STM32读写M95040 SPI EEPROM问题求教
3926|0
 楼主| just_soso 发表于 2009-3-9 20:13 | 显示全部楼层 |阅读模式
用SPI1读写SPI EEPROM M95040. clock和MOSI都能正常工作,就是MISO上没有信号。用示波器看信号,MOSI信号符合时序。但是MISO上就是没有信号。
还有个很奇怪的问题。就是单步执行,发现能够写入,也能读出数量,任意修改写入某地址的数据,都能正确读出。但是全速运行时读出来的都是0xFF.是不是延时的问题?
程序如下:请高手看看。谢谢!
/* EEPROM instructions */
#define WREN    0x06
#define WRDI    0x04
#define RDSR     0x05
#define WRSR    0x01
#define READ    0x03
#define WRITE    0x02
/* Private variables ---------------------------------------------------------*/
SPI_InitTypeDef  SPI_InitStructure;
ROUTINE NAME : SPI_Init
INPUT/OUTPUT : None
DESCRIPTION  : Configure the SPI peripheral
COMMENTS     :
void SPI_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1 | RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);
  /* Configure SPI1 pins: SCK, MISO and MOSI ---------------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_SetBits(GPIOA, GPIO_Pin_4);
  /* SPI1 configuration */
  SPI_I2S_DeInit(SPI1);
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  /* Enable SPI1  */
  SPI_Cmd(SPI1, ENABLE);
ROUTINE NAME : Chk_WP_Bit
INPUT/OUTPUT : None/Boolean
DESCRIPTION  : Return 'TRUE' if write is still in progress in the EEPROM (M95040)
COMMENTS     :
bool Chk_WP_Bit(void)
  u8 i;
  SPI_Cmd(SPI1, ENABLE);//SetBit(SPICR,6);  // spi enable
  GPIO_ResetBits(GPIOA,GPIO_Pin_4);
  //SPI_SendByte(RDSR);
  while((SPI1->SR & SPI_I2S_FLAG_TXE) == RESET);
  SPI1->DR=RDSR;
  while((SPI1->SR & SPI_I2S_FLAG_RXNE) == RESET);
  i=SPI1->DR;
  SPI1->DR=RDSR;
  i=SPI1->DR;
 GPIO_SetBits(GPIOA,GPIO_Pin_4);//SetBit(PADR,6);
 SPI_Cmd(SPI1, DISABLE);//ClrBit(SPICR,6);  // spi disable
 if(((SPI1->DR)|0xFE)==0xFE) return(TRUE);//(ValBit(SPIDR,0)) return(TRUE);
 else
 return(FALSE);
ROUTINE NAME : Read_EEPROM
INPUT/OUTPUT : u8 (adress) / u8 (data)
DESCRIPTION  : Return data located at the adress specified
COMMENTS     :
u8 Read_EEPROM(u8 add)
  u8 data;
  SPI_SendByte(READ);
  SPI_SendByte(add);
  data=SPI_ReadByte();
  return (data);
ROUTINE NAME : Send_EEPROM
INPUT/OUTPUT : u8,u8 (adress,data) / None
DESCRIPTION  : Send data byte to the adress specified
COMMENTS     :
void Send_EEPROM(u8 add, u8 data)
  GPIO_ResetBits(GPIOA,GPIO_Pin_4);//ClrBit(PADR,6);
  SPI_SendByte(WREN);
  SPI_SendByte(WRITE);
  SPI_SendByte(add);
  SPI_SendByte(data);
* Function Name  : SPI_SendByte
* Description    : Sends a byte through the SPI interface and return the byte
*                  received from the SPI bus.
* Input          : byte : byte to send.
* Output         : None
* Return         : The value of the received byte.
u8 SPI_SendByte(u8 byte)
  /* Loop while DR register in not emplty */
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  /* Send byte through the SPI1 peripheral */
  SPI_I2S_SendData(SPI1, byte);
  /* Wait to receive a byte */
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_I2S_ReceiveData(SPI1);
* Function Name  : SPI_ReadByte
* Description    : Reads a byte from the SPI Flash.
*                  This function must be used only if the Start_Read_Sequence
*                  function has been previously called.
* Input          : None
* Output         : None
* Return         : Byte Read from the SPI Flash.
u8 SPI_ReadByte(void)
  return (SPI_SendByte(0x55));
void Delay_us(u16 us)
    while(us--);
ROUTINE NAME : Delay_ms
INPUT/OUTPUT : ms
DESCRIPTION  :
COMMENTS     :
void Delay_ms(u16 ms)
    u16 i,j;
    for(i=0;i<ms;i++)
    for(j=0;j<15;j++)
    Delay_us(1);
