[应用方案] 基于单片机的秒表程序上读写数据至24c02芯片
947|3
 楼主| ideafor 发表于 2016-6-15 22:18 | 显示全部楼层 |阅读模式
        #include<reg51.h>
                #define uchar unsigned char
                #define uint unsigned int
                bit write=0;
                sbit sda=P2^0;
                sbit scl=P2^1;
                sbit wei0=P1^0;
                sbit wei1=P1^1;
                uchar sec,tcnt;
                uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
                void delay()
                void delayms(uint z)
                        uint x,y;
                        for(x=z;x>0;x--)
                        for(y=110;y>0;y--);
                void start()
                        sda=1;
                        delay();
                        scl=1;
                        delay();
                        sda=0;
                        delay();
                void stop()
                        sda=0;
                        delay();
                        scl=1;
                        delay();
                        sda=1;
                        delay();
                void respons()
                        uchar i;
                        scl=1;
                        delay();
                        while((sda==1)&&(i<250))i++;
                        scl=0;
                        delay();
                void init()
                        sda=1;
                        delay();
                        scl=1;
                        delay();
                void write_byte(uchar date)
                        uchar i,temp;
                        temp=date;
                        for(i=0;i<8;i++)
                                temp=temp<<1;
                                scl=0;
                                delay();
                                sda=CY;
                                delay();
                                scl=1;
                                delay();
                        scl=0;
                        delay();
                        sda=1;
                        delay();
                uchar read_byte()
                        uchar i,k;
                        scl=0;
                        delay();
                        sda=1;
                        delay();
                        for(i=0;i<8;i++)
                                scl=1;
                                delay();
                                k=(k<<1)|sda;
                                scl=0;
                                delay();
                    return k;
                void write_add(uchar address,uchar date)
                        start();
                        write_byte(0xa0);
                        respons();
                        write_byte(address);
                        respons();
                        write_byte(date);
                        respons();
                        stop();
                uchar read_add(uchar address)
                        uchar date;
                        start();
                        write_byte(0xa0);
                        respons();
                        respons();
                        start();
                        write_byte(0xa1);
                        respons();
                        date=read_byte();
                        stop();
                        return date;
                void display(uchar shi,uchar ge)
                        wei0=1;
                        wei1=1;
                        P0=table[shi];
                        wei0=0;
                        delayms(10);
                        wei0=1;
                        wei1=0;
                        P0=table[ge];
                        delayms(10);
                        wei1=1;
                void main()
                        init();
                        sec=read_add(2);
                        if(sec>100)sec=0;
                        TMOD=0x01;
                        ET0=1;
                        EA=1;
                        TH0=(65536-50000)/256;
                        TL0=(65536-50000)%256;
                        TR0=1;
                        while(1)
                                display(sec/10,sec%10);
                                if(write==1)
                                        write=0;
                                        write_add(2,sec);
                void t0() interrupt 1
                        tcnt++;
                        if(tcnt==20)
                                tcnt=0;
                                sec++;
                                write=1;
                                if(sec==100)
                                sec=0;
gaoyang9992006 发表于 2016-6-16 18:06 | 显示全部楼层
不要贴个程序就跑了,要说下这个芯片咋回事,然后说清楚了,再来段例程。
Bermanrep 发表于 2016-6-18 09:39 | 显示全部楼层
楼主你这个程序是51单片机的吗,看着貌似是模拟的
yiyigirl2014 发表于 2016-6-19 12:57 | 显示全部楼层
没看懂是什么意思
