S3C2410(QT2410)入门实践 --- ARM Linux 系列
2653|3
jordonwu|  楼主 | 2007-12-1 16:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
希望大家在此帖把在学习2410过程中关于ARM Linux的一些笔记写/贴出来,也希望有兴趣的朋友积极参与。
作为开贴,我转几篇我在chinaunix的关于2410入门的blog
http://blog.chinaunix.net/u/27204/showart_433964.html
QT2410入门实践02 --- PC(宿主机)环境安装及配置
2007/10/21
Host OS install and environment build
1. Linux host OS: Ubuntu-7.10
2. On linux host, execute command after installed
$sudo apt-get upgrade
$sudo apt-get update
3. Install build-essential - this will install a complete devlopement environment for linux
$sudo apt-get install build-essential libncurses5-dev bison flex texinfo zlib1g-dev gettext autoconf
4. Install nfs
$sudo apt-get install nfs-kernel-server
$edit /etc/exports, add /opt/nfs *(sync,rw)
$sudo /etc/init.d/nfs-kernel-server restart
5. Install tftp
1) Install tftpd and related packages.
$sudo apt-get install xinetd tftpd tftp
2) Create /etc/xinetd.d/tftp and put this entry:
service tftp
protocol = udp
port = 69
socket_type = dgram
wait = yes
user = nobody
server = /usr/sbin/in.tftpd
server_args = /tftpboot
disable = no
3) Make /tftpboot directory
$sudo mkdir /tftpboot
$sudo chmod -R 777 /tftpboot
$sudo chown -R nobody /tftpboot
4) Start tftpd through xinetd
$sudo /etc/init.d/xinetd start
http://blog.chinaunix.net/u/27204/showart_433982.html
QT2410入门实践03 ---交叉编译工具(for ARM)及rootfs(for NFS)的制作
Building buildroot-20071126.tar.bz2
1. Untar buildroot package
$cd /opt
$sudo tar -jxvf buildroot-20071126.tar.bz2 -C ./
$cd /opt/buildroot
2. Modify configure files
1)inittab
$cd /opt/buildroot/target/generic/target_skeleton/etc/ //this inittab using udev
$modify initab and uncomment ttyS0 as following:
# Put a getty on the serial port
ttyS0::respawn:/sbin/getty -L ttyS0 115200 vt100
$cd /opt/buildroot/target/generic/target_skeleton/etc/init.d
$Add "/bin/sh" to rcS script at the end of file as following:
#add /bin/sh start
echo "QT2410 shell"
/bin/sh
#add /bin/sh end
$cd /opt/buildroot/target/generic/target_busybox_skeleton/etc //this inittab using mdev buildin busybox
$modify inittab and uncomment ttySo as following:
$cd /opt/buildroot/target/generic/target_busybox_skeleton/etc/init.d
#add /bin/sh start
echo "QT2410 shell"
/bin/sh
#add /bin/sh end
3. Make menuconfig & make
$cd /opt/buildroot
$sudo make menuconfig (according to package versions as following list)
binutils-2.18.tar.bz2
busybox-1.7.2.tar.bz2
cramfs-1.1.tar.gz
fakeroot_1.8.2.tar.gz
gcc-4.2.1.tar.bz2
genext2fs-1.4.tar.gz
gmp-4.2.2.tar.bz2
jpegsrc.v6b.tar.gz
libpng-1.2.16.tar.bz2
linux-2.6.23.tar.bz2
lzo_1.08.orig.tar.gz
module-init-tools-3.2.2.tar.bz2
mpfr-2.3.0.patch
mpfr-2.3.0.tar.bz2
mtd_20061007.orig.tar.gz
ncurses-5.5.tar.gz
pkg-config-0.21.tar.gz
tslib-1.0.tar.bz2
uClibc-0.9.29.tar.bz2
udev-114.tar.bz2
zlib-1.2.3.tar.bz2
Note:1)MTD/JFFS2 utilities must use mtd_20061007.orig.tar.gz version
$sudo make WITHOUT_XATTR=1
4. Customizing busybox and uclibc for support NFS boot
$cd /opt/buildroot
$sudo make busybox-menuconfig
$Busybox Settings -> General configuration --> RPC support
$Busybox Settings -> Build Options -> Build BusBox as an static binary
$Linux System Utilities ->mount ->Support mounting NFS file system
$sudo cp project_build_arm/uclibc/busybox-1.7.2/.config package/busybox/busybox-1.6.0.config
$cd /opt/buildroot
$sudo make uclibc-menuconfig
$Networking support -> Remote Procedure Call (RPC) support
$cd /opt/buildroot
5. Make device node for console
$cd /opt/buildroot/project_build_arm/uclibc/root/dev
$rm console -Rf
$sudo mknod -m 660 console c 5 1
# Need not make device node of null(Note!!!)
# $rm null -Rf
# $sudo mknod -m 660 null c 1 3
6. Modify init scipt (Note:Need not this modification if you have done step 2。1)
$cd /opt/buildroot/project_build_arm/uclibc/root/etc
$modify inittab and uncomment ttyS0 as following:
$cd buildroot/project_build_arm/uclibc/root/etc/init.d
#add /bin/sh start
echo "QT2410 shell"
/bin/sh
#add /bin/sh end
7. Add cross toolchain to PATH environement(Host PC)
$Modify /etc/profile to add follow content at the end of file:
PATH=$PATH:/opt/buildroot/build_arm/staging_dir/usr/bin
export PATH
8. Done! That's all. ARM Linux cross toolchain and rootfs is completed until now!
9。/opt/buildroot/project_build_arm/uclibc/root/ is a completed rootfs for NFS。
最后对该帖有几点建议:
1。欢迎对该贴的相关内容进行讨论
2。不赞成对该帖的好坏进行讨论,不欢迎对该帖进行评价。个人认为这样是在浪费大家的时间。
相关链接:http://blog.chinaunix.net/u/27204/showart_433964.html
jordonwu|  楼主 | 2007-12-1 16:38 | 只看该作者
占几个位置以后写些文档
jordonwu|  楼主 | 2007-12-1 16:39 | 只看该作者
占几个位置以后写些文档2
占几个位置以后写些文档
占几个位置以后写些文档3
