LITE定时中断处理程序
3079|3
 楼主| bluergreen 发表于 2008-10-10 10:25 | 显示全部楼层 |阅读模式
我使用的IC是ST7FLITE05Y0M6,使用的晶振是1M的内部晶振。程序如下所示。我想实现的效果是让PA3控制的LED灯先灭2.5秒左右,然后亮1秒左右,再灭2.5秒,如此循环下去。可是实现不了我所想的效果
st7/
    ; SEGMENT MAPPING FILE AUTOMATICALLY GENERATED BY STVD7
    ; SHOULD NOT BE MANUALLY MODIFIED.
    ; CHANGES WILL BE LOST WHEN FILE IS REGENERATED.
    TITLE "KF85.ASM"
    MOTOROLA
    #INCLUDE "st7flite05.inc"
    BYTES            ; The following addresses are 8 bits long
    segment byte at 80-FF 'ram0'
MMSH   DS.B $1
MMSL   DS.B $1
TEMP   DS.W $2
    WORDS            ; The following addresses are 16 bits long
    segment byte at FA00-FFDF 'rom'
TL1 DC.B $0E2
TH1 DC.B $04
TL2 DC.B $0E8
TH2 DC.B $03
COUNT DC.B $10
COUNT1 DC.B $10
MAIN:
    LD A,#$0
    LD PBDDR,A
    LD A,#$05
    LD PBOR,A
    LD A,#$0F
    LD PADDR,A
    LD PAOR,A
    CLR PADR
    LD A,$0FFDE
    LD RCCR,A
    LD A,#$10
  LD LTCSR,A
    LD A,#0
    LD MMSH,A
    ;LD A,#255
    LD MMSL,A
    BSET PADR,#2
    BRES PADR,#3
  RIM
    JRA *
TBINT:
  LD A,LTCSR
    LD A,#$01
    CP A,MMSH
    JRNE L2
L1:
  LD A,MMSL
    CP A,#$02C
    JRULT L2
    CP A,#$90   ;持续亮1000ms后变为灭
    JRULE L5
    JRA L6
L2:
  INC MMSL
    JRNE L4
    INC MMSH
    JRA L4
L5:
  INC MMSL
  BSET PADR,#3
    JRA L4
L6:
  BRES PADR,#3
  LD A,#0
    LD MMSL,A
    LD MMSH,A
L4:
  IRET
NonHandledInterrupt
  iret
    segment byte at FFE0-FFFF 'vectit'
                DC.W    NonHandledInterrupt ;FFE0-FFE1h location
                DC.W    NonHandledInterrupt ;FFE2-FFE3h location
                DC.W   TBINT;FFE4-FFE5h location
                DC.W    NonHandledInterrupt ;FFE6-FFE7h location
                DC.W    NonHandledInterrupt ;FFE8-FFE9h location
                DC.W    NonHandledInterrupt ;FFEA-FFEBh location
                DC.W    NonHandledInterrupt ;FFEC-FFEDh location
                DC.W    NonHandledInterrupt ;FFEE-FFEFh location
                DC.W    NonHandledInterrupt ;FFF0-FFF1h location
                DC.W    NonHandledInterrupt ;FFF2-FFF3h location
                DC.W    NonHandledInterrupt ;FFF4-FFF5h location
                DC.W    NonHandledInterrupt ;FFF6-FFF7h location
                DC.W    NonHandledInterrupt ;FFF8-FFF9h location
                DC.W    NonHandledInterrupt ;FFFA-FFFBh location
                DC.W    NonHandledInterrupt ;FFFC-FFFDh location
                                DC.W    MAIN                ;reset
        END
我的问题是,在DEBUG调试的过程中可以看到定时周期为8ms,并且可以循环地进入到定时中断。可是就是看不到灯会闪烁,奇怪。请各位高手帮我解答,谢谢!
 楼主| bluergreen 发表于 2008-10-10 11:52 | 显示全部楼层
奇怪,好像连中断也进不去,我调试后才发现
 楼主| bluergreen 发表于 2008-10-13 08:22 | 显示全部楼层
搞定了,原来是IC的问题,不是我程序的问题,郁闷
香水城 发表于 2008-10-13 10:10 | 显示全部楼层
IC的问题?什么问题?
