OSTaskNameSet是什么功能
8678|4
 楼主| pigeon0411 发表于 2009-8-24 16:48 | 显示全部楼层 |阅读模式
在UCOS II V2.86之后多了一些功能函数,请问
类似这个函数:
#if OS_TASK_NAME_SIZE > 13
    OSTaskNameSet(APP_TASK_START_PRIO, "Start Task", &err);
#endif
是什么意思?
 楼主| pigeon0411 发表于 2009-8-24 16:52 | 显示全部楼层
不知道大家用UCOS用的多不
 楼主| pigeon0411 发表于 2009-8-24 16:57 | 显示全部楼层
/*$PAGE*/
*                                        ASSIGN A NAME TO A TASK
* Description: This function is used to set the name of a task.
* Arguments  : prio      is the priority of the task that you want the assign a name to.
*              pname     is a pointer to an ASCII string that contains the name of the task.  The ASCII
*                        string must be NUL terminated.
*              perr       is a pointer to an error code that can contain one of the following values:
*                        OS_ERR_NONE                if the requested task is resumed
*                        OS_ERR_TASK_NOT_EXIST      if the task has not been created or is assigned to a Mutex
*                        OS_ERR_TASK_NAME_TOO_LONG  if the name you are giving to the task exceeds the
*                                                   storage capacity of a task name as specified by
*                                                   OS_TASK_NAME_SIZE.
*                        OS_ERR_PNAME_NULL          You passed a NULL pointer for 'pname'
*                        OS_ERR_PRIO_INVALID        if you specified an invalid priority:
*                                                   A higher value than the idle task or not OS_PRIO_SELF.
*                        OS_ERR_NAME_SET_ISR        if you called this function from an ISR
* Returns    : None
字面意思明白,但还是没明白设置任务名有什么实际意义。
 楼主| pigeon0411 发表于 2009-8-24 17:02 | 显示全部楼层
[quote][/quote]
  1. :sleepy:[url][img][/img][/url]
lvpengandy 发表于 2011-5-15 22:30 | 显示全部楼层
就是给任务命名。没有什么太大的用处。
