TI 28027 加密报错
695|0
 楼主| ljgljgljg 发表于 2016-6-21 17:03 | 显示全部楼层 |阅读模式
C28xx: Flash operation timed out waiting for the algorithm to complete. Operation cancelled.
C28xx: Trouble Writing Memory Block at 0x3f7f80 on Page 0 of Length 0x76: (Error -1135 @ 0x5DC) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.0.569.0)
C28xx: GEL: File: D:\King\King\Tmp\201606210\development_kits\HVMotorCtrl+PfcKit_v1.6\HVPM_Sensored\F2803x_FLASH\HVPM_Sensored.out: Load failed.
C28xx: Error: (Error -1135 @ 0x5DC) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.0.569.0)
怎么回事啊??配置如下
.sect "csmpasswds"
      .int    0x5678        ;PWL0 (LSW of 128-bit password)
      .int    0xFFFF        ;PWL1
      .int    0xFFFF        ;PWL2
      .int    0xFFFF        ;PWL3
      .int    0xFFFF        ;PWL4
      .int    0xFFFF        ;PWL5
      .int    0xFFFF        ;PWL6
      .int    0xFFFF        ;PWL7 (MSW of 128-bit password)
; For code security operation, all addresses between 0x3F7F80 and
; 0X3f7ff5 cannot be used as program code or data.  These locations
; must be programmed to 0x0000 when the code security password locations
; (PWL) are programmed.  If security is not a concern, then these addresses
; can be used for code or data.
; The section "csm_rsvd" can be used to program these locations to 0x0000.
        .sect "csm_rsvd"
        .loop (3F7FF5h - 3F7F80h + 1)
              .int 0x0000
        .endloop
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   PRAML0      : origin = 0x008000, length = 0x000500     /* on-chip RAM block L0 */
   OTP         : origin = 0x3D7800, length = 0x000400     /* on-chip OTP */
// FLASHD      : origin = 0x3F0000, length = 0x001000     /* on-chip FLASH */
// FLASHC      : origin = 0x3F1000, length = 0x001000     /* on-chip FLASH */
   FLASHA      : origin = 0x3F0000, length = 0x007F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
   CSM_PWL_P0  : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
   IQTABLES    : origin = 0x3FE000, length = 0x000B50     /* IQ Math Tables in Boot ROM */
   IQTABLES2   : origin = 0x3FEB50, length = 0x00008C     /* IQ Math Tables in Boot ROM */
   IQTABLES3   : origin = 0x3FEBDC, length = 0x0000AA          /* IQ Math Tables in Boot ROM */
   ROM         : origin = 0x3FF27C, length = 0x000D44     /* Boot ROM */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM  */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM  */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   BOOT_RSVD   : origin = 0x000000, length = 0x000050     /* Part of M0, BOOT rom will use this for stack */
   RAMM0       : origin = 0x000050, length = 0x0003B0     /* on-chip RAM block M0 */
   RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
   DRAML0      : origin = 0x008500, length = 0x000A80     /* on-chip RAM block L0 */
   DRAML1      : origin = 0x008F80, length = 0x000080     /* on-chip RAM block L1 */
// FLASHB      : origin = 0x3F4000, length = 0x002000     /* on-chip FLASH */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
   /* Allocate program areas: */
   .cinit              : > FLASHA       PAGE = 0
   .pinit              : > FLASHA,      PAGE = 0
   .text               : > FLASHA       PAGE = 0
   codestart           : > BEGIN        PAGE = 0
   ramfuncs            : LOAD = FLASHA,
                         RUN = PRAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         PAGE = 0
   csmpasswds          : > CSM_PWL_P0   PAGE = 0
   csm_rsvd            : > CSM_RSVD     PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM0        PAGE = 1
   .ebss               : > DRAML0       PAGE = 1
   .esysmem            : > DRAML1       PAGE = 1
   /* Initalized sections go in Flash */
   /* For SDFlash to program these, they must be allocated to page 0 */
   .econst             : > FLASHA       PAGE = 0
   .switch             : > FLASHA       PAGE = 0
   /* Allocate IQ math areas: */
   IQmath              : > FLASHA       PAGE = 0            /* Math Code */
   IQmathTables        : > IQTABLES,    PAGE = 0, TYPE = NOLOAD
   /* Uncomment the section below if calling the IQNexp() or IQexp()
      functions from the IQMath.lib library in order to utilize the
      relevant IQ Math table in Boot ROM (This saves space and Boot ROM
      is 1 wait-state). If this section is not uncommented, IQmathTables2
      will be loaded into other memory (SARAM, Flash, etc.) and will take
      up space, but 0 wait-state is possible.
   IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
   /* Uncomment the section below if calling the IQNasin() or IQasin()
   IQmathTables3    : > IQTABLES3, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNasinTable.obj> (IQmathTablesRam)
   /* .reset is a standard section used by the compiler.  It contains the */
   /* the address of the start of _c_int00 for C Code.   /*
   /* When using the boot ROM this section and the CPU vector */
   /* table is not needed.  Thus the default type is set here to  */
   /* DSECT  */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
