msp430与GPRS模块的连接例程
1058|9
 楼主| dirtwillfly 发表于 2016-2-13 21:02 | 显示全部楼层 |阅读模式
硬件电路:
2. #include <msp430x14x.h>
3. #include “string.h”
4.
5.  typedef unsigned short int    u16
6.  typedef unsigned char       u8
7.
typedef signed short int      s16
8.  typedef signed char         s8
9.
10.  #define SYS_SUCCESS    0
11.  #define SYS_FAIL          1
12. //==============================================================
13.  // DTU Pin define
14.  #define DTU_IGT_PORT_DIR      P1DIR
15.  #define DTU_IGT_PORT_OUT     P1OUT
16.  #define DTU_IGT_PIN             BIT6
17.
18.  #define DTU_RTS_PORT_DIR      P1DIR
19.  #define DTU_RTS_PORT_OUT     P1OUT
20.  #define DTU_RTS_PIN             BIT2
21.
22.  #define DTU_CTS_PORT_DIR      P1DIR
23.  #define DTU_CTS_PORT_IN       P1IN
24.  #define DTU_CTS_PIN             BIT4
25.
26.  #define DTU_IGT_FIRE      DTU_IGT_PORT_DIR  |= DTU_IGT_PIN;\
27.                             DTU_IGT_PORT_OUT  |= DTU_IGT_PIN
28.  #define DTU_IGT_SHUT     DTU_IGT_PORT_DIR  |= DTU_IGT_PIN;\
29.                             DTU_IGT_PORT_OUT  &= ~DTU_IGT_PIN
30.  #define DTU_RTS_HIGH     DTU_RTS_PORT_DIR |= DTU_RTS_PIN;\
31.                             DTU_RTS_PORT_OUT |= DTU_RTS_PIN
32.  #define DTU_RTS_LOW     DTU_RTS_PORT_DIR |= DTU_RTS_PIN;\
33.                             DTU_RTS_PORT_OUT &=~DTU_RTS_PIN
34.  #define DTU_CTS_FLAG    DTU_CTS_PORT_DIR &= ~ DTU_CTS_PIN
35.  #DTU_CTS                 (DTU_CTS_PORT_IN & DTU_CTS_PIN)
36.
37.  #define DTU_DAT_LEN    100
38.
39.  u8 g_rec_buf[DTU_DAT_LEN]
40.  u16 g_count = 0
41.  u8 g_sys_error = SYS_SUCCESS
42.
43.  /***********************************************************************************************
44.  ** Function Name : Delay                                                  **
45.  ** Parameter     : uTime                                                  **
46.   ** Return     :
47.   ********************************************************************************************/
48.   void Delay(u16 uTime)
49.   {
50.       u16 i=0;
51.       u16 j=0;
52.       for (i = 0  I < 1000; i++)
53.       {
54.            for (j = 0; j < uTime; j++);
55.       }
56.   }
57.
58.  /***********************************************************************************************
59.  ** Function Name : InitClock                                                **
60.  ** Parameter     : None                                                  **
61.  ** Return        :                                                        **
62.  ***********************************************************************************************/
63.   void InitClock()
64.   {
65.       u8 i= 0;
66.
67.       BCSCTL1 &= ~XT2OFF;
68.       BCSCTL2 |= SELM1+SELS;       // MCLK 8M, SMCLK 1M
69.
70.       do
71.       {
72.           IFG1 &= ~OFIFG;
73.           for (i = 0; I < 100; i++)
74.           {
75.               _NOP();
76.           }
77.       } while(0 != (IFG1 & OFIFG));
78.       IFG1 &= ~OFIFG;
79.   }
80.
81. /***********************************************************************************************
82.  ** Function Name : InitUart1                                                **
83.  ** Parameter     : None                                                  **
84.  ** Return        :                                                        **
85.  ***********************************************************************************************/
86.  void InitUart1(void)
87.  {
88.      U1CTL |= SWRST;    // Rest UART1
89.      U1CTL |= CHAR;     // 8 bit data
90.      U1TCTL |= SSEL1; // set SMCLK as uart1 clock
91.      UBR01 = 0x8A;  // Baud rate 19200bps
92.      UBR11 = 0x00;
93.
94.      UMCTL1 = 0xDE;
95.      ME2 |= 0x30;
96.      uctl1 &= ~SWRST;  //
97.
98.      IE2 |= URXIE1;
99.      P3SEL = 0XC0; // P3.6 and P3.7 as TXD and RXD
100.      P3DIR = 0x40;
101.  }
102.
103.  ***********************************************************************************************
104.  ** Function Name : UART1_RX_ISR                                        **
105.  ** Parameter     : None                                                  **
106.  ** Return        :                                                       **
107.  **********************************************************************************************/
108.  #pragma vector = UART1RX_VECTOR
109.  __interrupt void UART1_RX_ISR(void)
110.  {
111.      char dat = 0
112.      data = U1RXBUF
113.      g_rec_buf[g_count] = data
114.      if (g_count > (DTU_DAT_LEN -1))
115.      {
116.          g_count = 0;
117.      }
118.  }
119.
120.  ***********************************************************************************************
121.  ** Function Name : Uart1SendByte                                         **
122.  ** Parameter     : u8 dat                                                 **
123.  ** Return        :                                                       **
124.  **********************************************************************************************/
125.   void Uart1SendByte(u8 dat)
126.   {
127.       while(0 == (IFG2 & UTXIFG1);
128.       U1TXBUF = dat;
129.   }
130.
131.   *********************************************************************************************
132.  ** Function Name : ClearDtuBuf                                            **
133.  ** Parameter     :                                                       **
134.  ** Return        :                                                       **
135.  **********************************************************************************************/
136.   void ClearDtuBuf(void)
137.   {
138.       u8 len = 0;
139.       g_count = 0;
140.
141.       IE2 &= ~URXIE1; // Close receive interrupt
142.       for (; len < DTU_DAT_LEN; len++)
143.       {
144.           g_rec_buf[len] = „\0‟
145.       }
146.       IE2 |= URXIE1;
147.   }
148.
149.   void SendDat(s8 * strptr)
150.   { 151.       u8 i.j;
152.       j = strlen(strptr);
153.       for (i=0;i<j;i++)
154.       {
155.           Uart1SendByte((u8)strptr[i]);
156.       }
157.   }
158.   *********************************************************************************************
159.  **  DTU MODULE: Start, Shut, Initialize
160.  **********************************************************************************************/
161.   void StartDtu(void)
162.   {
163.       DTU_IGT_FIRE;
164.       Delay(1);
165.       DTU_IGT_SHUT;
166.       Delay(100);
167.       DTU_IGT_FIRE;
168.   }
169.
170.  void ShutdownDtu(void)
171.   {
172.       Delay(100);
173.       SendDat(“AT^smso\r\n”);
174.       Delay(100);
175.   }
176.
177.  void InitDtu(void)
178.   {
179.       SendDat(“AT\\Q3\r\n”);
180.       Delay(1000);
181.       SendDat(“ATE0\r\n”);
182.       Delay(100);
183.       SendDat(“AT+CMGF=1\r\n”);
184.       Delay(100);
185.       SendDat(“AT+CFUN=7\r\n”);
186.       Delay(100);
187.       SendDat(“AT+CFUN\?\r\n”);
188.       Delay(100);
189.   }
190.
191.  void SendDtuMsg(char *num, char * msg)
192.  {
193.      char instruct[] = “AT+CMGS=\””;
194.      char numinstuct[27];
195.
196.      strcpy(numinstuct, instruct);
197.      strcat(numinstuct, num);
198.      strcat(numinstuct, “\”\r\n”);
199.      SendDat(numinstuct);
200.      SendDat(msg);
201.      Uart1SendByte(0x1A);   // CTRL+Z
202.
203.  }
204.
205.  void main()
206.  {
207.     WDTCTL = WDTPW + WDTHOLD; // close WATCH DOG
208.     InitClock(); 209.     InitUart1();
210.     DTU_RTS_LOW
211.
212.     StartDtu()
213.     _EINT()
214.     Delay(2000)
215.     InitDtu()
216.
217.     SendDat(“AT\r\n“)
218.     SendDtuMsg ( ”18615771975”, ”Hello world! Just a Test!”);
219.     CloseDtu();
220.
221.     while(1)
222.      {
223.      }
224.  }
225.
lvyunhua 发表于 2016-2-13 23:51 | 显示全部楼层
不错,学习了。
android2 发表于 2016-2-14 20:47 | 显示全部楼层
感谢分享
vivilzb1985 发表于 2016-2-16 14:06 | 显示全部楼层
这个主要是通过UART口的通讯实现的。
chuntian2016 发表于 2016-2-16 17:51 | 显示全部楼层
这个主要是通过UART口来进行数据的交互的。
wanyisq 发表于 2016-2-17 10:16 | 显示全部楼层
就是没有实现检测AT指令返回,如果返回不正确,发下一条AT指令也没用的
shenmu2012 发表于 2016-2-18 14:18 | 显示全部楼层
2. #include
注意这些AT指令的用法即可的。
firstblood 发表于 2016-2-18 16:28 | 显示全部楼层
这个主要也是看相关的AT指令的应用了
comeon201208 发表于 2016-2-18 21:17 | 显示全部楼层
注意相关的AT指令及延时的长短的。
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1200
