- * [url=home.php?mod=space&uid=288409]@file[/url] ADC/TIMTrigger_AutoInjection/main.c
- * [url=home.php?mod=space&uid=187600]@author[/url] MCD Application Team
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.5.0
- * [url=home.php?mod=space&uid=212281]@date[/url] 08-April-2011
- * [url=home.php?mod=space&uid=247401]@brief[/url] Main program body
- * @attention
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- /** @addtogroup STM32F10x_StdPeriph_Examples
- /** @addtogroup ADC_TIMTrigger_AutoInjection
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define ADC1_DR_Address ((uint32_t)0x4001244C)
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- ADC_InitTypeDef ADC_InitStructure;
- DMA_InitTypeDef DMA_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- __IO uint16_t ADC_RegularConvertedValueTab[32], ADC_InjectedConvertedValueTab[32];
- /* Private function prototypes -----------------------------------------------*/
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program
- * @param None
- * @retval None
- int main(void)
- /*!< At this stage the microcontroller clock setting is already configured,
- this is done through SystemInit() function which is called from startup
- file (startup_stm32f10x_xx.s) before to branch to application main.
- To reconfigure the default setting of SystemInit() function, refer to
- system_stm32f10x.c file
- /* System clocks configuration ---------------------------------------------*/
- RCC_Configuration();
- /* NVIC configuration ------------------------------------------------------*/
- // NVIC_Configuration();
- /* GPIO configuration ------------------------------------------------------*/
- GPIO_Configuration();
- /* TIM1 configuration ------------------------------------------------------*/
- /* Time Base configuration */
- TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
- TIM_TimeBaseStructure.TIM_Period = 1000;
- TIM_TimeBaseStructure.TIM_Prescaler = 71;
- TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
- /* TIM1 channel1 configuration in PWM mode */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = 500;
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
- TIM_OC1Init(TIM1, &TIM_OCInitStructure);
- /* DMA1 Channel1 Configuration ----------------------------------------------*/
- DMA_DeInit(DMA1_Channel1);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADC_RegularConvertedValueTab;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = 16;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- /* Enable DMA1 channel1 */
- DMA_Cmd(DMA1_Channel1, ENABLE);
- /* ADC1 configuration ------------------------------------------------------*/
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanConvMode = DISABLE;
- ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NbrOfChannel = 1;
- ADC_Init(ADC1, &ADC_InitStructure);
- /* ADC1 regular channel14 configuration */
- ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_71Cycles5);
- /* Set injected sequencer length */
- ADC_InjectedSequencerLengthConfig(ADC1, 1);
- //// /* ADC1 injected channel Configuration */
- //// ADC_InjectedChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_71Cycles5);
- //// /* ADC1 injected external trigger configuration */
- //// ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);
- /* Enable automatic injected conversion start after regular one */
- ADC_AutoInjectedConvCmd(ADC1, ENABLE);
- /* Enable ADC1 DMA */
- ADC_DMACmd(ADC1, ENABLE);
- /* Enable ADC1 external trigger */
- ADC_ExternalTrigConvCmd(ADC1, ENABLE);
- //// /* Enable JEOC interrupt */
- //// ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE);
- /* Enable ADC1 */
- ADC_Cmd(ADC1, ENABLE);
- /* Enable ADC1 reset calibration register */
- ADC_ResetCalibration(ADC1);
- /* Check the end of ADC1 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* Start ADC1 calibration */
- ADC_StartCalibration(ADC1);
- /* Check the end of ADC1 calibration */
- while(ADC_GetCalibrationStatus(ADC1));
- /* TIM1 main Output Enable */
- TIM_CtrlPWMOutputs(TIM1, ENABLE);
- while (1)
- TIM_Cmd(TIM1, ENABLE);
- /* Test on channel1 transfer complete flag */
- while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
- /* Clear channel1 transfer complete flag */
- DMA_ClearFlag(DMA1_FLAG_TC1);
- /* TIM1 counter disable */
- TIM_Cmd(TIM1, DISABLE);
- * @brief Configures the different system clocks.
- * @param None
- * @retval None
- /* Enable peripheral clocks ------------------------------------------------*/
- /* Enable DMA1 clock */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- /* Enable GPIOA, GPIOC, ADC1 and TIM1 clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC |
- RCC_APB2Periph_ADC1 | RCC_APB2Periph_TIM1, ENABLE);
- * @brief Configures the different GPIO ports.
- * @param None
- * @retval None
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure TIM1_CH1 (PA8) as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* Configure PC.06 as output push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- /* Configure PC.01 and PC.04 (ADC Channel11 and Channel14) as analog input */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
