我配置为其他的了,但是不可以用,uart2和uart0除了引脚配置不同,还有别的不同吗?配置程序如下,麻烦帮我看看,谢谢!
void SYS_Init(void)
/* Init System Clock */
/* Unlock protected registers */
SYS_UnlockReg();
/* Enable External XTAL (4~24 MHz) */
CLK->PWRCTL |= CLK_PWRCTL_HXTEN_Msk; // XTAL12M (HXT) Enabled
/* Waiting for 12MHz clock ready */
CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
/* Switch HCLK clock source to HXT */
CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT,CLK_CLKDIV0_HCLK(1));
/* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
CLK->PLLCTL |= CLK_PLLCTL_PD_Msk;
/* Set PLL frequency */
CLK->PLLCTL = CLK_PLLCTL_84MHz_HXT;
/* Waiting for clock ready */
CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
/* Switch HCLK clock source to PLL */
CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL,CLK_CLKDIV0_HCLK(1));
/* Enable IP clock */
// CLK_EnableModuleClock(UART0_MODULE);
CLK_EnableModuleClock(UART2_MODULE);
/* Select IP clock source */
// CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
CLK_SetModuleClock(UART2_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
/* Update System Core Clock */
/* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
SystemCoreClockUpdate();
/* Init I/O Multi-function */
/* Set PG multi-function pins for UART0 RXD, TXD */
SYS->GPA_MFPH = SYS_GPA_MFPH_PA13MFP_UART0_RXD | SYS_GPA_MFPH_PA14MFP_UART0_TXD ;
/* Set GPC multi-function pins for UART2 RXD and TXD */
SYS->GPC_MFPH = SYS_GPC_MFPH_PC10MFP_UART2_RXD | SYS_GPC_MFPH_PC11MFP_UART2_TXD ;
/* Set PB multi-function pins for UART1 RXD, TXD, RTS and CTS */
SYS->GPD_MFPL = SYS_GPD_MFPL_PD4MFP_UART3_RXD | SYS_GPD_MFPL_PD5MFP_UART3_TXD;
/* Lock protected registers */
SYS_LockReg();
/* MAIN function */
int main (void)
int i;
/* Init System, IP clock and multi-function I/O
In the end of SYS_Init() will issue SYS_LockReg()
to lock protected register. If user want to write
protected register, please issue SYS_UnlockReg()
to unlock protected register if necessary */
SYS_Init();
/* Init UART to 115200-8n1 for print message */
UART_Open(UART2, 115200);
// UART_Open(UART0, 115200);
// printf("\n\nCPU @ %dHz\n", SystemCoreClock);
printf("+-------------------------------------+ \n");
printf("| GPIO Driver Sample Code | \n");
