供应hp rp2405 rp2430 rp2470
1748|0
xxjpj2009|  楼主 | 2009-9-9 10:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hp, TE, ST, AN, mb
公司提供小型机、服务器、工作站、存储设备、外设、CPU 内存 硬盘 电源 存储设备 控制卡 升级选件、维修配件(HP、IBM、EMC)等
联系人:李先生    联系电话:010-88147562
A-Class Base Unit           A5182-69201 Incl. Chassis, Backplane, Processor,
                     Power Supply, Fans
1MB L2 Cache Upgrade        A5187A      no Partnr. available 11.11.98
++ I/O SYSTEM A180: ++++++++++++
Remote Management Card      A3262-69311 Access Port
PCI FW SCSI card            A4800-69002     l  port fast wide ultra1
PCI FW SCSI card            A5159-69001 dual   port fast wide ultra1
HSC 100BaseT card           J3516-69004 dual port
HSC FW SCSI card            A2874-69006 BlueFish
A400/A500/rp24x0
Crescendo Sys. Board Rev. B A5570-69316 A400/A500 Revsion B  A5570B/A6109B
                                        run ss_update before use as A500
                                        old RevA board A5570-69001 non orderable
(order VDETester for power supply, fan assy or system board replacement: NHP%VDE0701)
Crescendo GSP (Tosca)       A5570-69002 A400/A500     (Maestro not supported on Crescendo)
Harmony System Board        A6889-69101 rp2430/rp2470
Harmony GSP (Maestro)       A6889-69102 rp2430/rp2470 (Tosca not supported on Harmony)
Power-Supply                A5570-69009 A400/A500
CPU PA8600 440MHz           A5571-69001 A400/A500 (Crescendo)
CPU PA8600 550MHz           A6148-69001 A500      (Crescendo)
CPU PA8700 650MHz           A6891-69001 rp2430/rp2470 (Harmony)
CPU PA8700 750MHz           A6892-69001 rp2470        (Harmony)
Harmony CPU FAN Controller  A6889-62005 Service Note A6889A-09A/A6890A-09A
Runwaybus Terminator        A5570-62014 Crescendo (same Part as in L-1000/L2000)
Runwaybus Terminator        A6889-67003 Harmony
Power System:
Power-Supply                A5570-69009 A400/A500/rp2430/rp2470
DC-DC Converter - Master    0950-3821   A400/A500/rp2430/rp2470
DC-DC Converter - Slave     0950-3822   A400/A500/rp2430/rp2470
PCI I/O Backplane           A5570-66003 A400/A500
Disk Media Backplane        A5570-66004 A400/A500
Disk Media Backplane        A6889-67004 Harmony
Secure Web Console PCA      A5858-70001 A400/A500 PCI Card A5858A
Serial Cable for A5858A     A5858-63001 A400/A500  for connecting the PCI webconsole card to
                                                  the W-cable
***A5858-63001 ist nicht bestellbar -> The A5858-63001 is a straight-thru cable with a db9 female connector on one end and a db9 male
on the other -> ERSATZ: C2932A***
W-Cable Console/UPS/remote  A5191-63001 A400/A500 (gray) for Crescendo (Tosca GSP)
M-Cable Console/UPS/remote  A6144-63001 A400/A500 (black) for Harmony (Maestro GSP)
Disk Ribbon Cable           A5570-63001 A400/A500
Top Cover Assy              A5570-67007 A400/A500
P/S Shroud w/ Fans/LED      A5570-00001 A400/A500 all five FANs
++ MEMORY SYSTEM +++++++++++
64MB SIMM                  A2580-69001 (128MB module) ONLY A180!
128MB SIMM                  A3398-69014 (256MB module) ONLY A180!
256MB SIMM                  A3737-69001 (512MB module) ONLY A180!
128MB DIMM                  A5572-69001 A400/A500
256MB DIMM                  A5840-69101 A400/A500 This mistakenly appears as 512MB on the part page! it is definitely a 256MB.
512MB DIMM                  A5841-69001 A400/A500
1024MB DIMM                 A6114-69001 A400/A
500
A180:
4 GB SE SCSI, Seagate       A3352-69003
9 GB SE SCSI, Seagate       A4912-69001 ST39173N or ST39175LW
9 GB SE SCSI, Seagate       A5806-69002 ST39175LW
18GB SE SCSI, Seagate       A5560-69001
Adapter for 18GB Disk       5182-4551   A180
rp24x0:
9GB Disk Drive              A5505-69001 (hot-plug) ST39102LC, ST39103LC, ST39104LC
18GB Disk Drive             A5531-69003 (hot-plug) ST318203LC, ST318404LC
36GB Disk Drive             A6089-69001 (hot-plug) ST336704LC
18GB Ultra 160 SCSI 10k     A6741-69002 (hot-plug) MAN3184MC, ST318406LC
18GB Ultra 160 SCSI 15k     A6947-69001 (hot-plug) MAM3184MC
36GB Ultra 160 SCSI 10k     A6742-69002 (hot-plug) MAN3367MC, ST336706LC
36GB Ultra 320 SCSI 15k     A6948-69002 (hot-plug) MAM3367MC, ST336753LC
73GB Ultra 160 SCSI 10k     A6804-69002 (hot-plug) ST373405LC, MAN3735MC
73GB Ultra 320 SCSI 15k     A8706-69001 (hot-plug) ST373453LC (Product: A9759A)
external Smart DDS-3        C6364-69004 Product nr. C6364A
external Smart 12x CD-ROM   C4310-60017 Product nr. C4310A
++ Secure Web Console J3591A unter WEB-CONSOLE
A400/A500 Electronic Document CD       A5570-10001
