Cypress CY8CKIT-050B PSOC5LP 最新版开发板 原装
1104|0
 楼主| szjlj168 发表于 2016-4-1 12:25 | 显示全部楼层 |阅读模式
CY8CKIT-050 PSoC® 5LP Development Kit
Last Updated:04/10/2013
The CY8CKIT-050 PSoC® 5LP Development Kit enables you to evaluate, develop and prototype high precision analog, low-power and low-voltage applications powered by Cypress’s CY8C58LP high precision analog device family.
Additionally, this kit supports the PSoC Expansion Board Kit ecosystem as a compatible host platform. This kit is designed specifically for PSoC 5LP development, the PSoC 3 version of the same kit can be purchased from[url=]www.cypress.com/go/cy8ckit-030[/url].
This kit is designed for analog performance. The kit features a very low noise floor. Care has been taken to separate the analog and the digital domain. Separate regulators are also available and separate ground planes are provided. We have achieved ENOB very close to 20 bits with this kit. Provisions are provided to add an external precision voltage reference, if needed.
Besides the analog, this kit is also meant to demonstrate the low power operation of PSoC 5LP. The PSoC 5LP chip is soldered to the board, this significantly reduces the leakage currents compared to the CY8CKIT-001. Special terminals are provided to enable the boost converter operation without requiring many modifications. Jumpers have been provided to remove power to RS232 converter, potentiometer, to have a single regulator for analog and digital domain, and evaluate the low power operation of PSoC 5LP.
It features an onboard programmer (Cypress USB chip based), which allows you to program the PSoC 3/PSoC 5LP without connecting to Miniprog3, however, provisions have been provided to program using Miniprog3 as well.
Kit Upgrade: It is time to upgrade from CY8C55 silicon-based PSoC 5 DVK to the CY8C58LP silicon-based PSoC 5LP DVK. This upgrade is FREE to our valued customers. Shipping, handling, and customs charges may apply. Log on to[url=]www.cypress.com/go/psockitupgrade[/url]to get more details. Cypress appreciates your business and continued loyalty.
Kit Contents:
  • PSoC 5LP Development Board
  • LCD Character Display
  • USB Cable
  • Quick Start Guide
  • Kit CD, which includes: PSoC Creator, PSoC Programmer, Projects and Documentation
个人签名:深圳永晟达电子科技有限公司专业代理:CYPRESS,Microchip,NXP,ST,ATMEL,TI,LTC,等系列原装进口IC 可代客户开发程序  QQ;547838378
4395
