【试用】+GD32驱动HT1621
1587|2
 楼主| JY-DX-JY 发表于 2016-4-10 08:47 | 显示全部楼层 |阅读模式
看了一下程序,感觉有点像STM32。
先上图
附源代码:
#include "example.h"
#include "gd32f20x.h"
#include "colibri_bsp_led.h"
#if (EVB_EXAMPLE == LED_EXAMPLE)
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           GPIO_ResetBits(GPIOE,GPIO_PIN_2);
#define CS_1           GPIO_SetBits(GPIOE,GPIO_PIN_2);
#define WR_0           GPIO_ResetBits(GPIOE,GPIO_PIN_1);
#define WR_1           GPIO_SetBits(GPIOE,GPIO_PIN_1);
#define DA_0           GPIO_ResetBits(GPIOE,GPIO_PIN_0);
#define DA_1           GPIO_SetBits(GPIOE,GPIO_PIN_0);
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
unsigned int i;
void delay(void)
        unsigned char i;
        for(i=0;i<50;i++);
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        //delay();
        WR_0;
        //delay();
        for(i=0;i<3;i++)        //写命令
                if((0x04<<i)&0x04)  DA_1;    //100
                if(((0x04<<i)&0x04)==0)                DA_0;
                WR_0;
                WR_1;
        for(i=0;i<9;i++)        //写命令数据
                if((comm<<i)&0x80)  DA_1;    //100
                if(((comm<<i)&0x80)==0)                DA_0;
                WR_0;
                WR_1;
        CS_1;
void HT1621_Display(void)
        unsigned char i;
        CS_0;
        //delay();                        //片选CS
        WR_0;
        //delay();
                if((0x05<<i)&0x04)  DA_1;
                if(((0x05<<i)&0x04)==0)                DA_0;
                WR_0;
                WR_1;
        for(i=0;i<6;i++)                   //写地址
                if((20<<i)&0x20)    DA_1;    //20对应 SEG地址
          if(((20<<i)&0x20)==0)                DA_0;
                WR_0;
                WR_1;
        for(i=0;i<8;i++)                   //写数据
                if((DpyNum[5]<<i)&0x80)   DA_1;
                if(((DpyNum[5]<<i)&0x80)==0)                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[4]<<i)&0x80)   DA_1;
                if(((DpyNum[4]<<i)&0x80)==0)                     DA_0;
                WR_0;
                WR_1;
                if((DpyNum[3]<<i)&0x80)   DA_1;
                if(((DpyNum[3]<<i)&0x80)==0)                     DA_0;
                WR_0;
                WR_1;
                if((DpyNum[2]<<i)&0x80)   DA_1;
                if(((DpyNum[2]<<i)&0x80)==0)                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[1]<<i)&0x80)   DA_1;
                if(((DpyNum[1]<<i)&0x80)==0)                     DA_0;
                WR_0;
                WR_1;
                if((DpyNum[0]<<i)&0x80)   DA_1;
                if(((DpyNum[0]<<i)&0x80)==0)                      DA_0;
                WR_0;
                WR_1;
        CS_1;                            //释放CS
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
/* 用户应用程序入口函数 */
int main(void)
    int i;
    /* 配置使能评估板上的设备 */
    EvbSetupBoard();
    PRINTF("感谢使用Colibri开发板\r\n");
    PRINTF("\r\n");
    PRINTF("##### LED 实验 #####\r\n");
    PRINTF("\r\n");
                LCD_Init();
        DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
        DpyNum[1] = SegCode[1];
        DpyNum[2] = SegCode[2];
        DpyNum[3] = SegCode[3];
        DpyNum[4] = SegCode[4];
        DpyNum[5] = SegCode[5];
        HT1621_Display();               //刷新LCD
    while(1)
//        for (i = 0; i< 0x7fffff; i++);
//        EvbLedControl(LED1, LED_ON);
//        EvbLedControl(LED2, LED_ON);
//                EvbLedControl(LED3, LED_ON);
//        EvbLedControl(LED1, LED_OFF);
//        EvbLedControl(LED2, LED_OFF);
//        EvbLedControl(LED3, LED_OFF);
#endif
QQ178960471 发表于 2016-5-6 11:38 | 显示全部楼层
楼主想说什么?HT1621B怎么了
 楼主| JY-DX-JY 发表于 2016-5-6 11:40 | 显示全部楼层
楼主想说什么?HT1621B怎么了
开发板试用啊,你眼睛长哪儿了
个人签名:晴天响霹雳,平地一声雷。
245
