硬件开发和生产外包
2173|0
 楼主| izico 发表于 2009-7-8 15:49 | 显示全部楼层 |阅读模式
以下是需求规范,已有厂家报价成本US$7和两星期开发时间,我不是很相信它们的能力,但是最后的卖价不能超过US$20是死要求。<br /><br />请有意者与我联系,特别希望能与一个经验丰富的电子工程师长期合作。<br />不要跟贴,直接联系我,我不住论坛里。<br /><br />Skype:&nbsp;izicochang<br />GTalk:&nbsp;izicochang@gmail.com<br />MSN:&nbsp;izico@msn.com<br />Mail:&nbsp;izicochang@gmail.com<br /><br /><br />1.&nbsp;Camera<br /><br /><br />&nbsp;&nbsp;&nbsp;*&nbsp;1M&nbsp;pixel&nbsp;or&nbsp;more<br />&nbsp;&nbsp;&nbsp;*&nbsp;16&nbsp;bits&nbsp;color&nbsp;or&nbsp;more<br />&nbsp;&nbsp;&nbsp;*&nbsp;mountable<br />&nbsp;&nbsp;&nbsp;*&nbsp;operating&nbsp;environment&nbsp;-&nbsp;in&nbsp;door<br />&nbsp;&nbsp;&nbsp;*&nbsp;CMOS&nbsp;camera&nbsp;90&nbsp;degree&nbsp;FOV<br />&nbsp;&nbsp;&nbsp;*&nbsp;Top&nbsp;quality&nbsp;quality&nbsp;CMOS&nbsp;sensor.<br />&nbsp;&nbsp;&nbsp;*&nbsp;Temperature&nbsp;range:&nbsp;7C&nbsp;to&nbsp;32C<br />&nbsp;&nbsp;&nbsp;*&nbsp;product&nbsp;life&nbsp;expectancy:&nbsp;3&nbsp;years<br />&nbsp;&nbsp;&nbsp;*&nbsp;power&nbsp;sources:&nbsp;AC&nbsp;powered&nbsp;adaptor<br />&nbsp;&nbsp;&nbsp;*&nbsp;real&nbsp;time&nbsp;clock&nbsp;and&nbsp;time&nbsp;stamp&nbsp;on&nbsp;photo<br />&nbsp;&nbsp;&nbsp;*&nbsp;Need&nbsp;on/off&nbsp;indication&nbsp;LED<br />&nbsp;&nbsp;&nbsp;*&nbsp;auto&nbsp;focus&nbsp;or&nbsp;adjustable&nbsp;lens<br /><br />&nbsp;&nbsp;&nbsp;optional:<br /><br />&nbsp;&nbsp;&nbsp;*&nbsp;good&nbsp;quality&nbsp;in&nbsp;dim&nbsp;or&nbsp;dark&nbsp;light,&nbsp;this&nbsp;is&nbsp;prefered,&nbsp;but&nbsp;if&nbsp;the<br />cost&nbsp;will&nbsp;be&nbsp;much&nbsp;higher&nbsp;for&nbsp;this,&nbsp;this&nbsp;requirement&nbsp;can&nbsp;be&nbsp;removed<br />&nbsp;&nbsp;&nbsp;*&nbsp;video&nbsp;processing&nbsp;of&nbsp;5&nbsp;fps&nbsp;or&nbsp;above,&nbsp;if&nbsp;the&nbsp;cost&nbsp;not&nbsp;much&nbsp;higher,<br />and&nbsp;the&nbsp;video&nbsp;format&nbsp;is&nbsp;on&nbsp;your&nbsp;choice<br /><br /><br />&nbsp;&nbsp;&nbsp;2.&nbsp;USB&nbsp;host&nbsp;port<br /><br />&nbsp;&nbsp;&nbsp;*&nbsp;USB2.0&nbsp;OTG<br /><br />&nbsp;&nbsp;&nbsp;3.&nbsp;RS-232&nbsp;port<br /><br />&nbsp;&nbsp;&nbsp;*&nbsp;a&nbsp;real&nbsp;RS232&nbsp;port&nbsp;or&nbsp;a&nbsp;USB-to-Serial&nbsp;converter&nbsp;are&nbsp;both&nbsp;OK<br />dependant&nbsp;on&nbsp;cost<br /><br /><br />&nbsp;&nbsp;&nbsp;4.&nbsp;2G&nbsp;storage<br /><br />&nbsp;&nbsp;&nbsp;*&nbsp;Micro&nbsp;SD&nbsp;is&nbsp;OK&nbsp;as&nbsp;long&nbsp;as&nbsp;there's&nbsp;a&nbsp;USB&nbsp;interface&nbsp;for&nbsp;read/write<br />of&nbsp;the&nbsp;data&nbsp;from&nbsp;PC,&nbsp;and&nbsp;whether&nbsp;using&nbsp;Micro&nbsp;SD&nbsp;or&nbsp;USB&nbsp;flash&nbsp;is<br />dependant&nbsp;on&nbsp;cost<br /><br /><br />5.&nbsp;Linux/uClinux&nbsp;powered<br /><br />If&nbsp;the&nbsp;cost&nbsp;of&nbsp;a&nbsp;Linux&nbsp;powered&nbsp;board&nbsp;is&nbsp;more&nbsp;expensive&nbsp;than&nbsp;a&nbsp;uClinux<br />powered&nbsp;board&nbsp;within&nbsp;US$1,&nbsp;we&nbsp;prefer&nbsp;Linux,&nbsp;but&nbsp;both&nbsp;are&nbsp;OK<br /><br />We&nbsp;need&nbsp;just&nbsp;a&nbsp;working&nbsp;bootloader/kernel&nbsp;to&nbsp;confirm&nbsp;the&nbsp;hardware&nbsp;is<br />working&nbsp;well.
