MPLAB C 与汇编 编译问题
1225|1
 楼主| 张大卫 发表于 2016-3-23 16:33 | 显示全部楼层 |阅读模式
  用的是MPLAB V8.91  器件为 PIC18F25K22 ,准备做远程IAP,发现HITECH 提供的源码 有嵌入汇编,
  目前  asm("ljmp BOOT_START");     是可以编译成功
#asm
//    ; //Reset vector redirection
//    ; //some equates for accessing the program counter
    PCL    equ    02h
    PCLATH    equ    0Ah
    psect    redirect,abs,class=CODE,delta=2    ;//absolute psect so it goes
                        ;//to address zero
    ;//The boot loader code has been written so that it doesn't need any
    ;//variable initialization runtime startup code.
    ;//Because of this, we can jump directly into the main() function.
    global    _main
    movlw    _main >> 8    ;//A "long" jump to main - this will cope with
    movwf    PCLATH        ;//main being positioned anywhere
    movlw    _main & 0xFF
    movwf    PCL
#endasm
上面这段就是提示   syntax error  ,不知大家有没有碰到过这种怪事,我看了,MPLAB ,它支持这两种汇编格式的
 楼主| 张大卫 发表于 2016-3-23 16:34 | 显示全部楼层
希望大家能讨论,或者建立一个QQ群聊
