定时器A的基本例程
1056|3
 楼主| 上山砍老虎 发表于 2016-2-29 22:53 | 显示全部楼层 |阅读模式
//  MSP-FET430P140 Demo - Timer_A, Toggle P1.0, CCR0 Cont. Mode ISR, DCO SMCLK
//  Description: Toggle P1.0 using software and TA_0 ISR. Toggles every
//  50000 SMCLK cycles. SMCLK provides clock source for TACLK.
//  During the TA_0 ISR, P1.0 is toggled and 50000 clock cycles are added to
//  CCR0. TA_0 ISR is triggered every 50000 cycles. CPU is normally off and
//  used only during TA_ISR.
//  ACLK = n/a, MCLK = SMCLK = TACLK = default DCO ~800kHz
//           MSP430F149
//     /|\|            XIN|-
//      --|RST        XOUT|-
//        |           P1.0|-->LED
//  M. Buccini
//  Texas Instruments Inc.
//  Feb 2005
//  Built with IAR Embedded Workbench Version: 3.21A
#include  <msp430x14x.h>
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR |= 0x01;                            // P1.0 output
  CCTL0 = CCIE;                             // CCR0 interrupt enabled
  CCR0 = 50000;
  TACTL = TASSEL_2 + MC_2;                  // SMCLK, contmode
  _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/ interrupt
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A (void)
  P1OUT ^= 0x01;                            // Toggle P1.0
  CCR0 += 50000;                            // Add Offset to CCR0
 楼主| 上山砍老虎 发表于 2016-2-29 22:54 | 显示全部楼层
最基础的东西,才能学到东西,我记得我以前学430的时候,用示波器把TA的每一个例程都看一遍
bboo 发表于 2016-2-29 22:56 | 显示全部楼层
确实是这样的,跑例程其实是一种很好的学习方法
给力芯片 发表于 2016-2-29 23:01 | 显示全部楼层
定时器是一个芯片的灵魂啊
