[STM32F4] 串口通信(基于keil5.13)
1559|1
 楼主| Roderman_z 发表于 2016-4-18 22:08 | 显示全部楼层 |阅读模式
TM32F411一共有三个串口,分别是串口一,串口二和串口六。这个串口折腾了好多好多天,说多了都是泪,我一开始就上串口二,没想到串口二是个坑!!!!!使劲调都调不通,最后还是放弃先,之后试了试串口一和串口六,一试就通!
别跟我说是不是硬件问题,或者说是不是串口二的时钟没开之类的!都不是!!!!!我调通串口一和串口六之后,试了试用stn32的专用库来试试,我擦想死的心都有,一下就成了!!!别烦我先,我一个人想静静,别问静静是谁!     为什么标准库不行!!!!请广大网友解决这个问题能发发善心告诉我,这里我奉上我调通的三个串口源码。(串口一和串口六我都写好接收中断了,串口二仅仅写好了发送的没写接收的)
(1)建立工程,新建工程的步骤就不说了!
(2)新建bsp_usart.c和bsp_usart.h
bsp_usart.c
  1. #include "bsp_usart.h"
  2. void NVIC_USART1_Config(void)
  3. {
  4.         NVIC_InitTypeDef NVIC_InitStructure;
  5.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  6.
  7.         NVIC_InitStructure.NVIC_IRQChannel=USART1_IRQn;
  8.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x00;
  9.         NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x02;
  10.         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  11.         NVIC_Init(&NVIC_InitStructure);
  12. }
  13. void USART1_Config(void)
  14. {
  15.         GPIO_InitTypeDef GPIO_InitStructure;
  16.         USART_InitTypeDef USART_InitStructure;
  17.
  18.
  19.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA , ENABLE);
  20.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  21.         //串口1对应引脚复用映射
  22.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
  23.         GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
  24.
  25.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10;
  26.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  27.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  28.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  29.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  30.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  31.
  32.         NVIC_USART1_Config();
  33.         USART_InitStructure.USART_BaudRate=115200;
  34.         USART_InitStructure.USART_WordLength=USART_WordLength_8b;
  35.         USART_InitStructure.USART_StopBits=USART_StopBits_1;
  36.         USART_InitStructure.USART_Parity=USART_Parity_No;
  37.         USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
  38.         USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
  39.
  40.         USART_Init(USART1,&USART_InitStructure);
  41.
  42.         USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
  43.
  44.         USART_Cmd(USART1,ENABLE);
  45. }
  46. /// 重定向c库函数printf到USART1
  47. int fputc(int ch, FILE *f)
  48. {
  49.                 /* 发送一个字节数据到USART1 */
  50.                 USART_SendData(USART1, (uint8_t) ch);
  51.
  52.                 /* 等待发送完毕 */
  53.                 while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
  54.
  55.                 return (ch);
  56. }
  57. /// 重定向c库函数scanf到USART1
  58. int fgetc(FILE *f)
  59. {
  60.                 /* 等待串口1输入数据 */
  61.                 while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
  62.                 return (int)USART_ReceiveData(USART1);
  63. }
  64. /*********************************************END OF FILE**********************/
 楼主| Roderman_z 发表于 2016-4-18 22:09 | 显示全部楼层
bsp_usart.h
  1. #ifndef _BSP_USART_H_
  2. #define _BSP_USART_H_
  3. #include "stm32f4xx.h"
  4. #include <stdio.h>
  5. void USART1_Config(void);
  6. #endif
(3)修改stm32f4xx_it.c
  1. void USART1_IRQHandler(void)
  3.         char c;
  4.         if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
  5.         {
  6.                 c=USART_ReceiveData(USART1);
  7.                 USART_SendData(USART1,c);
  8.         }
  9. }
编译下载后利用USB转串口下载器进行通信(大家可以利用市面上的开发板的串口部分),打开串口助手后,给板子复位后
温馨提示,如果你要用串口二则板子的A2 和A3外引接口是没有跟MCU链接的   不过ST-link中的RX ,TX就是连上MCU的串口二的  我们也可以往这连!
