版主,能否提供一个使用芯片内部HSI设置的示例?
3209|3
gotomy|  楼主 | 2010-1-6 13:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
grant_jx| | 2010-1-6 14:13 | 只看该作者
ST官方提供的STM8S固件库不是有这个示例吗?
STM8S上电复位默认就是使用HSI在工作的,8分频,频率是2MHz。不用在切了,直接该分频比即可。
下面是ST提供的一个直接对寄存器操作的例子,实现HSE和HSI切换:
  This example provides two optimal clock configurations and switching between
  them. After reset the application is running on HSI with fcpu 16Mhz. When the
  KEY button is pressed switch to 24Mhz HSE in manual mode is performed. Fcpu
  could be controled on MCO pin (PE0) by scope. Change of All LEDs blinking
  frequency could be observed by eye.
  * @file CLK_example1\main.c
  * @brief This file contains the main function for CLK example 1.
  * @author STMicroelectronics, MCD Application Team
  * @version 1.02
  * @date 1-JUN-2009
  * THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
  * @addtogroup CLK_Example1
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define to_HSE        0xB4        // definition of clock blocks (to be copied to SWR)
#define        to_LSI        0xD2
#define        to_HSI        0xE1
#define ALL_LEDs         ((u8)0x0F)        // LEDs mask (EVAL board)
#define BUTTON ((u8)0x01)                // Button mask (EVAL board)
#define CLK_SWITCH_TIMEOUT ((u16)0x491)        //timeout for clock switching
/* Private macro -------------------------------------------------------------*/
#define switch_all_LEDs_on        { GPIOH->ODR|= ALL_LEDs; }        //LEDs control
#define switch_all_LEDs_off        { GPIOH->ODR&=~ALL_LEDs; }
#define button_is_pressed        ((GPIOC->IDR & BUTTON) == 0)
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
  * @brief Programable loop delay
  * @par Parameters:
  * nCnt: multiply factor of the number of loops
  * @retval None
void Delay(u8 nCnt) {
        u32 nCount= nCnt*(u32)10000;
        while (nCount != 0) {
                nCount--;
  * @brief Switch to selected clock using manual mode.
  * @par Parameters:
  * clck: to_HSE, to_LSI, to_HSI - block to switch
  * @retval TRUE in case of succes else FALSE
u8 switch_clock_system(u8 clck) {
        u16 Tout= CLK_SWITCH_TIMEOUT;
        CLK->SWCR &= ~CLK_SWCR_SWIF;                                        // manual switch mode
        CLK->SWR= clck;
   while ( !(CLK->SWCR & CLK_SWCR_SWIF)  &&  Tout)
        Tout--;        // wait for targed block is ready
        if(Tout) {
             CLK->SWCR|= CLK_SWCR_SWEN;                                             // new block is ready - make switch!
             return(TRUE);        // return SUCCES!
        else {
        CLK->SWCR &= ~CLK_SWCR_SWBSY;        // reswitch to original clock source
        return(FALSE);        // return switching wasn't succesfull
/* Public functions ----------------------------------------------------------*/
  * @brief Validation firmware main entry point.
  * @par Parameters:
  * None
  * @retval void None
void main(void) {
        u8 succ;
        u8 butt;
//         *** GIO INIT ***
        GPIOH->ODR &=~ALL_LEDs;        // LEDs - as push-pull outputs, all off
        GPIOH->DDR |= ALL_LEDs;
        GPIOH->CR1 |= ALL_LEDs;
        GPIOC->CR1 |= BUTTON;         // BUTTON input settings: Input pull-up
        GPIOC->DDR &=~BUTTON;
//         *** CLK INIT ***
        CLK->CKDIVR &= (u8)~(CLK_CKDIVR_CPUDIV);        // fcpu= fmaster (CPUDIV= 0)
        CLK->CKDIVR &= (u8)~(CLK_CKDIVR_HSIDIV);        // fhsi= fhsirc (HSIDIV= 0)
        CLK->CCOR |= (u8)((4<<1) & CLK_CCOR_CCOSEL);// fcpu -> CCO pin
        CLK->CCOR |= (u8)(CLK_CCOR_CCOEN);
        butt= FALSE;
//         *** MAIN LOOP ***
        while(1) {
        if(button_is_pressed && butt == FALSE)
              {// test one time switch condition
        succ= switch_clock_system(to_HSE);        // switch from HSI to HSE clock
        butt= TRUE;
                switch_all_LEDs_on;        // switch on all LEDs
                Delay(1);                        // delay
                switch_all_LEDs_off;        // LEDs off
                Delay(1);                        // delay
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
验证例程需要注意的事项:
1、例程使用硬件为ST官方的STM8S-128/Eval,基于STM8S208
2、At least 1 wait state for reading flash and data memory should be performed
    if cpu works at 24Mhz fcpu frequency - set corresponding option register
        e.g. in STVD via MCU configuration window:
                (Debug instrument -> MCU configuration -> Option -> WAITSTATE -> 1)
总的一句话208要运行在24MHz,需要在optionbytes配置一个时钟等待周期。你跑16MHz不要理会这句话。
3、the switching routine can be used for LSI initialization if it is called
    with parameter to_LSI (LSI_EN bit should be set in that case in corresponding
         option EEPROM register via MCU configuration window: ...option -> LSI_EN -> Enabled)
例程会可能使用到LSI,请打开Optionbytes中的LSI_EN位。
gotomy|  楼主 | 2010-1-6 14:59 | 只看该作者
sorry ,是STM32的
香水城| | 2010-1-6 15:38 | 只看该作者
上电后,STM32默认使用HSI,不必做任何设置。
