状态机按键
1040|9
 楼主| gongche 发表于 2016-2-26 18:56 | 显示全部楼层 |阅读模式
大家有没有状态机按键的参考程序?
huwr 发表于 2016-2-26 18:56 | 显示全部楼层
这个很多吧
以前按键都是用延时程序来判断的
huanghuac 发表于 2016-2-26 18:57 | 显示全部楼层
这样CPU的效率不高。
 楼主| gongche 发表于 2016-2-26 18:57 | 显示全部楼层
happy_10 发表于 2016-2-26 18:57 | 显示全部楼层
源码区找找吧,肯定有
哦,好吧
bbapple 发表于 2016-3-13 21:38 | 显示全部楼层
状态机按键 是老生常谈的问题了,论坛中有很多资料的,楼主再找找看呗。。。
Thor9 发表于 2016-3-25 23:03 | 显示全部楼层
#include "KeyBoard.h"
#include "AS1.h"
//unsigned int msCount;
#define KeyBuffLen 8
struct Struct_KeyBoardBuff
  uchar buff[KeyBuffLen];
  uchar in;
  uchar out;
}Key;
enum KeyFSM_Enum
  _Key_Idle=0,
  _Key1_down,
  _Key1_press,
  _Key1_up,
  _Key2_down,
  _Key2_press,
  _Key2_up,
  _Key_confirm,
void KeyBoardInit(void)
Key.in=0;
Key.out=0;
uchar ReadKey(void)
  uchar Value;
  if (Key.out!=Key.in)
    Value=Key.buff[Key.out++];
    if (Key.out>=KeyBuffLen)
      Key.out=0;
  else
    Value=KeyNull;
  return(Value);
uchar JudgeKey(uchar key)
  uchar i,count=0;
  for (i=0;i<6 ;i++ )
    if ((key&0x01)==0)count++;
    key=key>>1;
  return(count);
void KeyIn(void)
  static uchar Key_Input=0;
  static uchar volatile step=0;
  //Put the code get the Key_Value
  uchar NewKey=KEY_PORT&0x3f;
  uchar num=JudgeKey(NewKey);
  switch(step)
    case _Key_Idle:
      switch (num)
        case 1:
          Key_Input=NewKey;
          step=_Key1_down;
          break;
        case 2:
          Key_Input=NewKey;
          step=_Key2_down;
          break;
        default:
          break;
      break;
    case _Key1_down:
      switch (num)
        case 1:
          if(NewKey==Key_Input)
            step=_Key1_press;
          else
            step=_Key_Idle;
          break;
        case 2:
          Key_Input=NewKey;
          step=_Key2_down;
          break;
        default:
          step=_Key_Idle;
          break;
      break;
    case _Key1_press:
      switch (num)
        case 1:
          if(NewKey!=Key_Input)
            step=_Key1_up;
          break;
        case 2:
          Key_Input=NewKey;
          step=_Key2_down;
          break;
        default:
          step=_Key1_up;
          break;
      break;
    case _Key1_up:
      switch (num)
        case 1:
            step=_Key1_press;
          else
            step=_Key_confirm;
          break;
        case 2:
          Key_Input=NewKey;
          step=_Key2_down;
          break;
        default:
          step=_Key_confirm;
          break;
      break;
    case _Key2_down:
        step=_Key2_press;
      else
        step=_Key_Idle;
      break;
    case _Key2_press:
      if (num==0)
        step=_Key2_up;
      break;
    case _Key2_up:
      if (num==0)
        step=_Key_confirm;
      break;
    default:
      step=_Key_Idle;
      break;
  if (step==_Key_confirm)
    step=_Key_Idle;
    if (Key_Input!=0)
      Key.buff[Key.in++]=Key_Input;
      if (Key.in>=KeyBuffLen)
        Key.in=0;
void Key_Board_Test(void)
  uchar key;
  key=ReadKey();
    switch (key)
      case KeyUp:
        AS1_SendString("Up.");
        break;
      case KeyDown:
        AS1_SendString("Down.");
        break;
      case KeyAdd:
        AS1_SendString("Add.");
        break;
      case KeySub:
        AS1_SendString("Sub.");
        break;
      case KeyEnter:
        AS1_SendString("Enter.");
        break;
      case KeyReturn:
        AS1_SendString("Return.");
        break;
      case KeyLr:
        AS1_SendString("LR.");
        break;
      default:
        //AS1_SendString("None.");
        break;
文件Keyboard.h
#ifndef _Key_Board_h_
#define _Key_Board_h_
#define KEY_PORT PORTA
#define KeyUp 0x3e
#define KeyDown 0x3d
#define KeyAdd 0x3b
#define KeySub 0x37
#define KeyEnter 0x2f
#define KeyReturn 0x1f
#define KeyLr 0x33
#define KeyNull 0xff
typedef unsigned char uchar;
extern unsigned int msCount;
extern void KeyBoardInit(void);
extern unsigned char ReadKey(void);
extern void KeyIn(void);
extern void Key_Board_Test(void);
#endif
