(转)LPC2368一些基本测试程序2 TargetResetInit
3763|4
 楼主| txcy 发表于 2009-10-14 16:47 | 显示全部楼层 |阅读模式
void TargetResetInit(void)
#ifdef __DEBUG_RAM
     MEMMAP = 0x2;                     // remap
#endif
#ifdef __DEBUG_FLASH
     MEMMAP = 0x1;                    // remap
#endif
#ifdef __IN_CHIP
#endif
if ( PLLSTAT & (1 << 25) )    // if the PLL was connected
  PLLCON  = 0x01;
  PLLFEED = 0xAA;      // disconnect the PLL
  PLLFEED = 0x55;
  PLLCON  = 0x00;
  PLLFEED = 0xAA;      // disable the PLL
  PLLFEED = 0x55;
else if ( PLLSTAT & (1 << 24) )   // if the PLL was enabled        // 如果PLL已被使能,则先禁止PLL
  PLLCON  = 0x00;
  PLLFEED = 0x55;
SCS |= 0x20;       // Enable the main OSC,,1MHz~20MHz
    while( !(SCS & 0x40) );     // Wait until main OSC is usable
PLLCON = 1;        // Enable but disconnect the PLL
    CLKSRCSEL = 0x01;      // select main OSC as the PLL clock source
    PLLCFG  = ( ( (PLL_NValue-1) << 16)  | (PLL_MValue-1) );   // set the PLLCFG
    PLLFEED = 0xAA;       // Enable PLL
    PLLFEED = 0x55;
    while (((PLLSTAT & (1 << 24)) == 0)); // Wait until the PLL is usable
    CCLKCFG = (Fcco/Fcclk - 1);    // set the CCLKCFG
  PLLCON = 3;        // connect the PLL
    PLLFEED = 0xAA;
    PLLFEED = 0x55;
while (((PLLSTAT & (3 << 25)) == 0)); // Wait until the PLL is connected and locked
    #if USE_USB
     PCONP |= 0x80000000;    // Turn On the USB PCLK
     USBCLKCFG = (Fcco/Fusbclk - 1);
#endif
// Set system timers for each component
#if (Fpclk / (Fcclk / 4)) == 1
     PCLKSEL0 = 0x00000000;    // PCLK is 1/4 CCLK
     PCLKSEL1 = 0x00000000;
#endif
#if (Fpclk / (Fcclk / 4)) == 2
     PCLKSEL0 = 0xAAAAAAAA;    // PCLK is 1/2 CCLK
     PCLKSEL1 = 0xAAAAAAAA;
#endif
#if (Fpclk / (Fcclk / 4)) == 4
     PCLKSEL0 = 0x55555555;    // PCLK is the same as CCLK
     PCLKSEL1 = 0x55555555;
#endif
    // Set memory accelerater module
       MAMCR = 0;
#if Fcclk < 20000000
     MAMTIM = 1;
#else
#if Fcclk < 40000000
     MAMTIM = 2;
#else
     MAMTIM = 3;
#endif
#endif
     MAMCR = 2;
/* Initialize VIC*/
VICIntEnClr = 0xffffffff;
    VICVectAddr = 0;
    /* Add your codes here */
    return;
重点在于启动主晶振
 楼主| txcy 发表于 2009-10-14 16:48 | 显示全部楼层
LPC2368一些基本测试程序1 IRQ.c
//函数名:uint32 install_irq( uint32 IntNumber, void *HandlerAddr, uint32 Priority )
//描述  :
//参数  :
//返回  :
//其他  :
    uint32 *vect_addr;
    uint32 *vect_cntl;
    VICIntEnClr = 1 << IntNumber; /// Disable Interrupt
    if ( IntNumber >= VIC_SIZE )
  return ( FALSE );
    else
  // find first un-assigned VIC address for the handler
  vect_addr = (uint32 *)(VIC_BASE_ADDR + VECT_ADDR_INDEX + IntNumber*4);
  vect_cntl = (uint32 *)(VIC_BASE_ADDR + VECT_CNTL_INDEX + IntNumber*4);
  *vect_addr = (uint32)HandlerAddr; // set interrupt vector
  *vect_cntl = Priority;
  VICIntEnable = 1 << IntNumber; // Enable Interrupt
  return( TRUE );
和LPC21xx不同,LPC2368的vic的vect_addr 和中断号码是一样对应的。
华荣汇FAE3 发表于 2009-10-14 16:59 | 显示全部楼层
呵呵,谢谢楼上,辛苦了!:P
hsbjb 发表于 2009-10-15 09:36 | 显示全部楼层
楼主辛苦了,不过程序的注释要是再详细点就更好了
无冕之王 发表于 2009-10-16 19:21 | 显示全部楼层
应该说明一下程序的作用。。。
