STM32 I2C的问题
2925|0
 楼主| jjl3 发表于 2009-9-24 21:44 | 显示全部楼层 |阅读模式
void I2C_EE_ByteWrite(unsigned short int WriteAddr, unsigned char pBuffer)
  /* Send STRAT condition */
  I2C1_CR1             |= 0x0100;
  /* Test on EV5 and clear it */
  while(!(I2C1_SR1 & 0x0001));
  /* Send EEPROM address for write */
  I2C1_DR               = I2C_SLAVE_ADDRESS7_Write;
  /* Test on EV6 and clear it */
  while((!(I2C1_SR1 & 0x0002)) || (I2C1_SR2 & 0x0000));
  /* Send the EEPROM's internal address to write to : MSB of the address first */
  I2C1_DR               = (unsigned char)((WriteAddr & 0xFF00) >> 8);
  /* Test on EV8 and clear it */
  while(!(I2C1_SR1 & 0x0080) || (I2C1_SR2 & 0x0000));
  /* Send the EEPROM's internal address to write to : LSB of the address */
  I2C1_DR               = (unsigned char)(WriteAddr & 0x00FF);
  while(!(I2C1_SR1 & 0x0080));
  /* Send the byte to be written */
  I2C1_DR               = pBuffer;
  /* Send STOP condition */
  I2C1_CR1             |= 0x0200;
unsigned char I2C_EE_ByteRead(unsigned short int ReadAddr)
    /* While the bus is busy */
  while(I2C1_SR2 & 0x0002);
  /* Send START condition */
  I2C1_CR1             |= 0x0100;
  while(!(I2C1_SR1 & 0x0002) || (I2C1_SR2 & 0x0000));
  /* Clear EV6 by setting again the PE bit */
  I2C1_CR1             |= 0x0001;
  /* Send the EEPROM's internal address to read from: MSB of the address first */
  I2C1_DR               = (unsigned char)((ReadAddr & 0xFF00) >> 8);
  /* Send the EEPROM's internal address to read from: LSB of the address */
  I2C1_DR               = (unsigned char)(ReadAddr & 0x00FF);
  /* Send STRAT condition a second time */
  I2C1_CR1             |= 0x0100;
  /* Send EEPROM address for read */
  I2C1_DR               = I2C_SLAVE_ADDRESS7_Read;
  /* While there is data to be read */
  /* Disable Acknowledgement */
  I2C1_CR1             &= 0xFBFF;
  /* Send STOP Condition */
  I2C1_CR1             |= 0x0200;
  return I2C1_DR;
在调试时,单步运行这两个函数可以运行通过,但run起来就老是死在某哦个while处,请大家帮忙看看这两个函数有什么问题?
