今天遇到鬼了...
8620|44
mohanwei 发表于 2009-8-25 15:12 | 显示全部楼层
用指向性强的麦克风DIY一个音频版“猎狐”机……
fehuaxue 发表于 2009-8-28 10:24 | 显示全部楼层
曾经搞过一块数字功放,电感可以出声!没接喇叭也能唱歌!呵呵!
应该是你的PCB出问题,找找是线上的频率,看哪条接近,应该可以找出来的!
frienz 发表于 2009-8-28 15:25 | 显示全部楼层
前几天比较了几家电容厂商的4.7uF, 0805, 25V的X5R电容,(在俺的应用系统里)通通都有压电效应的问题,从最严重到较轻的排名是:
Samsung > Taiyo > Murata > TDK > AVX
友情提示:以上排名严格讲没有任何参考价值,因为抽样很少,而离散性很明显。不要以为大厂名牌就没有问题
,改进设计或者更换其他类型的电容才是解决之道。
frienz 发表于 2009-8-28 15:27 | 显示全部楼层
在8L的转贴里有一句话(如下),算是得到了验证。
“Piezoelectric effects can result in noise for ferroelectric ceramic chips, such as those of the middle to high dielectric constants like X5R, X7R, X8R, Y5V, Y5U, Z5U, etc. Piezoelectricity occurs in all ferroelectric dielectrics, regardless of manufacturer, and the means to reduce these effects usually requires the dielectric constant be lowered (the capacitance capability is also lowered with the lower dielectric constant) while moving to higher dielectrics (Y5V, Z5V are usually cheaper) creates a higher susceptibility to this effect. ”
t2397362 发表于 2009-8-28 21:40 | 显示全部楼层
都是强人,测测我耳朵的频带
