[PIC®/AVR®/dsPIC®产品]
C30中 DataEEPROM.h中调用的外部函数存在哪?
674|0
tulufan234|  楼主 | 2015-12-25 15:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* ReadEErow prototype:
* Parameters Definition:
* Page:        is the 8 most significant bits of the source address in EEPROM
* Offset:      is 16 least significant bits of the source address in EEPROM
* DataOut:     is the 16-bit address of the destination RAM location or array
* Size:        is the number of words to read from EEPROM and is a value of 1 or 16
* Return Value:
* Function returns ERROREE (or -1) if Size is invalid
extern int ReadEE(int Page, int Offset, int* DataOut, int Size);
一直找不到这个外部函数的具体程序。
