请教:编译错误
4501|2
zhiyu03|  楼主 | 2009-3-4 11:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
编译时的错误问题如下:我用的是PD5.0,使用HI-tech的LITE模式编译,不知此错误是怎么回事?
./boot.asm
./main.c
!WE:\psoc\DJ42\DJ42\DJ42\DJ42\main.c(77):(356) implicit conversion of float to integer (warning)
sed: can't read HTlinkOpts.lkp: No such file or directory
expanded_libs =
Linking..
HI-TECH C COMPILER (Cypress PSOC) Lite  V9.61PL2
Copyright (C) 1984-2008 HI-TECH SOFTWARE
(1273) Omniscient Code Generation not available in Lite mode (warning)
!WE:\psoc\DJ42\DJ42\DJ42\DJ42\function.h(262):(764) mismatched comparison (warning)
!WE:\psoc\DJ42\DJ42\DJ42\DJ42\function.h(284):(750) constant operand to || or && (warning)
!WE:\psoc\DJ42\DJ42\DJ42\DJ42\function.h(284):(764) mismatched comparison (warning)
!WE:\psoc\DJ42\DJ42\DJ42\DJ42\function.h(1374):(690) interrupt function requires address (warning)
!WE:\psoc\DJ42\DJ42\DJ42\DJ42\function.h(1416):(690) interrupt function requires address (warning)
: 0: (491) can't find 0x7D4 words for psect "UserModules" in segment "CODE" (error)
HI-TECH C PRO compiler averages 40% less code than this Lite mode
PRO may reduce your program size by 12196 bytes
To evaluate HI-TECH C PRO please visit http://cypress.htsoft.com/portal/convert
D:\PROGRA~1\Cypress\Common\CY3E64~1\tools\make: *** [output/DJ42.hex] Error 1
DJ42 - 1 error(s) 6 warning(s) 11:07:32
feelingme| | 2009-3-5 22:21 | 只看该作者
SOF_Flag!!!!!
我在编译有些程序时,  SOF_Flag可以编译通过,而有时候又会出现
!ERROR main.c[line number unavailable] undefined symbol '_SOF_Flag'
C:\PROGRA~1\Cypress\Common\CY3E64~1\tools\make: *** [output/d1.rom] Error 1
这样的问题,请指教!
小工程师| | 2009-3-6 17:35 | 只看该作者
LZ可以试一试ImageCraft complier
LZ,我以前也出现过类似的error,用ImageCraft complier去编译就可以了。
呵呵,希望有帮助。
