将McBSP用作SPI,发送数据有问题,不知道怎么回事?
2082|6
 楼主| thf2008 发表于 2009-9-22 14:56 | 显示全部楼层 |阅读模式
我将McBSP用作SPI功能,我的数据长度是8位,发送一个1,本来应该一个时钟周期为高电平,可是我输出的确是三到四个时钟周期,不知道是我哪设置错了?
这是我的McBSP的初始化程序:
void InitMcbsp(void)
        EALLOW;
        GpioMuxRegs.GPFMUX.all = 0xFF00;
    EDIS;
        McbspaRegs.SPCR2.bit.XRST = 0;                // Reset FS generator, sample rate generator & transmitter
    McbspaRegs.SPCR1.bit.RRST = 0;                // Reset Receiver, Right justify word,clock stop mode, without clock
    for(d=0;d<100;d++)
    McbspaRegs.SPCR2.bit.GRST = 0;
    McbspaRegs.SPCR1.bit.CLKSTP = 2;
        McbspaRegs.PCR1.bit.CLKXP = 0;
        McbspaRegs.PCR1.bit.CLKRP = 1;
        McbspaRegs.PCR1.bit.SCLKME = 0;     //the clock generated by the sample rate generator is derived form the cpu clock                                            // The Mcbsp is a master in the SPI protocol
    McbspaRegs.SRGR2.bit.CLKSM = 1;                // CLKSM=1 (If SCLKME=0, i/p clock to SRG is LSPCLK)
        McbspaRegs.SRGR1.bit.CLKGDV = 2;
    McbspaRegs.PCR1.bit.FSXM = 1;                // FSX generated internally, FSR derived from an external source
    McbspaRegs.SRGR2.bit.FSGM = 0;
    McbspaRegs.PCR1.bit.FSXP = 1;
    McbspaRegs.XCR2.bit.XDATDLY=1;
    McbspaRegs.RCR2.bit.RDATDLY=1;
    McbspaRegs.SPCR1.bit.RJUST = 0;
        McbspaRegs.PCR1.bit.CLKXM =1;
        McbspaRegs.XCR2.bit.XPHASE = 0;
        McbspaRegs.RCR2.bit.RPHASE =0;
        McbspaRegs.XCR1.bit.XFRLEN1 = 0;
        McbspaRegs.RCR1.bit.RFRLEN1 = 0;
        McbspaRegs.XCR1.bit.XWDLEN1 = 0;
        McbspaRegs.RCR1.bit.RWDLEN1 = 0;
    McbspaRegs.SPCR2.bit.GRST=1; // Enable the sample rate generator
    for(d=0;d<100;d++)
    McbspaRegs.SPCR2.bit.XRST=1; // Release TX from Reset
    McbspaRegs.SPCR1.bit.RRST=1; // Release RX from Reset
    McbspaRegs.SPCR2.bit.FRST=1; // Frame Sync Generator reset
这是我用示波器测得数据输出端得波形和时钟端得输出波形
 楼主| thf2008 发表于 2009-9-22 14:58 | 显示全部楼层
希望做过的人指点一下
 楼主| thf2008 发表于 2009-9-23 01:44 | 显示全部楼层
没有人这么用过的吗?
还是问题太简单了?
 楼主| thf2008 发表于 2009-9-23 15:52 | 显示全部楼层
没人这么用过吗?
lobby 发表于 2009-9-23 16:11 | 显示全部楼层
不是太简单
而是确实没用过
帮顶
