[开发工具] mbed目前支持的STM32型号
1208|1
 楼主| 天灵灵地灵灵 发表于 2015-12-24 22:25 | 显示全部楼层 |阅读模式
mbed SDK
Build Status
The mbed Software Development Kit (SDK) is a C/C++ microcontroller software platform relied upon by tens of thousands of developers to build projects fast.
The SDK is licensed under the permissive Apache 2.0 licence, so you can use it in both commercial and personal projects with confidence.
The mbed SDK has been designed to provide enough hardware abstraction to be intuitive and concise, yet powerful enough to build complex projects. It is built on the low-level ARM CMSIS APIs, allowing you to code down to the metal if needed. In addition to RTOS, USB and Networking libraries, a cookbook of hundreds of reusable peripheral and module libraries have been built on top of the SDK by the mbed Developer Community.
STMicroelectronics:
 楼主| 天灵灵地灵灵 发表于 2015-12-24 22:26 | 显示全部楼层
上面列表里,带链接的就是点了直接跳转的,不带的,是可能目前还没有能用的,未来可能加入进来。
