hp rp5405 rp5430 rp5470
1821|0
 楼主| xxjpj2009 发表于 2009-9-10 09:33 | 显示全部楼层 |阅读模式
L1000, L1500, L2000, L3000  => rp54x0
++ PROCESSOR Module
CPU, 360MHZ                   A5521-69001       L1000A/B & L2000A/B
CPU, 440MHZ                   A5522-69001       L1000A/B & L2000A/B
CPU, 540MHZ / 550MHz          A6146-69001 L1000B & L2000B (540MHz), L1500B & L3000A/B (550MHz)
CPU, 650MHz (Piranha CPU)     A6798-69001       L1500B & L3000B
CPU, 750MHz (Piranha CPU)     A6805-69001       L1500B & L3000B #if part not available, A6805-69002 maybe used (check min. PDC!)
CPU, 750MHz (Payara CPU)      A6805-69002       L1500B & L3000B, PDC>=42.19 #if part not available, A6805-69001 maybe used
CPU, 875MHz (Payara CPU)      A6152-69001       L1500B & L3000B, PDC>=42.19
Processor Terminator          A5570-62014       see Service Note A5191A-14
                                                (same Part as in A-Class systems)
CPU Socket                    1253-0703         just the single CPU-sockets
Cleaning Kit                  A3639-70101       contains: 4 CPU Chip Sockets, 4 thermstrate pads, 4 EMI O-rings, 1 IPA wipe & cleaning manual
++ To replace a CPU, order: ++
CPU
Vacuum-cleaner               1150-5071
Cable for vacuum-cleaner     5184-0874
++ SYSTEM BOARDS +++++++++++
L1000/2000 System Board Rev. B   A5191
-69116
L3000 System Board               A6144
-69101
L1500/3000 Sys Bd Rev. B         A6797-69101  (old:) A6797-69001 rp5430/5470
LAN/SCSI CARD                    A5191-69211    ex A5191-69111 (siehe S/N A5576A-14)
GSP Card (Tosca, old)            A5191-69112
GSP Card (Maestro) A6144-69112    old PN: A6144-69012
                                                        (use-till-gone)
!!! if Tosca GSP is replaced by Maestro, order also:
M-Cable                          A6144-63001    (for Maestro GSP only)
see: http://wtec.cup.hp.com/~cpuhw/hppa/GSP/gsp.htm
128 MB MEMORY DIMM           A5554-69002
256 MB MEMORY DIMM           A5797-69101
512 MB MEMORY DIMM           A5798-69001
!!! Two types of 1 GB Dimms exists which must not be mixed in one pair. !!!
!!! Order both types or two Dimms. See also Service Note A5191A-23      !!!
1024 MB MEMORY DIMM           A6115-69001 EDC <  A-4052
1024 MB MEMORY DIMM           A6115-69002 EDC >= A-4052 SN A5191A-23
Memory Extender               A6155-69001 L1500 & L3000 only !!!
Processor Support Module     A3639-69012    360, 440, 550MHz (2.0V)
Processor Support Module     A3639-69033    only for 650MHz and 750MHz (1.6V)
POWER SUPPLY                 A5527-69001
Power Converter              A5191-69105
Platform Monitor             A5191-69210
Power Harness Cable          A6144-63004
Power-Cord EUR Black         8120-5336      2,5m C15/CEE-7 Schukostecker
Power-Cord PDU/L-Class       8120-6358     0,7m Jumpercable C14/C15 M/F
Power-Cord PDU/L-Class       8120-8848     2,5m Jumpercable C14/C15 M/F
++ Internals disk are the same as in SC10, but with other Product Numbers, order
++ SC10 disks only if below disks are unavailable
++ see disks=>enclosure=>A5272A
9GB HotPlug Disk             A5802-69003   ST39103LC ST39204LC A5802A
9GB HotPlug Disk             A5276-69002   according to GSL this is an alt. part # to A5802-69003
18GB HotPlug Disk            A5803-69003   ST318404LC, ST118202LC, ST318203LC, Fujitsu MAJ3182MC A5803A
18GB HotPlug Ultra160 Disk   A6736-69001
36GB HotPlug Disk            A6110-69003   ST336704LC, ST136403LC, Fujitsu MAJ3364MC A6119A
36GB HotPlug Disk 10K        A6737-69002   Quantum U160 MAN3367MC
36GB HotPlug U160 Disk 15k   A6846-69002   ST336753LC, MAM3367MC
73GB HotPlug      Disk 10K   A6091-69001   ST173404LC
73GB HotPlug U160 Disk 10K   A6738-69002   ATLAS10K3_73_SCA, MAN3735MC U160
73GB HotPlug Ultra320 15k    A9761-69001   ST373453LC
146GB HotPlug Ultra320 10k   A7080-69002   ST3146807LC (???)
Embedded DVD                 A5220-67003
Embedded 12GB DDS            C1537-69202
PCI I/O Backplane      A5191-69102  L1000 L2000
PCI I/O Backplane A6144-69102  L1500 L3000
HS Chassis Fan                A5191-04002  (fan# 0, 1)
HS Card Cage Fan              A5191-04003  (fan# 2, 3, 4, 5)
HS Pwr Conv Fan               A5191-67006  (fan# 6, 7)
Fuse, SMT, 3A, 125V            1400-1776     (fuse for Fan0 and Fan1 only on L1500 & L3000)
For CD-ROM / DDS Drives in the SMART Rack look under SMART PRODUCTS **
Console-UPS-Modem-Cable  (W-Cable, Tosca)   A5191-63001  (gray, for old GSP-boards)
Console-UPS-Modem-Cable  (M-Cable, Maestro) A6144-63001  (black, for new GSP-boards)
Console cable                   24542G
Disk/Media Bkpln                            A5191-67104
Display Board                               A5191-60013  (includes Power Switch)
PCI Bkpln to Disk/Media ribbon cable        A5191-63004
PCI Bkpln to Disk/Media power cable         A5191-63003
DVD to Disk/Media PWR. - Cable              A5191-63002
DVD to Disk/Media SCSI - Cable              A5191-63008
DDS to Disk/Media PWR. - Cable              A5191-63013
DDS to Disk/Media SCSI - Cable              A5191-63014
LAN/SCSI to Disk/Media SCSI - Cable J5      A5191-63007  (rem. Media)
LAN/SCSI to Disk/Media SCSI - Cable J6      A5191-63006  (SCSI bus B, 0/0/1/1)
LAN/SCSI to Disk/Media SCSI - Cable J7      A5191-63005  (SCSI bus A, 0/0/2/0)
Disk Filler Panel                           A5236-40024
Rear Chassis fan cable                      A5191-63009
Front Chassis fan cable                     A5191-63010
Front Bezel Assembly  (center hinge)        A5191-04008
One piece Front Bezel (new model numbers)   A5191-04013
One piece Front Bezel hardware kit          A5191-70010
