下载地址:http://www.embedinfo.com/down-list.asp?id=667
【资料大小】 113.8M 【资料语言】 英文(帮助文件为中文)
【更新说明】 RealView Microcontroller Development Kit - Version 3.70 [Board Support] ·Added: Blinky example for Atmel board SAM3U-EK in folder ..\ARM\Boards\Atmel\SAM3U-EK\. ·Added: RTX-Blinky example for Atmel board AT91SAM9G20-EK in folder ..\ARM\Boards\Atmel\AT91SAM9G20-EK\. ·Updated: RTX-Blinky example for Atmel board AT91SAM9260-EK in folder ..\ARM\Boards\Atmel\AT91SAM92060-EK\. ·Updated: RTX-Blinky example for Atmel board AT91SAM9263-EK in folder ..\ARM\Boards\Atmel\AT91SAM92063-EK\. ·Added: USB examples for Keil MCB1700 board with LPC1766 device in folder ..\ARM\Boards\Keil\MCB1700\USBHID\ and ..\ARM\Boards\Keil\MCB1700\USBMem\. ·Added: EasyWEB example for Keil MCB1700 board with LPC1766 device in folder ..\ARM\Boards\Keil\MCB1700\EasyWEB\. ·Added: RTX_Blinky, RTX_Traffic, and LCD_Blinky examples for Keil MCB1700 board with LPC1766 device in folders ..\ARM\Boards\Keil\MCB1700\RTX_Blinky\, ..\ARM\Boards\Keil\MCB1700\RTX_Traffic\, and ..\ARM\Boards\Keil\MCB1700\LCD_Blinky\. ·Added: CAN examples for Keil MCB1700 board with LPC1768 in folder ..\ARM\Boards\Keil\MCB1700\CAN\. ·Added: CAN examples for Keil MCB2300 board in folder ..\ARM\Boards\Keil\MCB2300\CAN\. ·Updated: USB examples for Keil MCBSTR9, MCBSTM32, and MCBSTM32E boards in folders ..\ARM\Boards\Keil\MCBSTR9\, ..\ARM\Boards\Keil\MCBSTM32\, and ..\ARM\Boards\Keil\MCBSTM32E\. ·Updated: USB examples for Keil MCBSTR7, and MCBSTM750 boards in folders ..\ARM\Boards\Keil\MCBSTR7\, and ..\ARM\Boards\Keil\MCBSTM750\. ·Updated: USB examples for ST CQ-STARM2, EK-STM32F, and STR9_DONGLE boards in folders ..\ARM\Boards\ST\CQ-STARM2\, ..\ARM\Boards\ST\EK-STM32F\, and ..\ARM\Boards\STR9_DONGLE\. ·Added: Blinky example for Embedded Artists board LPC3131 in folder ..\ARM\Boards\Embedded Artists\LPC3131\.
[Device support] ·Updated: Headerfiles, startup code, and Flash programming algorithm for ATMEL ATSAM3xx devices. ·Updated: Flash programming algorithms for NXP LPC17xx devices. ·Added: enhanced SPI peripheral simulation for NXP LPC21xx/22xx devices. ·Updated: Flash algorithms for STM32F10x devices in folder ..\ARM\Flash\STM32F10x\.
[Target debugging] ·Added: automatic detection for Segger's J-Link Pro debugger over TCP/IP. ·Added: automatic detection and configuration for Segger's J-Link and J-Trace debugger. ·Enhanced: the J-Link driver supports Atmel SAM3 devices. ·Enhanced: the J-Link driver shows the interrupt names for STM STM32, Atmel SAM3, Toshiba TMPM330, and Luminary Micro LM3S devices inside the trace window.
[RTX-Enhancements] ·Added: RTX configuration for Atmel ATSAM9260 devices. Preconfigured RTX_Blinky example for the Atmel ATSAM9260-EK evaluation board can be found in ..\ARM\Boards\Atmel\AT91SAM9260-EK\ folder.
[RTX-Problems Solved] Corrected: problems in Cortex-M library: ·The _alloc_box and _free_box functions have re-enabled globally disabled interrupts. ·When deleting the preceding task (by order of TID's), the os_tsk_delete function has deleted the current running task instead. ·The system might incorrectly execute svc system calls in very rare timing sequences when followed by the SysTick timer interrupt.
下载地址:http://www.embedinfo.com/down-list.asp?id=667 相关链接:http://bbs.embedinfo.com |
