[开关电源] 电源专业词汇(三)
780|0
 楼主| hbepu 发表于 2015-12-22 09:51 | 显示全部楼层 |阅读模式
  printed circuit 印制电路
  printed wiring 印制线路
  printed board 印制板
  printed circuit board 印制板电路
  printed wiring board 印制线路板
  printed component 印制元件
  printed contact 印制接点
  printed board assembly 印制板装配
  board 板
  rigid printed board 刚性印制板
  flexible printed circuit 挠性印制电路
  flexible printed wiring 挠性印制线路
  flush printed board 齐平印制板
  metal core printed board 金属芯印制板
  metal base printed board 金属基印制板
  mulit-wiring printed board 多重布线印制板
  molded circuit board 模塑电路板
  discrete wiring board 散线印制板
  micro wire board 微线印制板
  buile-up printed board 积层印制板
  surface laminar circuit 表面层合电路板
  B2it printed board 埋入凸块连印制板
  chip on board 载芯片板
  buried resistance board 埋电阻板
  mother board 母板
  daughter board 子板
  backplane 背板
  bare board 裸板
  copper-invar-copper board 键盘板夹心板
  dynamic flex board 动态挠性板
  static flex board 静态挠性板
  break-away planel 可断拼板
  cable 电缆
  flexible flat cable (FFC) 挠性扁平电缆
  membrane switch 薄膜开关
  hybrid circuit 混合电路
  thick film 厚膜
  thick film circuit 厚膜电路
  thin film 薄膜
  thin film hybrid circuit 薄膜混合电路
  interconnection 互连
  conductor trace line 导线
  flush conductor 齐平导线
  transmission line 传输线
  crossover 跨交
  edge-board contact 板边插头
  stiffener 增强板
  substrate 基底
  real estate 基板面
  conductor side 导线面
  component side 元件面
  solder side 焊接面
  printing 印制
  grid 网格
  pattern 图形
  conductive pattern 导电图形
  non-conductive pattern 非导电图形
  legend 字符
  mark 标志
  base material 基材
  laminate 层压板
  metal-clad bade material 覆金属箔基材
  copper-clad laminate (CCL) 覆铜箔层压板
  composite laminate 复合层压板
  thin laminate 薄层压板
  basis material 基体材料
  prepreg 预浸材料
  bonding sheet 粘结片
  preimpregnated bonding sheer 预浸粘结片
  epoxy glass substrate 环氧玻璃基板
  mass lamination panel 预制内层覆箔板
  core material 内层芯板
  bonding layer 粘结层
  film adhesive 粘结膜
  unsupported adhesive film 无支撑胶粘剂膜
  cover layer (cover lay) 覆盖层
  stiffener material 增强板材
  copper-clad surface 铜箔面
  foil removal surface 去铜箔面
  unclad laminate surface 层压板面
  base film surface 基膜面
  adhesive faec 胶粘剂面
  plate finish 原始光洁面
  matt finish 粗面
  length wise direction 纵向
  cross wise direction 模向
  cut to size panel 剪切板
  ultra thin laminate 超薄型层压板
  A-stage resin A阶树脂
  B-stage resin B阶树脂
  C-stage resin C阶树脂
  epoxy resin 环氧树脂
  phenolic resin 酚醛树脂
  polyester resin 聚酯树脂
  polyimide resin 聚酰亚胺树脂
  bismaleimide-triazine resin 双马来酰亚胺三嗪树脂
  acrylic resin 丙烯酸树脂
  melamine formaldehyde resin 三聚氰胺甲醛树脂
  polyfunctional epoxy resin 多官能环氧树脂
  brominated epoxy resin 溴化环氧树脂
  epoxy novolac 环氧酚醛
  fluroresin 氟树脂
  silicone resin 硅树脂
  silane 硅烷 polymer 聚合物
  amorphous polymer 无定形聚合物
  crystalline polamer 结晶现象
  dimorphism 双晶现象
  copolymer 共聚物
  synthetic 合成树脂
  thermosetting resin 热固性树脂
  thermoplastic resin 热塑性树脂
  photosensitive resin 感光性树脂
  epoxy value 环氧值
  dicyandiamide 双氰胺
  binder 粘结剂
  adesive 胶粘剂
  curing agent 固化剂
  flame retardant 阻燃剂
  opaquer 遮光剂
  plasticizers 增塑剂
  unsatuiated polyester 不饱和聚酯
  polyester 聚酯薄膜
  polyimide film (PI) 聚酰亚胺薄膜
  polytetrafluoetylene (PTFE) 聚四氟乙烯
  reinforcing material 增强材料
  glass fiber 玻璃纤维
  E-glass fibre E玻璃纤维
  D-glass fibre D玻璃纤维
  S-glass fibre S玻璃纤维
  glass fabric 玻璃布
  non-woven fabric 非织布
  glass mats 玻璃纤维垫
  yarn 纱线
  filament 单丝
  strand 绞股
  weft yarn 纬纱
  warp yarn 经纱
  denier 但尼尔
  warp-wise 经向
  thread count 织物经纬密度
  weave structure 织物组织
  plain structure 平纹组织
  grey fabric 坏布
  woven scrim 稀松织物
  bow of weave 弓纬
  end missing 断经
  mis-picks 缺纬
  bias 纬斜
  crease 折痕
  waviness 云织
  fish eye 鱼眼
  feather length 毛圈长
  mark 厚薄段
  split 裂缝
  twist of yarn 捻度
  size content 浸润剂含量
  size residue 浸润剂残留量
  finish level 处理剂含量
  size 浸润剂
  couplint agent 偶联剂
  finished fabric 处理织物
  polyarmide fiber 聚酰胺纤维
  aromatic polyamide paper 聚芳酰胺纤维纸
  breaking length 断裂长
  height of capillary rise 吸水高度
  wet strength retention 湿强度保留率
  whitenness 白度 ceramics 陶瓷
  conductive foil 导电箔
  copper foil 铜箔
  rolled copper foil 压延铜箔
  annealed copper foil 退火铜箔
  thin copper foil 薄铜箔
  adhesive coated foil 涂胶铜箔
  resin coated copper foil 涂胶脂铜箔
  composite metallic material 复合金属箔
  carrier foil 载体箔
  invar 殷瓦
  foil profile 箔(剖面)轮廓
  shiny side 光面
  matte side 粗糙面
  treated side 处理面
  stain proofing 防锈处理
  double treated foil 双面处理铜箔
  shematic diagram 原理图
  logic diagram 逻辑图
  printed wire layout 印制线路布设
  master drawing 布设总图
  computer aided drawing 计算机辅助制图
  computer controlled display 计算机控制显示
  placement 布局
  routing 布线
  layout 布图设计
  rerouting 重布
  simulation 模拟
  logic simulation 逻辑模拟
  circit simulation 电路模拟
  timing simulation 时序模拟
  modularization 模块化
  layout effeciency 布线完成率
  MDF databse 机器描述格式数据库
  design database 设计数据库
  design origin 设计原点
  optimization (design) 优化(设计)
  predominant axis 供设计优化坐标轴
  table origin 表格原点
  mirroring 镜像
  drive file 驱动文件
  intermediate file 中间文件
  manufacturing documentation 制造文件
  queue support database 队列支撑数据库
  component positioning 元件安置
  graphics dispaly 图形显示
  scaling factor 比例因子
  scan filling 扫描填充
  rectangle filling 矩形填充
  region filling 填充域
  physical design 实体设计
  logic design 逻辑设计
  logic circuit 逻辑电路
  hierarchical design 层次设计
  top-down design 自顶向下设计
  bottom-up design 自底向上设计
  net 线网
  digitzing 数字化
  design rule checking 设计规则检查
  router (CAD) 走(布)线器
  net list 网络表
  subnet 子线网
  objective function 目标函数
  post design processing (PDP) 设计后处理
  interactive drawing design 交互式制图设计
  cost metrix 费用矩阵
  engineering drawing 工程图
  block diagram 方块框图
  moze 迷宫
  component density 元件密度
  traveling salesman problem 回售货员问题
  degrees freedom 自由度
  out going degree 入度
  incoming degree 出度
  manhatton distance 曼哈顿距离
  euclidean distance 欧几里德距离
  network 网络
  array 阵列
  segment 段
  logic 逻辑
  logic design automation 逻辑设计自动化
  separated time 分线
  separated layer 分层
  definite sequence 定顺序
  conduction (track) 导线(通道)
  conductor width 导线(体)宽度
  conductor spacing 导线距离
  conductor layer 导线层
  conductor line/space 导线宽度/间距
  conductor layer No.1 第一导线层
  round pad 圆形盘
  square pad 方形盘
  diamond pad 菱形盘
  oblong pad 长方形焊盘
  bullet pad 子弹形盘
  teardrop pad 泪滴盘
  snowman pad 雪人盘
  V-shaped pad V形盘
  annular pad 环形盘
  non-circular pad 非圆形盘
  isolation pad 隔离盘
  monfunctional pad 非功能连接盘
  offset land 偏置连接盘
  back-bard land 腹(背)裸盘
  anchoring spaur 盘址
  land pattern 连接盘图形
  land grid array 连接盘网格阵列
  annular ring 孔环
  component hole 元件孔
  mounting hole 安装孔
  supported hole 支撑孔
  unsupported hole 非支撑孔
  via 导通孔
  plated through hole (PTH) 镀通孔
  access hole 余隙孔
  blind via (hole) 盲孔
  buried via hole 埋孔
  buried blind via 埋,盲孔
  any layer inner via hole 任意层内部导通孔
  all drilled hole 全部钻孔
  toaling hole 定位孔
  landless hole 无连接盘孔
  interstitial hole 中间孔
  landless via hole 无连接盘导通孔
  pilot hole 引导孔
  terminal clearomee hole 端接全隙孔
  dimensioned hole 准尺寸孔
  via-in-pad 在连接盘中导通孔
  hole location 孔位
  hole density 孔密度
  hole pattern 孔图
  drill drawing 钻孔图
  assembly drawing 装配图
  datum referan 参考基准
