请教关于用DSPBIOS配置文件后出现这样的错误怎么解决?
3425|0
 楼主| nealfei 发表于 2009-8-30 22:11 | 显示全部楼层 |阅读模式
[Configuration1cfg.s54] "C:\ti\C5400\cgtools\bin\cl500" -g -fr"C:/ti/MyProjects/FLMS/Debug" -d"_DEBUG" [email=-@]-@"Debug.lkf[/email]" "Configuration1cfg.s54" "Configuration1cfg.s54", ERROR! at line 283: [ ***** USER ERROR ***** - ] Project build options do not match Global configuration settings. Compiler options specify near model, configuration set for far model. .emsg "Project build options do not match Global configuration settings. Compiler options specify near model, configuration set for far model." 1 bottomembly Error, No bottomembly Warnings Errors in Source - bottomembler Aborted >> Compilation failure
谢谢那位老师可以指点指点!
