msp430 iar软仿真的问题,怎么不进串口中断?
3992|0
jiaojian|  楼主 | 2009-9-22 09:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
刚接触msp430 2132程序如下就是 TI的例程改了一下用IAR软仿真:
//   MSP430F21x2 Demo - USCI_A0, Ultra-Low Pwr UART 9600 String, 32kHz ACLK
//   Description: This program demonstrates a full-duplex 9600-baud UART using
//   USCI_A0 and a 32kHz crystal.  The program will wait in LPM3, and will
//   respond to a received 'u' character using 8N1 protocol. The response will
//   be the string 'Hello World'.
//   ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.2MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//   //* An external watch crystal is required on XIN XOUT for ACLK *//
//                MSP430F21x2
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P3.4/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P3.5/UCA0RXD|<------------
//   A. Dannenberg
//   Texas Instruments Inc.
//   October 2006
//   Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include  "msp430x21x2.h"
const char string1[] = { "Hello World\r\n" };
unsigned int i;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR = 0xFF;                             // All P1.x outputs
  P1OUT = 0;                                // All P1.x reset
  P2DIR = 0xFF;                             // All P2.x outputs
  P2OUT = 0;                                // All P2.x reset
  P3SEL = 0x30;                             // P3.4,5 = USCI_A0 TXD/RXD
  P3DIR = 0xFF;                             // All P3.x outputs
  P3OUT = 0;                                // All P3.x reset
  UCA0CTL1 |= UCSSEL_1;                     // CLK = ACLK
  UCA0BR0 = 0x03;                           // 32kHz/9600 = 3.41
  UCA0BR1 = 0x00;                           //
  UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(GIE);
  //__bis_SR_register(LPM3_bits + GIE);       // Enter LPM3 w/ int until Byte RXed
  IE2 |= UCA0TXIE;                        // Enable USCI_A0 TX interrupt
  UCA0TXBUF = string1[i++];
  while(1);
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
  UCA0TXBUF = string1[i++];                 // TX next character//断点就设在这里怎么不进入呢我在main里已经从串口发东西了呀?
  if (i == sizeof string1 - 1)              // TX over?
    IE2 &= ~UCA0TXIE;                       // Disable USCI_A0 TX interrupt
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  if (UCA0RXBUF == 'u')                     // 'u' received?
    i = 0;
断点设在串口发送中断里软仿真不停在断点上 为什么 谢谢
