关于28335 I2C模块编程问题请教
1092|0
 楼主| zuqiuxiaozi 发表于 2016-3-21 13:24 | 显示全部楼层 |阅读模式
各位大侠,我在学习I2C模块的编程,我对头文件中的一个定义的结构体弄不明白,关键是源程序中的MsgStatus变量包含的各种状态,我实在弄不明白这是什么意思,希望大家指导一下:
结构体为:
struct I2CMSG {
  uint16 MsgStatus;    // Word stating what state msg is in:
                                      //   I2C_MSGCMD_INACTIVE = do not send msg
                                     //   I2C_MSGCMD_BUSY = msg start has been sent,
                                    //                     awaiting stop
                                   //   I2C_MSGCMD_SEND_WITHSTOP = command to send
                                  //       master trans msg complete with a stop bit
                                 //   I2C_MSGCMD_SEND_NOSTOP = command to send
                                //       master trans msg without the stop bit
                               //   I2C_MSGCMD_RESTART = command to send a restart
                              //       as a master receiver with a stop bit
  uint16 SlaveAddress;   // I2C address of slave msg is intended for
  uint16 NumOfBytes;   // Num of valid bytes in (or to be put in MsgBuffer)
  uint16 MemoryAddr;   // RTC address of data associated with msg (low byte)
  uint16 MsgBuffer[I2C_MAX_BUFFER_SIZE]; // Array holding msg data - max that
        // MAX_BUFFER_SIZE can be is 16 due to
        // the FIFO's
这些是MsgStatus指向的各种状态变量,到底是跟I2C模块是怎样的关系,我应该在哪查到这些变量,希望大家帮我指导一下:
// I2C  Message Commands for I2CMSG struct
#define I2C_MSGSTAT_INACTIVE                     0x0000
#define I2C_MSGSTAT_SEND_WITHSTOP     0x0010
#define I2C_MSGSTAT_WRITE_BUSY              0x0011
#define I2C_MSGSTAT_SEND_NOSTOP          0x0020
#define I2C_MSGSTAT_SEND_NOSTOP_BUSY  0x0021
#define I2C_MSGSTAT_RESTART                           0x0022
#define I2C_MSGSTAT_READ_BUSY                      0x0023
希望大家能帮我解决这个疑惑点,谢谢了!
