请教:ccs3.3连接时报错,请高手指点指点!
2128|3
 楼主| sunwind45 发表于 2008-6-19 22:03 | 显示全部楼层 |阅读模式
ccs3.3 连接目标板(DSP:TMS320VC5510)时报错,如下:
Error connecting to the target:
Error 0x80000242/-1143
Fatal Error during: Memory, Initialization, OCS,
The memory at 0x000000BE continually indicated it was 'not ready'
All memory operations currently in progress were aborted in order
to regain control of the processor.
This is considered a catastrophic event, but the debugger should
still be able to access memory and CPU registers.
System state has been altered.  It is strongly advised
that the processor should be reset before resuming execution,
Sequence ID: 0
Error Code: -1143
Error Class: 0x80000242
这会是什么问题?
是不是ccs的问题?
CLKOUT测了下,是正常的,dsp芯片应该没问题.
TI_CPIC 发表于 2008-6-20 17:30 | 显示全部楼层
可能是Emulator Driver的问题
先建议查一下Emulator Driver。稍后帮你看看有没有类似的案例。
TI_CPIC 发表于 2008-6-23 13:38 | 显示全部楼层
RE
如果CCS和仿真器能和其他板子相连吗?如果可以,那问题很有可能是目标板的硬件问题.
 楼主| sunwind45 发表于 2008-7-8 10:44 | 显示全部楼层
问题解决了
换了台PC机,就可以了.
据说,ccs跟系统有关.
天晓得哟.
