[STM32F3] STM32F303-如何解析GPS数据
3225|4
 楼主| Bermanrep 发表于 2016-1-31 16:03 | 显示全部楼层 |阅读模式
实现步骤如下:
1.初始化usart3:
  1. #define UART3_TX_BUF_SIZE        1*128
  2. #define UART3_RX_BUF_SIZE        512
  1. unsigned char Uart1TxBuf[UART1_TX_BUF_SIZE]={0};                /* com1_rf发送缓冲区 */
  2. unsigned char Uart1RxBuf[UART1_RX_BUF_SIZE]={0};                /* com1_rf接收缓冲区 */
  3. unsigned char Uart3TxBuf[UART3_TX_BUF_SIZE]={0};                /* com3_发送缓冲区 */
  4. unsigned char Uart3RxBuf[UART3_RX_BUF_SIZE]={0};                /* com3_接收缓冲区 */
  5. bool Uart1RxBuf_full =false;
  6. bool Uart3RxBuf_full =false;
  1. void USART3_Init(u32 Baudrate)
  3.   USART_InitTypeDef  USART_InitStructure;
  4.   GPIO_InitTypeDef   GPIO_InitStructure;
  5.
  6.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
  7.
  8.   RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  9.
  10.   //这里USART3映射到PC10和PC11是部分映射,没有映射时时端口是PB10和PB11,
  11.   //完全映射时(GPIO_FullRemap_USART3)是PD8和PD9 (但是64引脚没有引出PD8和PD9)
  12.   GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);// I/O口重映射开启.
  13.
  14.   /*Remap Pc10 USART3.TX推挽输出*/
  15.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  16.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  17.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  18.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  19.
  20.   /*remap Pc11 USART3.RX浮空输入 */
  21.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  22.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  23.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  24.   USART_InitStructure.USART_BaudRate = Baudrate;
  25.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  26.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
  27.   USART_InitStructure.USART_Parity = USART_Parity_No;
  28.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  29.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  30.   USART_Init(USART3, &USART_InitStructure);
  31.
  32.   USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//接收中断使能
  33.   USART_Cmd(USART3, ENABLE);
  34. }
 楼主| Bermanrep 发表于 2016-1-31 16:04 | 显示全部楼层
2.写带fifo缓冲区的串口中断:
  1. void  USART3_IRQHandler(void)
  3.     static u16 RxCount;
  4.
  5.   if(USART_GetFlagStatus(USART3,USART_IT_RXNE)==SET)
  6.   {
  7.     USART_ClearITPendingBit(USART3,USART_IT_RXNE);//清除中断标志
  8.
  9.      Uart3RxBuf[RxCount] = USART_ReceiveData(USART3);
  10.        RxCount++; // must not change it !
  11.
  12.       if (RxCount >= UART3_RX_BUF_SIZE) //
  13.        {
  14.          RxCount=0;
  15.          Uart3RxBuf_full = true;
  16.        }
  17.   }
  18. }
  1. 3.从缓冲区中提取有效数据:
  1. /*
  2. *********************************************************************************************************
  3. *        函 数 名: gps_pro
  4. *        功能说明:  从串口缓冲区中解析出GPS数据包。插入到主程序中执行即可。分析结果存放在全局变量 myGPS
  5. *        形    参:  无
  6. *        返 回 值: 无
  7. *********************************************************************************************************
  8. */
  9. void gps_pro(void)
  10. {
  11.     uint16_t i=0;
  12.
  13.     char *p,*pt;
  14.                 if (Uart3RxBuf_full)
  15.                    {
  16.                     USART_ITConfig(USART3, USART_IT_RXNE, DISABLE); //禁止接收中断
  17.
  18.                     Uart3RxBuf_full = false;
  19.
  20.                 //LCD_print_0816Num(3, 5,  1 ,0);//debug
  21.                     p = (char *)Uart3RxBuf;
  22.                     pt = strchr(p, '
  23. 4. 解析语义:
  24. [code]void GPS_Data_update()
  25. {
  26.
  27.     char * start_p = GpsBuf;
  28.     char *pos_p;
  29.    /*
  30.    int strncmp(const char *string1, const char *string2, size_t count);
  31.    比较字符串string1和string2大小,只比较前面count个字符. 比较过程中,
  32.    任何一个字符串的长度小于count, 则count将被较短的字符串的长度取代.
  33.    此时如果两串前面的字符都相等, 则较短的串要小.
  34.    返回值< 0, 表示string1的子串小于string2的子串;
  35.    返回值为0, 表示string1的子串等于string2的子串;
  36.    返回值> 0, 表示string1的子串大于string2的子串.
  37.    */
  38.   if(strncmp(GpsBuf, "$GPGGA",6)==0)
  39.   {
  40.    //ShowStringPos (0, 4,"$GPGGA"); //bebug
  41.
  42.         /*字段1 :UTC 时间,hhmmss.sss,时分秒格式 */
  43.         pos_p = strchr(start_p, ','); //查找字符串s中首次出现字符c的位置,剥离c前面的信息
  44.         if (pos_p == 0)
  45.         {
  46.             return;//2个逗号连在一起的情况
  47.         }
  48.     pos_p++;  // p+1后指向UTC时间
  49.     myGPS.Hour = StrToIntFix(pos_p, 2);
  50.         pos_p += 2;
  51.         myGPS.Min = StrToIntFix(pos_p, 2);
  52.         pos_p += 2;
  53.         myGPS.Sec = StrToIntFix(pos_p, 2);
  54.          //微秒忽略
  55.
  56.      /* 字段2 :纬度ddmm.mmmm,度分格式(前导位数不足则补0)*/
  57.      pos_p = strchr(pos_p, ','); //接着刚才指针位置找下一个逗号
  58.         if (pos_p == 0)
  59.         {
  60.            return;
  61.         }
  62.         pos_p++;
  63.
  64.         myGPS.WeiDu_Du = StrToIntFix(pos_p, 2);
  65.         pos_p += 2;
  66.         myGPS.WeiDu_Fen = StrToIntFix(pos_p, 2) * 10000;
  67.         pos_p += 3;
  68.         myGPS.WeiDu_Fen += StrToIntFix(pos_p, 4);
  69.
  70.         /* 字段3 :N(北纬)或S(南纬) */
  71.         pos_p = strchr(pos_p, ',');
  72.         if (pos_p == 0)
  73.         {
  74.                 return;
  75.         }
  76.         pos_p++;
  77.         if (*pos_p == 'S')
  78.         {
  79.                 myGPS.NS = 'S';
  80.         }
  81.         else if (*pos_p == 'N')
  82.         {
  83.                 myGPS.NS = 'N';
  84.         }
  85.         else
  86.         {
  87.                 return;
  88.         }
  89.
  90.     /* 字段4 :经度dddmm.mmmm,度分格式(前导位数不足则补0) */
  91.         pos_p = strchr(pos_p, ',');
  92.         if (pos_p == 0)
  93.         {
  94.                 return;
  95.         }
  96.         pos_p++;
  97.         myGPS.JingDu_Du = StrToIntFix(pos_p, 3);
  98.         pos_p += 3;
  99.         myGPS.JingDu_Fen = StrToIntFix(pos_p, 2) * 10000;
  100.         pos_p += 3;
  101.         myGPS.JingDu_Fen += StrToIntFix(pos_p, 4);
  102.
  103.         /* 字段5 :E(东经)或W(西经) */
  104.         pos_p = strchr(pos_p, ',');
  105.         if (pos_p == 0)
  106.         {
  107.                 return;
  108.         }
  109.         pos_p++;
  110.         if (*pos_p == 'E')
  111.         {
  112.                 myGPS.EW = 'E';
  113.         }
  114.         else if (*pos_p == 'W')
  115.         {
  116.                 myGPS.EW = 'W';
  117.         }
  118.
  119.         /* 字段6 :GPS状态,0=未定位,1=非差分定位,2=差分定位,3=无效PPS,6=正在估算 */
  120.         pos_p = strchr(pos_p, ',');
  121.         if (pos_p == 0)
  122.         {
  123.                 return;
  124.         }
  125.         pos_p++;
  126.         if ((*pos_p == '1') || (*pos_p == '2'))
  127.         {
  128.                 myGPS.PositionOk = 1;
  129.         }
  130.         else
  131.         {
  132.                 myGPS.PositionOk = 0;
  133.         }
  134.
  135.           /* 字段7:正在使用的卫星数量(00 - 12)(前导位数不足则补0) */
  136.                 pos_p = strchr(pos_p, ',');
  137.                 if (pos_p == 0)
  138.                 {
  139.                         return;
  140.                 }
  141.                 pos_p++;
  142.                 myGPS.ViewNumber = StrToInt(pos_p);
  143.
  144.                 //p += 2;
  145.
  146.                 /* 字段8:HDOP水平精度因子(0.5 - 99.9) */
  147.                 pos_p = strchr(pos_p, ',');
  148.                 if (pos_p == 0)
  149.                 {
  150.                         return;
  151.                 }
  152.                 pos_p++;
  153.                 myGPS.HDOP = StrToInt(pos_p);
  154.
  155.                 /* 字段9:海拔高度(-9999.9 - 99999.9) */
  156.                 pos_p= strchr(pos_p, ',');
  157.                 if (pos_p == 0)
  158.                 {
  159.                         return;
  160.                 }
  161.                 pos_p++;
  162.                 myGPS.Altitude = StrToInt(pos_p);
  163.         //后面的,39.5,M,-15.5,M,6.8,0000*68 丢弃
  164.
  165.
  166.   }
  167.
  168.   //if(strncmp(GpsBuf, "$GPRMC",6)==0)
  169.   //{
  170.    //ShowStringPos (0, 4,"$GPRMC"); //bebug
  171.   //}
  172.
  173. }
 楼主| Bermanrep 发表于 2016-1-31 16:05 | 显示全部楼层
5.运行:
在RTOS中用一个或两个任务执行   gps_pro(); GPS_Data_update();
在main函数中用while(1){gps_pro(); GPS_Data_update();}
  1. ); //P指向了该位置,在字符串中查找字符$第一次出现的位置
  2.                     for(i=0;i<GPS_BUFF_SIZE;i++)
  3.                     {
  4.                       GpsBuf = Uart3RxBuf[pt-p+i];  //以$开头的字符串
  5.                     }
  6.
  7.                 printf("%s\r\n",GpsBuf);/* 将收到的GPS模块数据按原样 打印到COM1口,便于跟踪调试 */
  8.
  9.                     USART_ITConfig(USART3, USART_IT_RXNE, ENABLE); //使能接收中断
  10.
  11.
  12.         }
  13.
  14. }
4. 解析语义:
  1. void GPS_Data_update()
  4.     char * start_p = GpsBuf;
  5.     char *pos_p;
  6.    /*
  7.    int strncmp(const char *string1, const char *string2, size_t count);
  8.    比较字符串string1和string2大小,只比较前面count个字符. 比较过程中,
  9.    任何一个字符串的长度小于count, 则count将被较短的字符串的长度取代.
  10.    此时如果两串前面的字符都相等, 则较短的串要小.
  11.    返回值< 0, 表示string1的子串小于string2的子串;
  12.    返回值为0, 表示string1的子串等于string2的子串;
  13.    返回值> 0, 表示string1的子串大于string2的子串.
  14.    */
  15.   if(strncmp(GpsBuf, "$GPGGA",6)==0)
  16.   {
  17.    //ShowStringPos (0, 4,"$GPGGA"); //bebug
  18.
  19.         /*字段1 :UTC 时间,hhmmss.sss,时分秒格式 */
  20.         pos_p = strchr(start_p, ','); //查找字符串s中首次出现字符c的位置,剥离c前面的信息
  21.         if (pos_p == 0)
  22.         {
  23.             return;//2个逗号连在一起的情况
  24.         }
  25.     pos_p++;  // p+1后指向UTC时间
  26.     myGPS.Hour = StrToIntFix(pos_p, 2);
  27.         pos_p += 2;
  28.         myGPS.Min = StrToIntFix(pos_p, 2);
  29.         pos_p += 2;
  30.         myGPS.Sec = StrToIntFix(pos_p, 2);
  31.          //微秒忽略
  32.
  33.      /* 字段2 :纬度ddmm.mmmm,度分格式(前导位数不足则补0)*/
  34.      pos_p = strchr(pos_p, ','); //接着刚才指针位置找下一个逗号
  35.         if (pos_p == 0)
  36.         {
  37.            return;
  38.         }
  39.         pos_p++;
  40.
  41.         myGPS.WeiDu_Du = StrToIntFix(pos_p, 2);
  42.         pos_p += 2;
  43.         myGPS.WeiDu_Fen = StrToIntFix(pos_p, 2) * 10000;
  44.         pos_p += 3;
  45.         myGPS.WeiDu_Fen += StrToIntFix(pos_p, 4);
  46.
  47.         /* 字段3 :N(北纬)或S(南纬) */
  48.         pos_p = strchr(pos_p, ',');
  49.         if (pos_p == 0)
  50.         {
  51.                 return;
  52.         }
  53.         pos_p++;
  54.         if (*pos_p == 'S')
  55.         {
  56.                 myGPS.NS = 'S';
  57.         }
  58.         else if (*pos_p == 'N')
  59.         {
  60.                 myGPS.NS = 'N';
  61.         }
  62.         else
  63.         {
  64.                 return;
  65.         }
  66.
  67.     /* 字段4 :经度dddmm.mmmm,度分格式(前导位数不足则补0) */
  68.         pos_p = strchr(pos_p, ',');
  69.         if (pos_p == 0)
  70.         {
  71.                 return;
  72.         }
  73.         pos_p++;
  74.         myGPS.JingDu_Du = StrToIntFix(pos_p, 3);
  75.         pos_p += 3;
  76.         myGPS.JingDu_Fen = StrToIntFix(pos_p, 2) * 10000;
  77.         pos_p += 3;
  78.         myGPS.JingDu_Fen += StrToIntFix(pos_p, 4);
  79.
  80.         /* 字段5 :E(东经)或W(西经) */
  81.         pos_p = strchr(pos_p, ',');
  82.         if (pos_p == 0)
  83.         {
  84.                 return;
  85.         }
  86.         pos_p++;
  87.         if (*pos_p == 'E')
  88.         {
  89.                 myGPS.EW = 'E';
  90.         }
  91.         else if (*pos_p == 'W')
  92.         {
  93.                 myGPS.EW = 'W';
  94.         }
  95.
  96.         /* 字段6 :GPS状态,0=未定位,1=非差分定位,2=差分定位,3=无效PPS,6=正在估算 */
  97.         pos_p = strchr(pos_p, ',');
  98.         if (pos_p == 0)
  99.         {
  100.                 return;
  101.         }
  102.         pos_p++;
  103.         if ((*pos_p == '1') || (*pos_p == '2'))
  104.         {
  105.                 myGPS.PositionOk = 1;
  106.         }
  107.         else
  108.         {
  109.                 myGPS.PositionOk = 0;
  110.         }
  111.
  112.           /* 字段7:正在使用的卫星数量(00 - 12)(前导位数不足则补0) */
  113.                 pos_p = strchr(pos_p, ',');
  114.                 if (pos_p == 0)
  115.                 {
  116.                         return;
  117.                 }
  118.                 pos_p++;
  119.                 myGPS.ViewNumber = StrToInt(pos_p);
  120.
  121.                 //p += 2;
  122.
  123.                 /* 字段8:HDOP水平精度因子(0.5 - 99.9) */
  124.                 pos_p = strchr(pos_p, ',');
  125.                 if (pos_p == 0)
  126.                 {
  127.                         return;
  128.                 }
  129.                 pos_p++;
  130.                 myGPS.HDOP = StrToInt(pos_p);
  131.
  132.                 /* 字段9:海拔高度(-9999.9 - 99999.9) */
  133.                 pos_p= strchr(pos_p, ',');
  134.                 if (pos_p == 0)
  135.                 {
  136.                         return;
  137.                 }
  138.                 pos_p++;
  139.                 myGPS.Altitude = StrToInt(pos_p);
  140.         //后面的,39.5,M,-15.5,M,6.8,0000*68 丢弃
  141.
  142.
  143.   }
  144.
  145.   //if(strncmp(GpsBuf, "$GPRMC",6)==0)
  146.   //{
  147.    //ShowStringPos (0, 4,"$GPRMC"); //bebug
  148.   //}
  149.
  150. }
5.运行:
wangagt 发表于 2016-9-23 11:31 | 显示全部楼层
您好,我手里有stm32 和 sim808 ,想实现上电自动取 GPS信息,发送到指定的ip上去。楼主这个程序能共享一下吗?多谢多谢wangagt 163邮箱
