关于定时器中断的程序问题
2985|5
 楼主| 懒懒的石块 发表于 2008-7-8 09:24 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#include <absacc.h>
#include <stdio.h>
#include <math.h>
#include <stdlib.h>
#define uchar unsigned char
#define uint unsigned int
sfr WDTRST = 0xA6;
  sbit RW    = P1^5;
  sbit     Elcm=P1^4;
   sbit     ad0=P0^7;
    sbit     p03=P0^3;
   sbit     tt=P2^0;
   sbit     t0=P3^4;
    sbit     PINEOC=P1^2;
sbit DR=P1^0;
sbit MDR=P1^1;
#define DataPort P0
#define ADDRPort P2
#define Busy         0x80
#define Work_M        0x38//n=1,f=0
#define Cls            0x01
#define Input_M     0x06//i/d=1  ac++  s=0 screen move=off
#define Screen_Off     0x08
#define Disp_M        0x0c//d=1 disp=on c=0 cursor=off
#define Ddram_Al1    0x80;
#define Ddram_Al2    0xc0;//0x80+0x40
#define    Wait1us        _nop_();
#define    Wait2us        {_nop_();_nop_();}
#define    Wait4us        {Wait2us;Wait2us;}
#define    Wait8us        {Wait4us;Wait4us;}
#define    Wait10us      {Wait8us;Wait2us;}
   unsigned char  com,dat;
//       uchar xdata ramadd _at_ 0x0200;
unsigned char xdata h1add _at_ 0xff71;
unsigned char xdata h2add _at_ 0xff6f;
unsigned char xdata h3add _at_ 0xff8f;
unsigned char xdata le1 _at_ 0xff10;
unsigned char xdata le2 _at_ 0xff11;
unsigned char xdata opp _at_ 0x0088;
unsigned char xdata AD0 _at_ 0xff40;
unsigned char xdata AD1 _at_ 0xff42;
unsigned char xdata AD2 _at_ 0xff44;
unsigned char xdata AD3 _at_ 0xff46;
unsigned char xdata AD4 _at_ 0xff48;
unsigned char xdata AD5 _at_ 0xff4A;
unsigned char xdata AD6 _at_ 0xff4C;
unsigned char xdata AD7 _at_ 0xff4E;
unsigned char xdata c8251 _at_ 0xff50;
unsigned char xdata d8251 _at_ 0xff51;
unsigned char xdata COM8279 _at_ 0xff00;             //8279com
unsigned char xdata DATA8279 _at_ 0xff01;             //8279data
unsigned char count;
uchar FREQ;
uchar temp;
uchar temp2;
void  displcd(void);
uchar dispc[2][16]=
    ' ','0','O','O','T','P','U','T',' ','P','O','W','E','R',' ',' ',
    ' ',' ',' ',' ',' ',' ',' ',' ',' ',' ','d','B','m',' ',' ',' '
  code  unsigned char ctab[19]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','<','>','L','O','W'};
void DELAY_1MS(uint i)      //延时1毫秒子程序
 uchar j;                   //定义局部变量j
 while(i--)                 //每循环一次,变量减一,为零返回
   for(j=0;j<123;j++);      //循环123次
        void Delay(uint i)
    uint j;
    for(;i>0;i--)
        { for(j=1;j>0;j--);}
    void initlcd(void){
 RW=0;
_nop_();
     le1=Work_M;
    Delay(50);
    le1=Screen_Off;
          Delay(50);
    le1=Cls;
           Delay(50);
    le1=Input_M;
        Delay(50);
       le1=Disp_M;
        Delay(50);
   RW=1;
void displcd(void){                           //LCD1602
uint i;
 RW=0;
_nop_();
  le1=Ddram_Al1;
 Delay(200);
  for (i=0;i<16;i++)
    le2=dispc[0];
    Delay(200);
le1=Ddram_Al2;
Delay(20);
  for (i=0;i<16;i++)
    le2=dispc[1];
    Delay(20);
     // 写字符
  //le2='0';
     // 写字符
   RW=1;
void main(void)
//以下设置中断和定时器;
 EA=1; PT0=1;
 ET0=1;
 IT0=1;IT1=1;
 EX0=1;EX1=1;
 TCON=0x08;
 TMOD=0x21;
//定时器0为产生1ms的中断,定时器1为9600b/s的波特率发生器;
TH0=-1000/256;
TL0=-1000%256;
TL1=0xfd;
TH1=0xfd;
SCON=0x50;
PCON=0x80;
//开定时器
TR1=1;
TR0=1;
TI=1;
while(1){}
void intsvr1(void) interrupt 1         //ADC0809
      uchar temp;
      uchar A,co;
      uchar B;
      uchar C;
      uchar D;
//重新装入定时器0的初值;
  TH0=-10000/256;
  TL0=-10000%256;
     FREQ=FREQ+1;
  if(FREQ==100)
     FREQ=0;
     temp=AD0;
     A = temp/1000;
     B = temp%1000/100;
      C = temp%1000%100/10;
      D = temp%1000%100%10;
     co=A*1000+B*100+C*10+D;
     dispc[1][1]    =ctab[B];
     dispc[1][2]    =ctab[C];
     dispc[1][3]    =ctab[D];
     displcd();
johnwjl 发表于 2008-7-8 14:38 | 显示全部楼层
 楼主| 懒懒的石块 发表于 2008-7-8 14:58 | 显示全部楼层
定时器只能检测到一次AD的转换
定时器只能检测到一次AD的转换,可能是无法跳回到主程序当中的。
dai_weis 发表于 2008-7-8 16:33 | 显示全部楼层
中断时间过短,过于频繁
导致中断内容没有执行完就发生再次中断了
acmilann 发表于 2008-7-10 19:36 | 显示全部楼层
中断中不要做太多事情
 if(FREQ==100)
     FREQ=0;
     temp=AD0;
     A = temp/1000;
     B = temp%1000/100;
     displcd();
将这些放到主程序的while(1)中去
当然FREQ要定义成全局变量
 楼主| 懒懒的石块 发表于 2008-7-11 09:20 | 显示全部楼层
谢谢大家
谢谢,acmilann,给我的建议。
我的程序给我调试出来了,谢谢大家。
