| 写这个程序,正是大名鼎鼎的开源音视频解码编码库FFMPEG2.5.3版本
 在ffmpeg-2.5.3\libavcodec\mpeg4videodec.c
 static int decode_user_data(Mpeg4DecContext *ctx, GetBitContext *gb)
 MpegEncContext *s = &ctx->m;
 char buf[256];
 int i;
 int e;
 int ver = 0, build = 0, ver2 = 0, ver3 = 0;
 char last;
 for (i = 0; i < 255 && get_bits_count(gb) < gb->size_in_bits; i++) {
 if (show_bits(gb, 23) == 0)
 break;
 buf[i] = get_bits(gb, 8);
 buf[i] = 0;
 /* divx detection */
 e = sscanf(buf, "DivX%dBuild%d%c", &ver, &build, &last);
 if (e < 2)
 e = sscanf(buf, "DivX%db%d%c", &ver, &build, &last);
 if (e >= 2) {
 ctx->divx_version = ver;
 ctx->divx_build   = build;
 s->divx_packed  = e == 3 && last == 'p';    <<<< ------  就是这个地方
 if (s->divx_packed && !ctx->showed_packed_warning) {
 av_log(s->avctx, AV_LOG_INFO, "Video uses a non-standard and "
 "wasteful way to store B-frames ('packed B-frames'). "
 "Consider using a tool like VirtualDub or avidemux to fix it.\n");
 ctx->showed_packed_warning = 1;
 /* libavcodec detection */
 e = sscanf(buf, "FFmpe%*[^b]b%d", &build) + 3;
 if (e != 4)
 e = sscanf(buf, "FFmpeg v%d.%d.%d / libavcodec build: %d", &ver, &ver2, &ver3, &build);
 if (e != 4) {
 e = sscanf(buf, "Lavc%d.%d.%d", &ver, &ver2, &ver3) + 1;
 if (e > 1)
 build = (ver << 16) + (ver2 << 8) + ver3;
 if (e != 4) {
 if (strcmp(buf, "ffmpeg") == 0)
 ctx->lavc_build = 4600;
 if (e == 4)
 ctx->lavc_build = build;
 /* Xvid detection */
 e = sscanf(buf, "XviD%d", &build);
 if (e == 1)
 ctx->xvid_build = build;
 return 0;
