[AVR单片机] GCC编译警告求助(Timer0匹配中断),谢谢!
1916|2
 楼主| cooperate 发表于 2008-3-17 11:55 | 显示全部楼层 |阅读模式
../Cpu.c:60: warning: return type defaults to `int'
../Cpu.c: In function `SIGNAL':
../Cpu.c:75: warning: control reaches end of non-void function
//以下为中断函数代码
SIGNAL (TIM0_COMPA_vect)    //Timer0定时60us中断
    uchar sreg = SREG;
    //系统定时时钟相关
    if(system_counter < 252) system_counter++;
    else
        system_counter = 0;
        SETBIT(system_status,SYSTEM_CLOCK);
    SREG = sreg;
 楼主| cooperate 发表于 2008-3-17 11:57 | 显示全部楼层
急,请各位支招,谢谢!
 楼主| cooperate 发表于 2008-3-17 14:28 | 显示全部楼层
解决了
忘了加:<avr/interrupt.h>   汗
