I2c读EEPROM问题
4438|2
 楼主| ykwei2008 发表于 2008-4-15 11:46 | 显示全部楼层 |阅读模式
用南京万利电子的EK-STM32F开发板上调试程序,使用I2C1读写外部24C02芯片遇到在写PAGE时,发完开始条件后,一直在等待EV5,我用的是FWLIB里的I2C EXSAMPLE5例程,I2C 作如下修改以适应万利EK-STM32F开发板,这个问题论坛上有不少人提到,希望万利和ST写出可以在开发板上使用的例程。
i2c_ee.h
#define EEPROM_Block0_ADDRESS 0xA0   /* E2 = 0 */
i2c_ee.c
#define I2C_Speed             400000
#define I2C1_SLAVE_ADDRESS7    0xA0
#define I2C_PageSize           4
void I2C_EE_PageWrite(u8* pBuffer, u8 WriteAddr, u8 NumByteToWrite)
  /* Send START condition */
  I2C_GenerateSTART(I2C1, ENABLE);
  /* Test on EV5 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
  /* Send EEPROM address for write */
  I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Transmitter);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  /* Send the EEPROM's internal address to write to */
  I2C_SendData(I2C1, WriteAddr);
  /* Test on EV8 and clear it */
  while(! I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* While there is data to be written */
  while(NumByteToWrite--)
    /* Send the current byte */
    I2C_SendData(I2C1, *pBuffer);
    /* Point to the next byte to be written */
    pBuffer++;
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send STOP condition */
  I2C_GenerateSTOP(I2C1, ENABLE);
amixice 发表于 2008-4-15 14:14 | 显示全部楼层
试试
在每次I2C_GenerateSTART() 之前加I2C_EE_WaitEepromFromStandbyState().
遇到过同样问题, 加了好了.
 楼主| ykwei2008 发表于 2008-4-17 16:13 | 显示全部楼层
谢谢 amixice
 谢谢 amixice ,OK 了
