请版主帮忙分析CAN的中断初始化,谢谢。
2387|4
 楼主| xqhwmk 发表于 2009-12-31 10:14 | 显示全部楼层 |阅读模式
00}
ST_ARM 发表于 2009-12-31 10:22 | 显示全部楼层
CAN的那部分怎么没有贴出来?
另外:
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  /* Configure one bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
添加上面这一行。
 楼主| xqhwmk 发表于 2009-12-31 10:25 | 显示全部楼层
CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CanTxMsg TxMessage;
  u8 i=0;
  /* CAN register init */
  CAN_DeInit();
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
  CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler=1;
  CAN_Init(&CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=1;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* CAN FIFO0 message pending interrupt enable */
  CAN_ITConfig(CAN_IT_FMP0, ENABLE);
  /* transmit 1 message */
  TxMessage.StdId=0x12;
  TxMessage.ExtId=0x34;
  TxMessage.IDE=CAN_ID_EXT;
  TxMessage.RTR=CAN_RTR_DATA;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xDE;
  TxMessage.Data[1]=0xCA;
  CAN_Transmit(&TxMessage);
  /* initialize the value that will be returned */
  ret=0xFF;
  /* receive message with interrupt handling */
  i=0;
  while((ret==0xFF)&&(i<0XFFF))
    i++;
  if (i==0xFFF)
   ret=0;
  /* disable interrupt handling */
  CAN_ITConfig(CAN_IT_FMP0, DISABLE);
  return (TestStatus)ret;
 楼主| xqhwmk 发表于 2009-12-31 10:26 | 显示全部楼层
不好意思,上面的不是。
补充正确的:
ST_ARM 发表于 2009-12-31 10:27 | 显示全部楼层
请问CAN的代码是在同一个函数里的,还是不同的函数里的,贴出时将函数完整贴出。
