EM78P447请各位看看本人的显示程序,和中断有啥问题
2364|1
 楼主| ytmkkk1986 发表于 2009-11-4 09:00 | 显示全部楼层 |阅读模式
定义:
#define  Yellow  R75
#define  Green  R74
#define  Red   R73
/**全局变量**/
uchar tcc_count = 0;  //计时到50次,为1秒;
uchar second = 0;   //秒初始值;
uchar set_state = 0;  //系统状态标致;
ushort key_time = 0;
uchar key_num = 0;  //键盘扫描次数;
ushort user_time_second = 1;  //调节,用户自己设定的时间;键盘设定的值;
ushort user_time_minute = 1;  //用户自己设定的加油等待时间;
uchar H_second_buf = 0;
uchar L_second_buf = 1;
uchar H_minute_buf = 0;
uchar L_minute_buf = 1;
uchar H_second = 0;  //超过256时的用户设置的秒user_time的高位;
uchar L_second = 1;
uchar H_minute = 0;  //超过256时的用户设置的分user_time的高位;
uchar L_minute = 1;
  //百位,十位,个位;
uchar dis_num[3] = {0,0,1}; //初始化显示程序;显示存储器;
ushort dis_buf = 1;   //显示缓冲数据;
/**位定义**/
bit  skey_flag = 0;   //20MS键盘扫描标致位;
bit  wait_flag = 0;   //等待时间;加油标致位"1时";
//bit  aotu_flag = 0;   //手动加油标致位;
/***常量定义***/
const uchar seg_duan[13] = {
//0   1   2   3   4   5   6   7   8   9 //0x40"-",0xff"open",0x00"close"
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0xff,0x00
const uchar seg_wei[3] = {
//seg1,seg2,seg3;
0x10,0x20,0x40
const uchar  duan_bit[7] = {
//R71,R67,R73, R74, R75, R70, R72;
0x01,0x02,0x04,0x08,0x10,0x20,0x40
________________________________________________
显示;
void delay(uchar de)
for(;de>0;de--){NOP();}
*    display
*R70~R75,R67 ARE duan out;R64,R65,R66 ARE wei out;
void display(uchar wei,uchar duan)  //写SEG段;write wei;
uchar j;
//write duan;
NOP();NOP();NOP();NOP();
P7CR &= 0XC0;
P6CR &= 0X07;
P6CR |= 0X04;
    PORT6&= 0X8F;
NOP();NOP();
Led_cr=1;
NOP();NOP();
if(duan & duan_bit[0])R71 = 1;
else R71 = 0;
if(duan & duan_bit[1])R67 = 1;
else R67 = 0;
if(duan & duan_bit[2])R73 = 1;
else R73 = 0;
if(duan & duan_bit[3])R74 = 1;
else R74 = 0;
if(duan & duan_bit[4])R75 = 1;
else R75 = 0;
if(duan & duan_bit[5])R70 = 1;
else R70 = 0;
if(duan & duan_bit[6])R72 = 1;
else R72 = 0;
//write wei;
NOP();NOP();
    PORT6 |= wei;
    WDTC();NOP();
for(j=100;j>0;j--){NOP();}
NOP();
WDTC();
    NOP();NOP();WDTC();
    PORT6 &= 0X0F;
    PORT7 &= 0XC0;
    NOP();NOP();
NOP();WDTC();
void dip_seg3(ushort num)
uchar i = 0;
dis_num[0] = (uchar)(num/100);
if(dis_num[0] == 0)dis_num[0] = 12;
dis_num[1] = (uchar)(num%100/10);
if(dis_num[0] == 12)
  if(dis_num[1] == 0)dis_num[1] = 12;
dis_num[2] = (uchar)(num%10);
  if(dis_num[1] == 12)
   if(dis_num[2] == 0)dis_num[2] = 12;
WDTC();
for(i=0;i<3;i++){
  display(seg_wei[i],~seg_duan[dis_num[i]]);
  WDTC();
显示程序;
void _intcall INTTERRUPT(void) @ int 0
  // Write your code (inline assembly or C) here
TCC = 178;
_asm{
  BC 0x4,7
  BC 0x4,6
  CLR 0x3f
DISI();
skey_flag = 1;
tcc_count++;
   if(wait_flag == 0){
    if(tcc_count == 50){
     tcc_count = 0;
     second++;
     if(second == 60){
      second = 0;
      L_minute--;
      if(L_minute == 0){
       if(H_minute == 0){
        wait_flag = 1;
        H_second = H_second_buf;
        L_second = L_second_buf;
       }else{
        H_minute--;
        L_minute = 250;
   }else{
     tcc_count = 0;
     L_second--;
     if(L_second == 0){
      if(H_second == 0){
       wait_flag = 0;
       H_minute = H_minute_buf;
       L_minute = L_minute_buf;
      }else{
       H_second--;
       L_second = 250;
  //restore ACC,R3,R4
  _asm
     reti            //tell Compiler to recover common registers here
     BS 0X4,6        //If switch to register page 3 in restore C system inline assembly,
     BS 0X4,7        //in this inline assembly can neglect.
  MOV A, 0X3C //使用2字节C类型数据,C系统恢复
  MOV 0X10, A
  MOV A, 0X3B
  MOV 0X11, A
  MOV A, 0X3A
  MOV 0X12, A
  MOV A, 0X39
  MOV 0X13, A
  MOV A, 0X38
  MOV 0X14, A
  MOV A, 0X37
  MOV 0X15, A
  MOV A, 0X36 //使用2字节C类型数据,C系统恢复
  MOV 0X16, A
  MOV A, 0X35
  MOV 0X17, A
  MOV A, 0X34
  MOV 0X18, A
  MOV A, 0X33
  MOV 0X19, A
     SWAPA 0X3E-1
     MOV 0X3,A
     SWAPA 0X3F-1
     MOV 0X4,A
     SWAP 0X1F
     SWAPA 0X1F
void _intcall INTERRUPT_l(void) @ 0x1:low_int 0
  //backup ACC,R3,R4
  _asm
     MOV 0X1F,A
     SWAPA 0X4
     BS 0X4,6
     BS 0X4,7
     MOV 0X3F-1,A
     SWAPA 0X3
     MOV 0X3E-1,A
     MOV A, 0X10 //使用1字节C数据类型,C系统备份
  MOV 0X3C, A //将0x10~0x19保存到bank 3的0x3C,0X3B, 0X3A,
  MOV A, 0X11 //0X39, 0X38, 0X37,因为在intcall INTERRUPT1_l
  MOV 0X3B, A //子程式里已将ram切换到了bank 3
  MOV A, 0X12
  MOV 0X3A, A
  MOV A, 0X13
  MOV 0X39, A
  MOV A, 0X14
  MOV 0X38, A
  MOV A, 0X15
  MOV 0X37, A
  MOV A, 0X16 //使用2字节C数据类型,C系统备份
  MOV 0X36, A //将0x10~0x19保存到bank 3的0x3C,0X3B, 0X3A,
  MOV A, 0X17 //0X39, 0X38, 0X37,因为在intcall INTERRUPT1_l
  MOV 0X35, A //子程式里已将ram切换到了bank 3
  MOV A, 0X18
  MOV 0X34, A
  MOV A, 0X19
  MOV 0X33, A
     BC 0X03,5
     BC 0X03,6
中断程序,递减计数;
 楼主| ytmkkk1986 发表于 2009-11-4 09:25 | 显示全部楼层
对了,我这个程序,感觉中断,要不就是显示问题,所有功能能实现,就是程序跑着跑着,就死机,开DOG,就会DOG拉回来重启!好像程序里面有个洞一样,进去了,就出不来了!别的键盘啊,FOR语句都没有,24C02读写都正常,主要是IO复用得比较多
