[AVR单片机] T0定时器溢出标志问题?
4561|5
 楼主| 新好男孩 发表于 2010-1-6 11:55 | 显示全部楼层 |阅读模式
刚学AVR,关于T0定时器做延时用,注意红色标记的地方。
//ICC-AVR application builder : 2010-1-4 10:37:07
// Target : M16
// Crystal: 8.0000Mhz
#include <iom16v.h>
#include <macros.h>
void port_init(void)
PORTA = 0x00;
DDRA  = 0x01;
PORTB = 0x00;
DDRB  = 0x00;
PORTC = 0x00; //m103 output only
DDRC  = 0x00;
PORTD = 0x00;
DDRD  = 0x00;
//TIMER0 initialize - prescale:64
// WGM: Normal
// desired value: 1mSec
// actual value:  1.000mSec (0.0%)
void Delay_ms(void)
   TCCR0 = 0x00; //stop
   TCNT0 = 0x83; //set count
   OCR0  = 0x7D;  //set compare
   TCCR0 = 0x03; //start timer
   while ((TIFR & 0x01) == 0);    // 为什么TIFR的D0位不会溢出????
  TIFR &= ~ (1<<TOV0);
void Delay_Xms(unsigned int i)
   unsigned int x;
  for (x=0; x<i; x++)
     Delay_ms();
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
   init_devices();
  while (1)
       PORTA &= ~(1<<0);
     Delay_Xms(1000);
     PORTA |= (1<<0);
宇容创行 发表于 2010-1-6 15:16 | 显示全部楼层
TIFR &= ~ (1<<TOV0); 这句不对
 楼主| 新好男孩 发表于 2010-1-6 15:33 | 显示全部楼层
谢谢!
明白了,T0的定时溢出后TOV0置位后要写1来清0
这样写就OK了
huamunv 发表于 2010-1-6 22:26 | 显示全部楼层
“T0的定时溢出后TOV0置位后要写1来清0”
wangwo 发表于 2010-1-9 00:05 | 显示全部楼层
Karlshen 发表于 2010-1-11 23:13 | 显示全部楼层
路过,修改后上面程序能通过不?
