帮看一下出错的地方怎么修改?
2054|2
 楼主| 雨下枫 发表于 2007-6-13 16:47 | 显示全部楼层 |阅读模式
TE, ST, IO, ic, logic
library&nbsp;ieee;<br />use&nbsp;ieee.std_logic_1164.all;<br />entity&nbsp;Counter&nbsp;is<br />port(CLK:&nbsp;in&nbsp;std_logic;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;result:&nbsp;inout&nbsp;std_logic_vector(7&nbsp;downto&nbsp;0));<br />end&nbsp;entity;<br />architecture&nbsp;behavioral&nbsp;of&nbsp;Counter&nbsp;is<br />signal&nbsp;temp:&nbsp;std_logic_vector(7&nbsp;downto&nbsp;0);<br />begin<br />&nbsp;&nbsp;&nbsp;&nbsp;process(CLK)<br />&nbsp;&nbsp;&nbsp;&nbsp;begin<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if(CLK'event&nbsp;and&nbsp;CLK&nbsp;=&nbsp;'1')&nbsp;then&nbsp;temp&nbsp;&lt=&nbsp;temp&nbsp;+&nbsp;'1';--Error&nbsp;(10327):&nbsp;VHDL&nbsp;error&nbsp;at&nbsp;Counter.vhd(12):&nbsp;can't&nbsp;determine&nbsp;definition&nbsp;of&nbsp;operator&nbsp;&quot;&quot;+&quot;&quot;&nbsp;--&nbsp;found&nbsp;0&nbsp;possible&nbsp;definitions<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;if;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;result&nbsp;&lt=&nbsp;temp;<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;process;<br />end&nbsp;behavioral;
 楼主| 雨下枫 发表于 2007-6-13 18:54 | 显示全部楼层
版主们上哪了?
怎么发了那么久,没一个人回复呢?本人在等待呢!
 楼主| 雨下枫 发表于 2007-6-13 20:38 | 显示全部楼层
OK
问题解决了!忘了加use&nbsp;ieee.std.logic_unsigned.all
