管道传输方式参数
738|7
 楼主| 栩栩如生 发表于 2016-5-19 19:13 | 显示全部楼层 |阅读模式
usb上位机的管道传输方式参数在哪里?
houcs 发表于 2016-5-19 19:15 | 显示全部楼层
在哪找不到
 楼主| 栩栩如生 发表于 2016-5-19 19:17 | 显示全部楼层
VOID
UsbSamp_EvtIoRead(
    IN WDFQUEUE         Queue,
    IN WDFREQUEST       Request,
    IN size_t           Length
Routine Description:
    Called by the framework when it receives Read requests.
Arguments:
    Queue - Default queue handle
    Request - Handle to the read/write request
    Lenght - Length of the data buffer associated with the request.
                 The default property of the queue is to not dispatch
                 zero lenght read & write requests to the driver and
                 complete is with status success. So we will never get
                 a zero length request.
Return Value:
    PFILE_CONTEXT           fileContext = NULL;
    WDFUSBPIPE              pipe;
    WDF_USB_PIPE_INFORMATION   pipeInfo;
    PAGED_CODE();
    // Get the pipe associate with this request.
    fileContext = GetFileContext(WdfRequestGetFileObject(Request));
    pipe = fileContext->Pipe;
    if (pipe == NULL) {
        UsbSamp_DbgPrint(1, ("pipe handle is NULL\n"));
        WdfRequestCompleteWithInformation(Request, STATUS_INVALID_PARAMETER, 0);
        return;
    WDF_USB_PIPE_INFORMATION_INIT(&pipeInfo);
    WdfUsbTargetPipeGetInformation(pipe, &pipeInfo);
    if((WdfUsbPipeTypeBulk == pipeInfo.PipeType) ||
       (WdfUsbPipeTypeInterrupt == pipeInfo.PipeType)) {
        ReadWriteBulkEndPoints(Queue, Request, (ULONG) Length, WdfRequestTypeRead);
        return;
    } else if(WdfUsbPipeTypeIsochronous == pipeInfo.PipeType){
#if !defined(BUFFERED_READ_WRITE) // if doing DIRECT_IO
        ReadWriteIsochEndPoints(Queue, Request, (ULONG) Length, WdfRequestTypeRead);
        return;
#endif
    UsbSamp_DbgPrint(1, ("ISO transfer is not supported for buffered I/O transfer\n"));
    WdfRequestCompleteWithInformation(Request, STATUS_INVALID_DEVICE_REQUEST, 0);
    return;
liuzaiy 发表于 2016-5-19 19:27 | 显示全部楼层
程序有什么问题
 楼主| 栩栩如生 发表于 2016-5-19 19:28 | 显示全部楼层
请问这函数中是怎么识别管道传输和登时传输的,文中我能看得懂。但是在上位机程序中我们调用了readfile,可是readfile没有传递相关的管道信息呀
pangb 发表于 2016-5-19 19:30 | 显示全部楼层
至少应该给一个参数说明是用的哪种传输方式和管道,端点
chenjunt 发表于 2016-5-19 19:31 | 显示全部楼层
如果你使用的是cypress 的上位机软件开发包,建议可以下载最新cysuite,参考里面的cyAPI文档。希望对你有帮助
 楼主| 栩栩如生 发表于 2016-5-19 19:32 | 显示全部楼层
嗯,我看下,多谢
