基于msp430的cc1100应用程序
893|2
 楼主| dirtwillfly 发表于 2016-2-15 21:37 | 显示全部楼层 |阅读模式
#include<msp430x14x.h>
#define INT8U unsigned char
#define        INT16U unsigned int
#define WRITE_BURST 0x40        //连续写入
#define BYTES_IN_RXFIFO  0x7F          //接收缓冲区的有效字节数
#define CRC_OK      0x80         //CRC校验通过位标志
//无线模块引脚定义
#define GDO0 P3DIR &= ~BIT1          //GDO0
#define MISO P3DIR &= ~BIT3          //MISO
#define SCK1 P3OUT |= BIT4;           //SCK=1
#define SCK0 P3OUT &= ~BIT4;          //SCK=0
#define MOSI1 P3OUT |= BIT5;          //MOSI=1
#define MOSI0 P3OUT &= ~BIT5;         //MOSI=0
//18B20引脚定义
#define DQ1 P1OUT |= BIT6
#define DQ0 P1OUT &= ~BIT6
#define DQ_in   P1DIR &= ~BIT6
#define DQ_out  P1DIR |= BIT6
#define DQ_val  (P1IN & BIT6)
//1602液晶引脚定义
#define DataDir     P4DIR
#define DataPort    P4OUT
#define Busy            0x80
#define CtrlDir     P5DIR
#define CLR_RS P5OUT&=~BIT0;    //RS = P5.0
#define SET_RS P5OUT|=BIT0;
#define CLR_RW P5OUT&=~BIT1;        //RW = P5.1
#define SET_RW P5OUT|=BIT1;
#define CLR_EN P5OUT&=~BIT2;        //EN = P5.2
#define SET_EN P5OUT|=BIT2;
#define dl P3OUT &=~ BIT7;    //灯亮
#define dm P3OUT |= BIT7;     //灯灭
#define   Num_of_Results   32
INT8U RxBuf[8]={0};
INT8U TxBuf[8]={1,2,3,4,5,6,7,8};         // 8字节, 如果需要更长的数据包,请正确设置
INT8U leng =0;
INT8U a,b,ptr[4];
INT8U dN[10]={0,1,2,3,4,5,6,7,8,9};
INT8U shuzi[] = {"0123456789."};
INT8U scandata[10] = {0xc0,0xcf,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
//INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};
INT8U PaTabel[8] = {0xc0 ,0xc0 ,0xc0 ,0xc0 ,0xc0 ,0xc0 ,0xc0 ,0xc0};//修改发射功率
void SpiInit(void);
void CpuInit(void);
void RESET_CC1100(void);
void POWER_UP_RESET_CC1100(void);
void halSpiWriteReg(INT8U addr, INT8U value);
void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count);
void halSpiStrobe(INT8U strobe);
INT8U halSpiReadReg(INT8U addr);
void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count);
INT8U halSpiReadStatus(INT8U addr);
void halRfWriteRfSettings(void);
void halRfSendPacket(INT8U *txBuffer, INT8U size);
INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length);
// CC1100 STROBE, CONTROL AND STATUS REGSITER
#define CCxxx0_IOCFG2       0x00        // GDO2 output pin configuration
#define CCxxx0_IOCFG1       0x01        // GDO1 output pin configuration
#define CCxxx0_IOCFG0       0x02        // GDO0 output pin configuration
#define CCxxx0_FIFOTHR      0x03        // RX FIFO and TX FIFO thresholds
#define CCxxx0_SYNC1        0x04        // Sync word, high INT8U
#define CCxxx0_SYNC0        0x05        // Sync word, low INT8U
#define CCxxx0_PKTLEN       0x06        // Packet length
#define CCxxx0_PKTCTRL1     0x07        // Packet automation control
#define CCxxx0_PKTCTRL0     0x08        // Packet automation control
#define CCxxx0_ADDR         0x09        // Device address
#define CCxxx0_CHANNR       0x0A        // Channel number
#define CCxxx0_FSCTRL1      0x0B        // Frequency synthesizer control
#define CCxxx0_FSCTRL0      0x0C        // Frequency synthesizer control
#define CCxxx0_FREQ2        0x0D        // Frequency control word, high INT8U
#define CCxxx0_FREQ1        0x0E        // Frequency control word, middle INT8U
#define CCxxx0_FREQ0        0x0F        // Frequency control word, low INT8U
#define CCxxx0_MDMCFG4      0x10        // Modem configuration
#define CCxxx0_MDMCFG3      0x11        // Modem configuration
#define CCxxx0_MDMCFG2      0x12        // Modem configuration
#define CCxxx0_RCCTRL1      0x27        // RC oscillator configuration
#define CCxxx0_RCCTRL0      0x28        // RC oscillator configuration
#define CCxxx0_FSTEST       0x29        // Frequency synthesizer calibration control
#define CCxxx0_PTEST        0x2A        // Production test
#define CCxxx0_AGCTEST      0x2B        // AGC test
#define CCxxx0_TEST2        0x2C        // Various test settings
#define CCxxx0_TEST1        0x2D        // Various test settings
#define CCxxx0_TEST0        0x2E        // Various test settings
// Strobe commands
#define CCxxx0_SRES         0x30        // Reset chip.
#define CCxxx0_SFSTXON      0x31        // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
                                        // If in RX/TX: Go to a wait state where only the synthesizer is
                                        // running (for quick RX / TX turnaround).
#define CCxxx0_SXOFF        0x32        // Turn off crystal oscillator.
#define CCxxx0_SCAL         0x33        // Calibrate frequency synthesizer and turn it off
                                        // (enables quick start).
#define CCxxx0_SRX          0x34        // Enable RX. Perform calibration first if coming from IDLE and
                                        // MCSM0.FS_AUTOCAL=1.
#define CCxxx0_STX          0x35        // In IDLE state: Enable TX. Perform calibration first if
                                        // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
                                        // Only go to TX if channel is clear.
#define CCxxx0_SIDLE        0x36        // Exit RX / TX, turn off frequency synthesizer and exit
                                        // Wake-On-Radio mode if applicable.
#define CCxxx0_SAFC         0x37        // Perform AFC adjustment of the frequency synthesizer
#define CCxxx0_SWOR         0x38        // Start automatic RX polling sequence (Wake-on-Radio)
#define CCxxx0_SPWD         0x39        // Enter power down mode when CSn goes high.
#define CCxxx0_SFRX         0x3A        // Flush the RX FIFO buffer.
#define CCxxx0_SFTX         0x3B        // Flush the TX FIFO buffer.
#define CCxxx0_SWORRST      0x3C        // Reset real time clock.
#define CCxxx0_SNOP         0x3D        // No operation. May be used to pad strobe commands to two
                                        // INT8Us for simpler software.
#define CCxxx0_PARTNUM      0x30
#define CCxxx0_VERSION      0x31
#define CCxxx0_FREQEST      0x32
#define CCxxx0_LQI          0x33
#define CCxxx0_RSSI         0x34
#define CCxxx0_MARCSTATE    0x35
#define CCxxx0_WORTIME1     0x36
#define CCxxx0_WORTIME0     0x37
#define CCxxx0_PKTSTATUS    0x38
#define CCxxx0_VCO_VC_DAC   0x39
#define CCxxx0_TXBYTES      0x3A
#define CCxxx0_RXBYTES      0x3B
#define CCxxx0_PATABLE      0x3E
#define CCxxx0_TXFIFO       0x3F
#define CCxxx0_RXFIFO       0x3F
// RF_SETTINGS is a data structure which contains all relevant CCxxx0 registers
typedef struct S_RF_SETTINGS
    INT8U FSCTRL2;   //自已加的
    INT8U FSCTRL1;   // Frequency synthesizer control.
    INT8U FSCTRL0;   // Frequency synthesizer control.
    INT8U FREQ2;     // Frequency control word, high INT8U.
    INT8U FREQ1;     // Frequency control word, middle INT8U.
    INT8U FREQ0;     // Frequency control word, low INT8U.
    INT8U MDMCFG4;   // Modem configuration.
    INT8U MDMCFG3;   // Modem configuration.
    INT8U MDMCFG2;   // Modem configuration.
    INT8U MDMCFG1;   // Modem configuration.
    INT8U MDMCFG0;   // Modem configuration.
    INT8U CHANNR;    // Channel number.
    INT8U DEVIATN;   // Modem deviation setting (when FSK modulation is enabled).
    INT8U FREND1;    // Front end RX configuration.
    INT8U FREND0;    // Front end RX configuration.
    INT8U MCSM0;     // Main Radio Control State Machine configuration.
    INT8U FOCCFG;    // Frequency Offset Compensation Configuration.
    INT8U BSCFG;     // Bit synchronization Configuration.
    INT8U AGCCTRL2;  // AGC control.
    INT8U AGCCTRL1;  // AGC control.
    INT8U AGCCTRL0;  // AGC control.
    INT8U FSCAL3;    // Frequency synthesizer calibration.
    INT8U FSCAL2;    // Frequency synthesizer calibration.
    INT8U FSCAL1;    // Frequency synthesizer calibration.
    INT8U FSCAL0;    // Frequency synthesizer calibration.
    INT8U FSTEST;    // Frequency synthesizer calibration control
    INT8U TEST2;     // Various test settings.
    INT8U TEST1;     // Various test settings.
    INT8U TEST0;     // Various test settings.
    INT8U IOCFG2;    // GDO2 output pin configuration
    INT8U IOCFG0;    // GDO0 output pin configuration
    INT8U PKTCTRL1;  // Packet automation control.
    INT8U PKTCTRL0;  // Packet automation control.
    INT8U ADDR;      // Device address.
    INT8U PKTLEN;    // Packet length.
} RF_SETTINGS;
const RF_SETTINGS rfSettings =
    0x00,
    0x08,   // FSCTRL1   Frequency synthesizer control.
    0x00,   // FSCTRL0   Frequency synthesizer control.
    0x10,   // FREQ2     Frequency control word, high byte.
    0xA7,   // FREQ1     Frequency control word, middle byte.
    0x62,   // FREQ0     Frequency control word, low byte.
    0x5B,   // MDMCFG4   Modem configuration.
        //0xf6,        // MDMCFG4 chang by allen
    0xF8,   // MDMCFG3   Modem configuration.
        //0x83,        // MDMCFG3 chang by allen   data rate = 2.398K
    0x03,   // MDMCFG2   Modem configuration.
    0x22,   // MDMCFG1   Modem configuration.
    0xF8,   // MDMCFG0   Modem configuration.
    0x00,   // CHANNR    Channel number.
    0x47,   // DEVIATN   Modem deviation setting (when FSK modulation is enabled).
    0xB6,   // FREND1    Front end RX configuration.
    0x10,   // FREND0    Front end RX configuration.
    0x18,   // MCSM0     Main Radio Control State Machine configuration.
    0x1D,   // FOCCFG    Frequency Offset Compensation Configuration.
    0x1C,   // BSCFG     Bit synchronization Configuration.
    0xC7,   // AGCCTRL2  AGC control.
    0x00,   // AGCCTRL1  AGC control.
    0xB2,   // AGCCTRL0  AGC control.
    0xEA,   // FSCAL3    Frequency synthesizer calibration.
    0x2A,   // FSCAL2    Frequency synthesizer calibration.
    0x00,   // FSCAL1    Frequency synthesizer calibration.
    0x11,   // FSCAL0    Frequency synthesizer calibration.
    0x59,   // FSTEST    Frequency synthesizer calibration.
    0x81,   // TEST2     Various test settings.
    0x35,   // TEST1     Various test settings.
    0x09,   // TEST0     Various test settings.
    0x0B,   // IOCFG2    GDO2 output pin configuration.
    0x06,   // IOCFG0D   GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation.
    0x04,   // PKTCTRL1  Packet automation control.
    //0x05,   // PKTCTRL0  Packet automation control.
    0x01,        //PKTCTRL0  crc disable chang by allen at 09.12.24
    0x00,   // ADDR      Device address.
    0x0c    // PKTLEN    Packet length.
void Disp_Numb();
//操作18B20温度传感器
函数名称:DelayNus
功    能:实现N个微秒的延时
参    数:n--延时长度
返回值  :无
说明    :定时器A的计数时钟是1MHz,CPU主频8MHz
          所以通过定时器延时能够得到极为精确的
          us级延时
void DelayNus(INT16U n)
    CCR0 = n;
    TACTL |= MC_1;           //增计数到CCR0
    while(!(TACTL & BIT0));   //等待
    TACTL &= ~MC_1;          //停止计数
    TACTL &= ~BIT0;          //清除中断标志
函数名称:Init_18B20
功    能:对DS18B20进行复位操作
参    数:无
返回值  :初始化状态标志:1--失败,0--成功
INT8U Init_18B20(void)
    INT8U Error;
    DQ_out;
    _DINT();
    DQ0;
    DelayNus(500);
    DQ1;
    DelayNus(55);
    DQ_in;
    _NOP();
    if(DQ_val)
        Error = 1;          //初始化失败
    else
        Error = 0;          //初始化成功
    DQ_out;
    DQ1;
    _EINT();
    DelayNus(400);
    return Error;
函数名称:Write_18B20
功    能:向DS18B20写入一个字节的数据
参    数:wdata--写入的数据
返回值  :无
void Write_18B20(INT8U wdata)
    INT8U i;
    _DINT();
    for(i = 0; i < 8;i++)
        DQ0;
        DelayNus(6);            //延时6us
        if(wdata & 0X01)    DQ1;
        else                DQ0;
        wdata >>= 1;
        DelayNus(50);           //延时50us
        DQ1;
        DelayNus(10);           //延时10us
    _EINT();
函数名称:Read_18B20
功    能:从DS18B20读取一个字节的数据
参    数:无
返回值  :读出的一个字节数据
INT8U Read_18B20(void)
    INT8U i;
    INT8U temp = 0;
    _DINT();
    for(i = 0;i < 8;i++)
        temp >>= 1;
        DQ0;
        DQ1;
        DelayNus(8);            //延时9us
        DQ_in;
        _NOP();
        if(DQ_val)   temp |= 0x80;
        DelayNus(45);           //延时45us
        DQ_out;
        DQ1;
    _EINT();
    return  temp;
函数名称:Skip
功    能:发送跳过读取产品ID号命令
参    数:无
返回值  :无
void Skip(void)
    Write_18B20(0xcc);
函数名称:Convert
功    能:发送温度转换命令
参    数:无
返回值  :无
void Convert(void)
    Write_18B20(0x44);
函数名称:Read_SP
功    能:发送读ScratchPad命令
参    数:无
返回值  :无
void Read_SP(void)
    Write_18B20(0xbe);
函数名称:ReadTemp
功    能:从DS18B20的ScratchPad读取温度转换结果
参    数:无
返回值  :读取的温度数值
INT16U ReadTemp(void)
    INT8U temp_low;
    INT16U  temp;
    temp_low = Read_18B20();      //读低位
    temp = Read_18B20();     //读高位
    temp = (temp<<8) | temp_low;
    return  temp;
函数名称:ReadTemp
功    能:控制DS18B20完成一次温度转换
参    数:无
返回值  :测量的温度数值
INT16U Do1Convert(void)
    INT8U i;
    do
        i = Init_18B20();
    while(i);
    Skip();
    Convert();
    for(i = 20;i > 0;i--)
        DelayNus(60000); //延时800ms以上
    do
        i = Init_18B20();
    while(i);
    Skip();
    Read_SP();
    return ReadTemp();
//写1602液晶
函数名称:DispStr
功    能:让液晶从某个位置起连续显示一个字符串
参    数:x--位置的列坐标
          y--位置的行坐标
          ptr--指向字符串存放位置的指针
返回值  :无
void Disp1Char(INT8U x,INT8U y,INT8U data);
void DispStr(INT8U x,INT8U y,INT8U *ptr)
    INT8U *temp;
    INT8U i,n = 0;
    temp = ptr;
    while(*ptr++ != '\0')   n++;    //计算字符串有效字符的个数
    for (i=0;i<n;i++)
        Disp1Char(x++,y,temp[i]);
        if (x == 0x0f)
           x  = 0;
           y ^= 1;
函数名称:DispNchar
功    能:让液晶从某个位置起连续显示N个字符
参    数:x--位置的列坐标
          y--位置的行坐标
          n--字符个数
          ptr--指向字符存放位置的指针
返回值  :无
void DispNChar(INT8U x,INT8U y, INT8U n,INT8U *ptr)
    INT8U i;
    for (i=0;i<n;i++)
        Disp1Char(x++,y,ptr[i]);
        if (x == 0x0f)
           x = 0;
        y ^= 1;
函数名称:LocateXY
功    能:向液晶输入显示字符位置的坐标信息
参    数:x--位置的列坐标
          y--位置的行坐标
返回值  :无
void LcdWriteCommand(INT8U cmd,INT8U chk);
void LocateXY(INT8U x,INT8U y)
    INT8U temp;
    temp = x&0x0f;
    y &= 0x01;
    if(y)   temp |= 0x40;  //如果在第2行
    temp |= 0x80;
    LcdWriteCommand(temp,1);
函数名称:Disp1Char
功    能:在某个位置显示一个字符
参    数:x--位置的列坐标
          y--位置的行坐标
          data--显示的字符数据
返回值  :无
void LcdWriteData( INT8U data );
    LocateXY( x, y );
    LcdWriteData( data );
函数名称:LcdReset
功    能:对1602液晶模块进行复位操作
参    数:无
返回值  :无
void delay_5ms(void);
void LcdReset(void)
    CtrlDir |= 0x07;                 //控制线端口设为输出状态
    DataDir  = 0xFF;                 //数据端口设为输出状态
    LcdWriteCommand(0x38, 0);            //规定的复位操作
    delay_5ms();
    delay_5ms();
    delay_5ms();
    LcdWriteCommand(0x38, 1);                //显示模式设置
    LcdWriteCommand(0x08, 1);                //显示关闭
    LcdWriteCommand(0x01, 1);            //显示清屏
    LcdWriteCommand(0x06, 1);                //写字符时整体不移动
    LcdWriteCommand(0x0c, 1);                //显示开,不开游标,不闪烁
函数名称:LcdWriteCommand
功    能:向液晶模块写入命令
参    数:cmd--命令,
          chk--是否判忙的标志,1:判忙,0:不判
返回值  :无
void WaitForEnable(void);
    if (chk) WaitForEnable();   // 检测忙信号?
    CLR_RS;
    CLR_RW;
    _NOP();
    DataPort = cmd;             //将命令字写入数据端口
    _NOP();
    SET_EN;                     //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
函数名称:LcdWriteData
功    能:向液晶显示的当前地址写入显示数据
参    数:data--显示字符数据
返回值  :无
    WaitForEnable();        //等待液晶不忙
    SET_RS;
    CLR_RW;
    _NOP();
    DataPort = data;        //将显示数据写入数据端口
    _NOP();
    SET_EN;                 //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
函数名称:WaitForEnable
功    能:等待1602液晶完成内部操作
参    数:无
返回值  :无
    P4DIR &= 0x00;  //将P4口切换为输入状态
    CLR_RS;
    SET_RW;
    _NOP();
    SET_EN;
    _NOP();
    _NOP();
    while((P4IN & Busy)!=0);  //检测忙标志
    CLR_EN;
    P4DIR |= 0xFF;  //将P4口切换为输出状态
函数名称:Delay5ms
功    能:延时约5ms
参    数:无
返回值  :无
    INT16U i=40000;
    while (i != 0)
        i--;
//操作无线模块
//函数名:delay(unsigned int s)
//输入:时间
//输出:无
//功能描述:普通廷时,内部用
static void delay(unsigned int s)
        unsigned int i;
        for(i=0; i<s; i++);
        for(i=0; i<s; i++);
void yanshi(INT16U z)//延时10us
        INT16U x,y;
        for(x=z;x>0;x--)
                for(y=1;y>0;y--);
void yanshi1(INT16U z)//延时13us
        INT16U x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void halWait(INT16U timeout)
    do {
          yanshi(1);
       } while (--timeout);
void SpiInit(void)
        CSN0;//CSN=0
        SCK0;//SCK=0
        CSN1;//CSN=1
//函数名:CpuInit()
//输入:无
//输出:无
//功能描述:SPI初始化程序
void CpuInit(void)
        SpiInit();
        delay(1000);
//函数名:SpisendByte(INT8U dat)
//输入:发送的数据
//输出:无
//功能描述:SPI发送一个字节
INT8U SpiTxRxByte(INT8U dat)
        INT8U i,temp;
        temp = 0;
        SCK0;//SCK = 0
        for(i=0; i<8; i++)
                if(dat & 0x80)
                     MOSI1;//MOSI = 1
                else MOSI0;//MOSI = 0
                dat <<= 1;
                SCK1; //SCK = 1
                yanshi(1);
                temp <<= 1;
                MISO;
                if((P3IN & BIT3)==BIT3/*MISO*/)temp++;
                SCK0;//SCK = 0
                yanshi(1);
        return temp;
//函数名:void RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:复位CC1100
        CSN0; //CSN = 0
        MISO;
        while ((P3IN & BIT3)==BIT3/*MISO*/);
        SpiTxRxByte(CCxxx0_SRES);                 //写入复位命令
        MISO;
        CSN1;//CSN = 1
//函数名:void POWER_UP_RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:上电复位CC1100
        CSN1; //CSN = 1
        halWait(1);
        CSN0; //CSN = 0
        halWait(1);
        CSN1; //CSN = 1
        halWait(10);
        RESET_CC1100();                   //复位CC1100
//函数名:void halSpiWriteReg(INT8U addr, INT8U value)
//输入:地址和配置字
//输出:无
//功能描述:SPI写寄存器
    CSN0; //CSN = 0
    MISO;
    SpiTxRxByte(addr);                //写地址
    SpiTxRxByte(value);                //写入配置
    CSN1; //CSN = 1
//函数名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//输入:地址,写入缓冲区,写入个数
//输出:无
//功能描述:SPI连续写配置寄存器
    INT8U i, temp;
    temp = addr | WRITE_BURST;
    CSN0; //CSN = 0
    MISO;
    SpiTxRxByte(temp);
    for (i = 0; i < count; i++)
        SpiTxRxByte(buffer[i]);
    CSN1; //CSN = 1
//函数名:void halSpiStrobe(INT8U strobe)
//输入:命令
//输出:无
//功能描述:SPI写命令
    CSN0; //CSN = 0
    MISO;
    SpiTxRxByte(strobe);                //写入命令
    CSN1; //CSN = 1
//函数名:INT8U halSpiReadReg(INT8U addr)
//输入:地址
//输出:该寄存器的配置字
//功能描述:SPI读寄存器
        INT8U temp, value;
        temp = addr|READ_SINGLE;//读寄存器命令
        CSN0; //CSN = 0
        MISO;
        SpiTxRxByte(temp);
        value = SpiTxRxByte(0);
        CSN1; //CSN = 1
        return value;
//函数名:void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//输入:地址,读出数据后暂存的缓冲区,读出配置个数
//输出:无
//功能描述:SPI连续写配置寄存器
    INT8U i,temp;
    temp = addr | READ_BURST;                //写入要读的配置寄存器地址和读命令
    CSN0; //CSN = 0
    MISO;
    SpiTxRxByte(temp);
        buffer[i] = SpiTxRxByte(0);
    CSN1; //CSN = 1
//输入:地址
//输出:该状态寄存器当前值
//功能描述:SPI读状态寄存器
    INT8U value,temp;
    temp = addr | READ_BURST;                //写入要读的状态寄存器的地址同时写入读命令
    CSN0; //CSN = 0
    MISO;
    SpiTxRxByte(temp);
    CSN1; //CSN = 1
    return value;
//函数名:void halRfWriteRfSettings(RF_SETTINGS *pRfSettings)
//输入:无
//输出:无
//功能描述:配置CC1100的寄存器
    halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL2);//自已加的
    // Write register settings
    halSpiWriteReg(CCxxx0_FSCTRL1,  rfSettings.FSCTRL1);
    halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL0);
    halSpiWriteReg(CCxxx0_FREQ2,    rfSettings.FREQ2);
    halSpiWriteReg(CCxxx0_FREQ1,    rfSettings.FREQ1);
    halSpiWriteReg(CCxxx0_FREQ0,    rfSettings.FREQ0);
    halSpiWriteReg(CCxxx0_MDMCFG4,  rfSettings.MDMCFG4);
    halSpiWriteReg(CCxxx0_MDMCFG3,  rfSettings.MDMCFG3);
    halSpiWriteReg(CCxxx0_MDMCFG2,  rfSettings.MDMCFG2);
    halSpiWriteReg(CCxxx0_MDMCFG1,  rfSettings.MDMCFG1);
    halSpiWriteReg(CCxxx0_MDMCFG0,  rfSettings.MDMCFG0);
    halSpiWriteReg(CCxxx0_CHANNR,   rfSettings.CHANNR);
    halSpiWriteReg(CCxxx0_DEVIATN,  rfSettings.DEVIATN);
    halSpiWriteReg(CCxxx0_FREND1,   rfSettings.FREND1);
    halSpiWriteReg(CCxxx0_FREND0,   rfSettings.FREND0);
    halSpiWriteReg(CCxxx0_MCSM0 ,   rfSettings.MCSM0 );
    halSpiWriteReg(CCxxx0_FOCCFG,   rfSettings.FOCCFG);
    halSpiWriteReg(CCxxx0_BSCFG,    rfSettings.BSCFG);
    halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
    halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
    halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
    halSpiWriteReg(CCxxx0_FSCAL3,   rfSettings.FSCAL3);
    halSpiWriteReg(CCxxx0_FSCAL2,   rfSettings.FSCAL2);
    halSpiWriteReg(CCxxx0_FSCAL1,   rfSettings.FSCAL1);
    halSpiWriteReg(CCxxx0_FSCAL0,   rfSettings.FSCAL0);
    halSpiWriteReg(CCxxx0_FSTEST,   rfSettings.FSTEST);
    halSpiWriteReg(CCxxx0_TEST2,    rfSettings.TEST2);
    halSpiWriteReg(CCxxx0_TEST1,    rfSettings.TEST1);
    halSpiWriteReg(CCxxx0_TEST0,    rfSettings.TEST0);
    halSpiWriteReg(CCxxx0_IOCFG2,   rfSettings.IOCFG2);
    halSpiWriteReg(CCxxx0_IOCFG0,   rfSettings.IOCFG0);
    halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
    halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
    halSpiWriteReg(CCxxx0_ADDR,     rfSettings.ADDR);
    halSpiWriteReg(CCxxx0_PKTLEN,   rfSettings.PKTLEN);
//函数名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
//输入:发送的缓冲区,发送数据个数
//输出:无
//功能描述:CC1100发送一组数据
    halSpiWriteReg(CCxxx0_TXFIFO, size);
    halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size);        //写入要发送的数据
    halSpiStrobe(CCxxx0_STX);                //进入发送模式发送数据
    GDO0;
    while ((P3IN & BIT1)!=BIT1/*!GDO0*/);
    while ((P3IN & BIT1)==BIT1/*GDO0*/);
    halSpiStrobe(CCxxx0_SFTX);
    delay(5);
void setRxMode(void)
    halSpiStrobe(CCxxx0_SRX);                //进入接收状态
    INT8U packetLength;
    INT8U i=(*length)*4;  // 具体多少要根据datarate和length来决定
        delay(1);
        GDO0;
                delay(1);
                --i;
                if(i<1)
                   return 0;
    if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字节数不为0
                packetLength = halSpiReadReg(CCxxx0_RXFIFO);//读出第一个字节,此字节为该帧数据长度
                if(packetLength == 0x08)
                        halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, 8); //读出所有接收到的数据
                        *length = packetLength;                                //把接收数据长度的修改为当前数据的长度
                        halSpiStrobe(CCxxx0_SFRX);                //清洗接收缓冲区
                        return 1;
                 else
                   return 0;
        return 0;
void main(void)
        WDTCTL = WDTPW + WDTHOLD;
        //进入程序之前先关闭所有的I/O口置0
        P1DIR = 0XFF;P1OUT = 0Xff;
        P2DIR = 0XFF;P2OUT = 0X00;
        P3DIR = 0XFF;P3OUT = 0X00;
        P4DIR = 0XFF;P4OUT = 0X00;
        P5DIR = 0XFF;P5OUT = 0X00;
        P6DIR = 0XFF;P6OUT = 0X00;
        BCSCTL1 &= ~XT2OFF;//打开XT2高频晶体振荡器
        do
            INT8U a;
            IFG1 &= ~OFIFG;//清除晶振失败标志
            for (a = 0xFF; a > 0; a--);//等待外部晶体起振
        while ((IFG1 & OFIFG));//检测外部晶振失效标志位是否清除
        BCSCTL2 |=SELM_2+SELS;//MCLK选择外部高频晶振
        TACTL = TASSEL_2+ID_3+TACLR;
        //TBCCTL0 = CCIE;
        //TBCCR0 = 50000;
        //TBCTL = TBSSEL_1+MC_1+TBCLR;
        //INT8U key1_flag = 0;
        //unsigned int key2_flag = 0;
        //unsigned int key1_scan_cnt = 400;
        //unsigned int key2_scan_cnt = 300;
        //INT8U i = 0;
        //INT8U leng =0;
        //INT8U tf =0;
        CpuInit();
        POWER_UP_RESET_CC1100();
        halRfWriteRfSettings();
        halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8);
        //halSpiStrobe(CCxxx0_SRX);                //进入接收状态
        //setRxMode();
        //h=RxBuf[5];
        LcdReset();
        DispStr(0,0,"N0W T :");
        DispStr(0,1,"NOW V :");
        Disp1Char(8,0,0+0x30);
        Disp1Char(7,0,0+0x30);
        Disp1Char(9,0,0x2e);
        Disp1Char(10,0,0+0x30);
        //Disp1Char(7,0,9+0x30);
        //Disp1Char(7,0,2+0x30);
        //_EINT();                    //打开全局中断控制位
        INT8U i;
        while(1)
                //t=TxBuf[0];
                //halRfSendPacket(TxBuf,8);
                /*leng =8;// 预计接受8 bytes
                if(halRfReceivePacket(RxBuf,&leng))
                  P1OUT = 0X00;
                  Disp_Numb();
                  Disp1Char(i,0,shuzi[ptr[0]]);
                  i++;
                  if(i==9)
                    i=i+1;
                  if(i==11)
                    i=7;*/
                Disp_Numb(Do1Convert());
                for(i=3;i<6;i++)
                TxBuf[5]=scandata[dN[i]];
函数名称:Disp_Numb
功    能:将从DS18B20读取的11bit温度数据转换
          成液晶显示的温度数字
参    数:temper--11bit温度数据
返回值  :无
/*void Disp_Numb()
   switch (RxBuf[5])
      case 0xc0:ptr[0]=0;break;
      case 0xcf:ptr[0]=1;break;
      case 0xa4:ptr[0]=2;break;
      case 0xb0:ptr[0]=3;break;
      case 0x99:ptr[0]=4;break;
      case 0x92:ptr[0]=5;break;
      case 0x82:ptr[0]=6;break;
      case 0xf8:ptr[0]=7;break;
      case 0x80:ptr[0]=8;break;
      case 0x90:ptr[0]=9;break;
void Disp_Numb(INT16U temper)
    INT8U i;
    for(i = 0;i < 6;i++) dN[i] = 0; //初始化显示变量
    //数值转换
    if(temper & BIT0)
        dN[0] = 5;
        dN[1] = 2;
        dN[2] = 6;
    if(temper&BIT1)
        dN[1] += 5;
        dN[2] += 2;
        dN[3] += 1;
    if(temper & BIT2)
        dN[2] += 5;
        dN[3] += 2;
        if(dN[2] >= 10)
            dN[2] -= 10;
            dN[3] += 1;
    if(temper&BIT3)
        dN[3] += 5;
    if(temper & BIT4)
        dN[4] += 1;
    if(temper & BIT5)
        dN[4] += 2;
    if(temper & BIT6)
        dN[4] += 4;
    if(temper & BIT7)
        dN[4] += 8;
        if(dN[4] >= 10)
            dN[4] -= 10;
            dN[5] += 1;
    if(temper & BIT8)
        dN[4] += 6;
        dN[5] += 1;
        if(dN[4] >= 10)
            dN[4] -= 10;
            dN[5] += 1;
    if(temper & BIT9)
        dN[4] += 2;
        dN[5] += 3;
        if(dN[4] >= 10)
            dN[4] -= 10;
            dN[5] += 1;
    if(temper & BITA)
        dN[4] += 4;
        dN[5] += 6;
        if(dN[4] >= 10)
            dN[4] -= 10;
            dN[5] += 1;
        if(dN[5] >= 10)
            dN[5] -= 10;
 楼主| dirtwillfly 发表于 2016-2-15 21:38 | 显示全部楼层
vivilzb1985 发表于 2016-2-16 13:57 | 显示全部楼层
    INT8U temp_low;
    INT16U  temp;
    return  temp;
从DS18B20上读取温度值并转换的。。
