[8/16-bit MCU] LPC54102 人机界面按键输入功能
1397|5
 楼主| Messi1999 发表于 2016-1-15 21:38 | 显示全部楼层 |阅读模式
目的:通过4个按键,设置基本参数!
占用端口:GPIO:通用输入输出端口
占用硬件资源   GINT:GPIO组中断块 (响应按键)
                     RIT :定时器 (去抖延时)
一、端口
  1. #define BUTTON1_PORT        0        /* GPIO port number for SW1 */
  2. #define BUTTON1_PIN         3        /* GPIO pin number for SW1 */
  3. #define BUTTON2_PORT        0        /* GPIO port number for SW2 */
  4. #define BUTTON2_PIN         4        /* GPIO pin number for SW2 */
  5. #define BUTTON3_PORT        0        /* GPIO port number for SW3 */
  6. #define BUTTON3_PIN         23        /* GPIO pin number for SW3 */
  7. #define BUTTON4_PORT        0        /* GPIO port number for SW4 */
  8. #define BUTTON4_PIN         24        /* GPIO pin number for SW4 */
二、初始化GINT
  1. /*****************************************************************************
  2. *
  3. *初始化GINT中断组
  4. *****************************************************************************/
  5. void Init_Gint(void)
  6. {
  7.         /* 初始化GPIO组中断块 */
  8.         Chip_GPIOGP_Init(LPC_GINT);
  9.         /* Configure pins as GPIO */
  10.         Chip_IOCON_PinMuxSet(LPC_IOCON, BUTTON1_PORT, BUTTON1_PIN,
  11.        (IOCON_FUNC0 | IOCON_DIGITAL_EN  |IOCON_MODE_PULLUP ));//IOCON_GPIO_MODE
  12.         Chip_IOCON_PinMuxSet(LPC_IOCON, BUTTON2_PORT, BUTTON2_PIN,
  13.        (IOCON_FUNC0 |  IOCON_MODE_PULLUP| IOCON_DIGITAL_EN));//IOCON_MODE_INACT
  14.         Chip_IOCON_PinMuxSet(LPC_IOCON, BUTTON3_PORT, BUTTON3_PIN,
  15.        (IOCON_FUNC0 | IOCON_DIGITAL_EN  | IOCON_MODE_PULLUP ));
  16.         Chip_IOCON_PinMuxSet(LPC_IOCON, BUTTON4_PORT, BUTTON4_PIN,
  17.        (IOCON_FUNC0 | IOCON_DIGITAL_EN  | IOCON_MODE_PULLUP));
  18.
  19.         /* Group GPIO interrupt 0 will be invoked when both SW1-WAKE and SW2-ISP buttons are pressed. */
  20.         Chip_GPIO_SetPinDIRInput(LPC_GPIO, BUTTON1_PORT, BUTTON1_PIN);
  21.         Chip_GPIO_SetPinDIRInput(LPC_GPIO, BUTTON2_PORT, BUTTON2_PIN);
  22.   Chip_GPIO_SetPinDIRInput(LPC_GPIO, BUTTON3_PORT, BUTTON3_PIN);
  23.         Chip_GPIO_SetPinDIRInput(LPC_GPIO, BUTTON4_PORT, BUTTON4_PIN);
  24.
  25.         /* Button 1 Setup for falling edge*/
  26.         //设置选择引脚组和端口为低电平触发
  27.         Chip_GPIOGP_SelectLowLevel(LPC_GINT, 0, BUTTON1_PORT, 1UL << BUTTON1_PIN);
  28.         //启用选择引脚组中断
  29.         Chip_GPIOGP_EnableGroupPins(LPC_GINT, 0, BUTTON1_PORT, 1UL << BUTTON1_PIN);
  30.         /* Button 2 Setup for falling edge*/
  31.         //设置选择引脚组和端口为低电平触发
  32.         Chip_GPIOGP_SelectLowLevel(LPC_GINT, 0, BUTTON2_PORT, 1UL << BUTTON2_PIN);
  33.         //启用选择引脚组中断
  34.         Chip_GPIOGP_EnableGroupPins(LPC_GINT, 0, BUTTON2_PORT, 1UL << BUTTON2_PIN);
 楼主| Messi1999 发表于 2016-1-15 21:40 | 显示全部楼层
  2.         Chip_GPIOGP_SelectLowLevel(LPC_GINT, 0, BUTTON3_PORT, 1UL << BUTTON3_PIN);
  3.         //启用选择引脚组中断
  4.         Chip_GPIOGP_EnableGroupPins(LPC_GINT, 0, BUTTON3_PORT, 1UL << BUTTON3_PIN);
  5.         /* Button 2 Setup for falling edge*/
  7.         Chip_GPIOGP_SelectLowLevel(LPC_GINT, 0, BUTTON4_PORT, 1UL << BUTTON4_PIN);
  8.         //启用选择引脚组中断
  9.         Chip_GPIOGP_EnableGroupPins(LPC_GINT, 0, BUTTON4_PORT, 1UL << BUTTON4_PIN);
  10.         /* Trigger interrupt when both buttons are pressed */
  11.         //触发选定的GPIO组功能上的所有匹配引脚组(AND模式)
  12.         Chip_GPIOGP_SelectOrMode(LPC_GINT, 0);   //And
  13.         //触发选定的GPIO组的功能在组(或模式)的引脚
  14.         //选择GPIO功能组边沿触发模式
  15.         Chip_GPIOGP_SelectEdgeMode(LPC_GINT, 0);
  16.         /* Enable Group GPIO interrupt 0 */
  17.         NVIC_EnableIRQ(GINT0_IRQn);
  18. }
注意这里要求4个按键,有一个按下就触发中断,所以这里选择AND模式
 楼主| Messi1999 发表于 2016-1-15 21:41 | 显示全部楼层
三、GINT中断响应
  2. *
  3. *GINT中断
  5. void GINT0_IRQHandler(void)
  6. {
  7.         uint32_t value=0;
  8.         uint32_t keyvalue=0;
  9.
  10.
  11.         //选定组清除中断挂起状态
  12.         Chip_GPIOGP_ClearIntStatus(LPC_GINT, 0);
  13.         if (buttonDebounce == 1)
  14.         {
  15.                 buttonDebounce = 2;
  16.                  //开启定时器,定时中断关闭定时器 ,延时去抖
  17.                 Init_Rit();
  18.                 //获取端口状态值
  19.                 value=Chip_GPIO_GetPortValue(LPC_GPIO, 0);
  20.
  21.                 keyvalue = value & ((1<<BUTTON1_PIN) | (1<<BUTTON2_PIN) |(1<<BUTTON3_PIN) |(1<<BUTTON4_PIN));
  22.
  23.                 if((keyvalue & (1<<BUTTON1_PIN))==0)
  24.                 {gkeyvalue = 1;}
  25.                 else if((keyvalue & (1<<BUTTON2_PIN))==0)
  26.                 {gkeyvalue = 2;}
  27.                 else if((keyvalue & (1<<BUTTON3_PIN))==0)
  28.                 {gkeyvalue = 3;}
  29.                 else if((keyvalue & (1<<BUTTON4_PIN))==0)
  30.                 {gkeyvalue = 4;}
  31.                 else
  32.                 {gkeyvalue = 0;}
  33.         }
  34.
  35.
  36.         //Board_LED_Toggle(0);
  37. }
 楼主| Messi1999 发表于 2016-1-15 21:42 | 显示全部楼层
四、定时器初始化
重复中断定时器(RIT)
250ms按键去抖,GINT触发
  1. *******************************************************************/
  2. void Init_Rit(void)
  3. {
  4.         /* Initialize RI Timer */
  5.         Chip_RIT_Init(LPC_RITIMER);
  6.         /* Setup timer period to 10Hz (100mS) */
  7.         Chip_RIT_SetTimerInterval64(LPC_RITIMER, 250);//250ms
  8.         /* Enable RI Timer */
  9.         NVIC_EnableIRQ(RIT_IRQn);
  10.         /* Enable RI Timer and clear on compare match or ....
  11.            use Chip_RIT_EnableCTRL(LPC_RITIMER, RIT_CTRL_ENCLR | RIT_CTRL_TEN);
  12.            to save space. */
  13.         Chip_RIT_Enable(LPC_RITIMER);
  14.         Chip_RIT_CompClearEnable(LPC_RITIMER);
  15. }
 楼主| Messi1999 发表于 2016-1-15 21:43 | 显示全部楼层
五、RIT中断
重复中断定时器(RIT)
  2. void RIT_IRQHandler(void)
  3. {
  4.         Chip_RIT_ClearInt(LPC_RITIMER);
  5. if (buttonDebounce == 2)
  6.         {
  7.                 buttonDebounce = 1;
  8.                 /* Disable RI Timer */
  9.                 Chip_RIT_Disable(LPC_RITIMER);
  10.
  11.                 Chip_RIT_DeInit(LPC_RITIMER);
  12.
  13.                 NVIC_DisableIRQ(RIT_IRQn);
  14.         }
  15. }
