[AVR单片机] 求教avr控制YM1602C问题
3376|3
 楼主| 我是一只鱼 发表于 2008-7-7 01:22 | 显示全部楼层 |阅读模式
小弟希望用atmega48的四个端口,通过4094扩展,控制LCD YM1602C和按键扫描。程序如下:
void YM1602C_Write(UINT8 CD,UINT8 Data)
    SiBuffer.YM1602C_RS = CD;
    SiBuffer.YM1602C_RW = YM1602C_WRITE;
    SiBuffer.YM1602C_E = YM1602C_DISABLE;
    SI_Dispatch();
    UsDelay(4);
    SiBuffer.YM1602C_E = YM1602C_ENABLE;
    SI_Dispatch();
    UsDelay(1);
    SiBuffer.YM1602C_D = Data;
    SI_Dispatch();
    UsDelay(4);
    SI_Dispatch();
    UsDelay(1);
BOOL YM1602C_IsBusy()
    int i;
    char ret = FALSE;
    SiBuffer.YM1602C_RS = 0;//registors option
    SiBuffer.YM1602C_RW = 1;//Read
    SiBuffer.YM1602C_D7 = 0;
    SI_Dispatch();
    UsDelay(1);
    SI_Dispatch();
    UsDelay(2);
    if(IS_YM1602C_BUSY) ret = TRUE;
    SI_Dispatch();
    return ret;
void YM1602C_Init()
    UsDelay(4000);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_FUN_MASK|YM1602_CMD_2LINES|YM1602_CMD_INTERFACE8|YM1602_CMD_DSP_ON);
    UsDelay(40);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_DCB_MASK|YM1602_CMD_DISPLAY_ON);
    UsDelay(40);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_MODE_MASK|YM1602_CMD_INC_CURSOR);//&(~YM1602_CMD_SHIFT_DISPLAY));
    UsDelay(40);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_CLEAR_DISPLAYER);
    UsDelay(1530);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_RESET_CURSOR);
    UsDelay(1530);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_SHIFT_MASK|YM1602_CMD_SHIFT_RIGHT);
    UsDelay(40);
void YM1602C_DisplayStrAt(UINT8 nLine, UINT8 nCharacter, UINT8 *pChar)
    #if 0
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_DDRA_MASK|1);
    YM1602C_Write(YM1602C_DATA,0x3a);
    #else
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_DDRA_MASK|(0x40*(nLine-1)+nCharacter-1));
    while('\0' != *pChar)
        YM1602C_Write(YM1602C_DATA, *pChar++);
    #endif
void YM1602C_SetCursor(UINT8 nLine, UINT8 nColumn)
    if(nLine > 0 && nLine<3 && nColumn > 0 && nColumn < 17)
        YM1602C_Write(YM1602C_CMD,YM1602_CMD_DDRA_MASK|(0x40*(nLine-1)+nColumn-1));
    UsDelay(39);
另外,定时1秒写:
                        static char n = '0';
                        int i;
                        YM1602C_SetCursor(1,1);
                        for(i=0; i<16; i++)
                        YM1602C_Write(YM1602C_DATA,n);
                        if(++n > '9') n = '0';
但是LCD显示的是乱码。
希望高手指点迷津。
 楼主| 我是一只鱼 发表于 2008-7-7 01:37 | 显示全部楼层
补充说明
void YM1602C_Init()
    UsDelay(4000);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_FUN_MASK|YM1602_CMD_2LINES|YM1602_CMD_INTERFACE8|YM1602_CMD_DSP_ON);/////////////写命令,值0x3C
    UsDelay(40);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_DCB_MASK|YM1602_CMD_DISPLAY_ON);///////写命令,值0x0C
    UsDelay(40);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_MODE_MASK|YM1602_CMD_INC_CURSOR);//写命令,值0x06//&(~YM1602_CMD_SHIFT_DISPLAY));
    UsDelay(40);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_CLEAR_DISPLAYER);////写命令,值0x01
    UsDelay(1530);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_RESET_CURSOR);/////写命令,值0x02
    UsDelay(1530);
    YM1602C_Write(YM1602C_CMD, YM1602_CMD_SHIFT_MASK|YM1602_CMD_SHIFT_RIGHT);/////写命令,值0x14
    UsDelay(40);
RS、RW、E、DB0~DB8正确输出到YM1602C接口处。
xwj 发表于 2008-7-7 01:50 | 显示全部楼层
1、串那么大的电阻干嘛?2、串行,好慢啊,建议E单独控制
 楼主| 我是一只鱼 发表于 2008-7-7 22:13 | 显示全部楼层
re
由于读LCD是,LCD接口上出现LCD数据,而4094输出特性,可能与其冲突,因此加电阻耦合。我使用5v电源,阻值4k7,目的使冲突电流限制在1mA左右,保护电路。
我使用的单片机是Atmega48;使用8MHz晶振。应该足够应付。MCU管脚只有32个脚,只好用4094扩展。
有哪位大侠写过 耀宇的YM1602C的驱动的?能给小弟指点一下,感激不尽!
