bootloader enable pin definition求救!
3863|1
 楼主| young_xyj 发表于 2009-10-24 15:57 | 显示全部楼层 |阅读模式
我有一份bootloader代码,其定义的:
// bootloader enable pin definition
#define BL_ENABLE_PORT  GPIOD
#define BL_ENABLE_PIN   GPIO_PIN_2
我想问下所有的STM8S是否都是用这个管脚来判定是否导向升级?
说明我使用的是STM8S105C6是否也是用这个脚?
附上:
// detect if bootloader is enabled
  // enable pull-up on detect pin
  GPIO_Init(BL_ENABLE_PORT, BL_ENABLE_PIN, GPIO_MODE_IN_PU_NO_IT);
  // detect if pin is in high state - jumper not present = inactive bootloader
  if(GPIO_ReadInputData(BL_ENABLE_PORT) & GPIO_PIN_2)
    //if user application is not virgin - valid reset vector jump
    if((*((@far u8*)MainUserApplication)==0x82) || (*((@far u8*)MainUserApplication)==0xAC))
      GPIO_DeInit(BL_ENABLE_PORT); //de-init pull-up
      //reset stack pointer (lower byte - because compiler decreases SP with some bytes)
      _asm("LDW X,  SP ");
      _asm("LD  A,  $FF");
      _asm("LD  XL, A  ");
      _asm("LDW SP, X  ");
      // then jump to user application
      _asm("JPF [_MainUserApplication]");
      //MainUserApplication();
香水城 发表于 2009-10-26 10:08 | 显示全部楼层
哪里搞来的bootloader代码?
