汇编语言,精简时钟
3826|15
 楼主| wangwo 发表于 2010-3-1 19:55 | 显示全部楼层 |阅读模式
汇编语言,精简时钟
;简易时钟,汇编程序(汇编精度高)
;作者:黄新建(从事机器的销售,参与控制板的开发与生产)
;2010年1月分
;--------------------ACC-------------------
A7     BIT    0E7H
A6     BIT    0E6H
A5     BIT    0E5H
A4     BIT    0E4H
A3     BIT    0E3H
A2     BIT    0E2H
A1     BIT    0E1H
A0     BIT    0E0H
Buffer EQU    R7
;-----AT24C02----------------------------
WriteAddress    equ    0A0H
ReadAddress     equ    0A1H
IIC_SCK         EQU    P2.1
IIC_SDA         EQU    P2.0
;-----LEDs-------------------------------
S1    EQU    P0.2
S2    EQU    P0.3
S3    EQU    P0.4
S4    EQU    P0.5
;------------------LED-------------------
LED   EQU    P1.0
LED2  EQU    P1.1
;-----74HC164----------------------------
SCK_164    EQU    P0.1
DAT_164    EQU    P0.0
;-----KEY--------------------------------
KeyHour    EQU    P2.4
KeyMin     EQU    P2.5
KeyEnter   EQU    P2.2
KeyExit    EQU    P2.3
;--------------Time---------------------
D1         EQU    30H;----------Time
Hour       EQU    31H
Min        EQU    32H
D2         EQU    33H
timer      EQU    34H
ClockHour  EQU    35H;----------Clock
ClockMin   EQU    36H
HourAddr   EQU    0
MinAddr    EQU    1
ORG    0000H
LJMP   Main
ORG    0003H
RETI
ORG 000BH
    LJMP Timer0Interrupt
;======================MAIN==================================
Main:
MOV    SP,#60H
acall  INIT
acall  InitTimer0
MOV    timer,#0
MOV    D1,#0
MOV    Min,#0
MOV    Hour,#12
MOV    Buffer,#HourAddr;Read Hour Data
ACALL  AT24C02_Read
MOV    ClockHour,Buffer
MOV    Buffer,#MinAddr;Read Min Data
ACALL  AT24C02_Read
MOV    ClockMin,Buffer
while:
MainL1:
ACALL  Display;display(Hour,Min)
ACALL  KeyDispose
MOV    a,timer
CJNE   a,#10,MainL2;if  timer>=500us  D1++;
MainL2:
JC     MainL3;如果C=1 说明a<10 如果a>=10 c=0
MOV    timer,#0
CPL    LED
INC    D1
mov    a,D1
cjne   a,#120,MainL3;if D1>60s  Min++;
MOV    D1,#0
inc    Min
mov    a,Min
CJNE   a,#60,MainL3 ;if Min>=60  Min=0; Hour++
mov    Min,#0       ;
inc    Hour;        ;
mov    a,Hour
cjne   a,#24,MainL3 ;if Hour>=24 Hour=0;
mov    Hour,#0      ;
MainL3:                 ;
LJMP   while
;=====================MAINEnd=================================
;=====================KeySet==================================
KeyDispose:
SETB   KeyHour
SETB   KeyMin
jb     KeyHour,KeyDisposeL1
ACALL  KeyDelay
INC    Hour
MOV    a,Hour
CJNE   a,#24,KeyDisposeL1
MOV    Hour,#0
KeyDisposeL1:
JB     KeyMin,KeyDisposeL2
ACALL  KeyDelay
INC    Min
MOV    a,Min
CJNE   a,#60,KeyDisposeL2
MOV    Min,#0
KeyDisposeL2:
RET
KeyDelay:
MOV    50H,#20
KeyDelayL1:
ACALL  Display
DJNZ   50H,KeyDelayL1
RET
;=====================KeyEnd==================================
;=====================TimeDisplay==============================
Display:
mov    DPTR,#LED_TAB;装入数据
mov    a,Hour;1
mov    b,#10
div    ab
mov    r1,b
movc   a,@a+DPTR
mov    r7,a
acall  HC164_Send
clr    S4
mov    r7,#1
acall  Delay_nMs
setb   S4;------------------
mov    a,r1
movc   a,@a+DPTR
xrl    a,#40H
mov    r7,a
acall  HC164_Send
clr    S3
mov    r7,#1
acall  Delay_nMs
setb   S3;==================
mov    a,Min;2
mov    b,#10
div    ab
mov    r1,b
movc   a,@a+DPTR
mov    r7,a
acall  HC164_Send
clr    S2
mov    r7,#1
acall  Delay_nMs
setb   S2;-----------------
mov    a,r1
movc   a,@a+DPTR
mov    r7,a
acall  HC164_Send
clr    S1
mov    r7,#1
acall  Delay_nMs
setb   S1
RET
;========================DisplayEnd===========================
;========================AT24C02==============================
AT24C02_Write:
mov    a,r7              ;addr
mov    50H,a
mov    a,r6              ;data
mov    51H,a
acall  IIC_Start         ;开始
mov    r7,#WriteAddress
acall  IIC_Write         ;写指令
mov    r7,50H
acall  IIC_Write         ;写地址
mov    r7,51H
acall  IIC_Write         ;写数据
acall  IIC_Stop          ;停止
mov    r7,#10
acall  Delay_nMs         ;delay10ms
RET
AT24C02_Read:
mov    a,r7
mov    50H,a
acall  IIC_Start         ;开始
mov    r7,#WriteAddress  ;写指令
acall  IIC_Write
mov    r7,50H            ;写地址
acall  IIC_Write
acall  IIC_Start         ;重新开始
mov    r7,#ReadAddress
acall  IIC_Write         ;读指令
acall  IIC_Read          ;读出数据(R7)
acall  IIC_NoAck         ;读完成
acall  IIC_Stop          ;停止
RET
IIC_Write:
mov    A,r7
mov    r4,#8
IIC_WriteL1:
CLR    IIC_SDA
    clr    C;c->A0
RLC    A;A7->C
jnc     IIC_WriteL2 ;if(A7==1) sda=1
setb   IIC_SDA
IIC_WriteL2:
    SETB   IIC_SCK
acall   Delay5Us
clr    IIC_SCK
djnz   r4,IIC_WriteL1
setb   IIC_SDA;test Ack
acall  Delay5Us
acall  Delay5Us
setb   IIC_SCK
acall  Delay5Us
clr    IIC_SCK
RET
IIC_Read:
mov    r4,#8
SETB   IIC_SDA
IIC_ReadL1:
SETB   IIC_SCK;clk=1
nop
nop
clr    c
jnb    IIC_SDA,IIC_ReadL2;if(sda==1) c=1
setb   c
IIC_ReadL2:
rlc    a
clr    IIC_SCK;clk=0
djnz   r4,IIC_ReadL1
mov    r7,a;return r7
RET
IIC_Start:
setb    IIC_SDA;sda=1
acall   Delay5Us
setb    IIC_SCK;clk=1
acall   Delay5Us
clr     IIC_SDA;sda=0
acall   Delay5Us
clr     IIC_SCK;clk=0
acall   Delay5Us
RET
IIC_Stop:
clr     IIC_SDA;sda=0
acall   Delay5Us
setb    IIC_SCK;clk=1
acall   Delay5Us
setb    IIC_SDA;sda=1
acall   Delay5Us
clr     IIC_SCK;clk=0
acall   Delay5Us
RET
IIC_NoAck:
setb    IIC_SDA;sda=1
acall   Delay5Us
setb    IIC_SCK;clk=1
acall   Delay5Us;
clr     IIC_SCK;clk=0
acall   Delay5Us
RET
Delay5Us:
nop;1us+call(2us)+ret(2us)=5us
RET
;========================AT24C02End===========================
;========================74HC164===============================
HC164_Send:
MOV R4,#8
HC164L1:
mov    a,#80H
ANL    a,r7
JB     A7,HC164L2
CLR    DAT_164
AJMP   HC164L3
HC164L2:
    SETB    DAT_164
HC164L3:
SETB    SCK_164
MOV     A,R7
CLR     C
RLC    A
MOV    R7,A
CLR    SCK_164
DJNZ R4,HC164L1
RET
;======================74HC164End================================
;=========================Delay================================
Delay_nUs:
djnz   r7,Delay_nUs
RET
Delay_nMs:
mov    r4,#250
djnz   r4,$
mov    r4,#250
djnz   r4,$
djnz   r7,Delay_nMs
RET
Delay_nS:
mov    r4,#8
DelayNsL2:
mov    r3,#250
DelayNsL1:
mov    r2,#250
djnz   r2,$
djnz   r3,DelayNsL1
djnz   r4,DelayNsL2
djnz r7,Delay_nS
RET
;=========================DelayEnd=============================
INIT:
mov    P0,#0FFH
mov    P1,#0FFH
mov    P2,#0FFH
mov    P3,#0FFH
SETB   EA ;打开CPU总中断请求
  SETB   IT0 ;设定INT0的触发方式为脉冲负边沿触发
  SETB   EX0 ;打开INT0中断请求
RET
InitTimer0:
    MOV TMOD,#01H
    MOV TH0,#3CH
    MOV TL0,#0C5H
    SETB EA
    SETB ET0
    SETB TR0
    RET
Timer0Interrupt:;2us
    PUSH DPH    ;2us
    PUSH DPL    ;2us
    PUSH ACC    ;2us
    MOV TH0,#3CH;2us
    MOV TL0,#0BCH;2us   -12us
    INC    timer ;
    POP ACC      ;
    POP DPL      ;
    POP DPH      ;
    RETI         ;
LED_TAB:
      DB        0B7H;0
      DB        084H;1
      DB        03DH;2
      DB        0ADH;3
      DB        08EH;4
      DB        0ABH;5
      DB        0BBH;6
      DB        085H;7
      DB        0BFH;8
      DB        0AFH;9
END
 楼主| wangwo 发表于 2010-3-1 19:56 | 显示全部楼层
贴出来大家看看,已经打包好了,想要的可以下:)
laslison 发表于 2010-3-1 20:23 | 显示全部楼层
很好,要了
麻辣鸭脖子 发表于 2010-3-1 22:41 | 显示全部楼层
 楼主| wangwo 发表于 2010-3-1 23:02 | 显示全部楼层
David_ming 发表于 2010-3-1 23:25 | 显示全部楼层
suoma 发表于 2010-3-5 17:57 | 显示全部楼层
挺长的啊
lovelyegle 发表于 2010-3-5 19:42 | 显示全部楼层
谢谢啦
David_ming 发表于 2010-3-5 21:47 | 显示全部楼层
大家用空可以玩一下DS1337这颗RTC芯片,顶好的IC,比DS1302强多了
huamunv 发表于 2010-3-12 22:16 | 显示全部楼层
:(有人说汇编很好学,偏偏我就不会用呢
linhai2009 发表于 2010-3-12 23:03 | 显示全部楼层
好长的汇编,可惜我汇编不怎么好
yidou 发表于 2010-3-12 23:42 | 显示全部楼层
楼主不仅贴出来了还压缩整理了:handshake
linhai1986 发表于 2010-3-13 09:35 | 显示全部楼层
LZ好人啊,不错的资料
eee3 发表于 2011-9-24 13:42 | 显示全部楼层
谢谢啦!
Andre.Gorz 发表于 2013-4-12 22:06 | 显示全部楼层
我觉得汇编还是蛮爽的啦。
huanghongxing 发表于 2013-4-13 15:52 | 显示全部楼层
这用汇编语言编写的程序挺长的,如果用c语言应该可以精简许多
