[嵌入式Linux] AM5728/AM57XX openCL使用案例一(查询硬件资源)
1392|0
 楼主| ohyes158 发表于 2016-6-22 10:43 | 显示全部楼层 |阅读模式
我们知道AM5728/AM57XX系列芯片支持使用openCL来调用DSP,
因此可以通过openCL硬件加速来提升算法效率,降低 CPU使用率.
openCL是一个为异构系统编写程序的框架,该异构系统可以由
CPU,GPU,DSP甚至FPGA组成,因此openCL开发人员需要对其运行的
硬件平台有非常大的了解,下面程序主要用来查询openCL的硬件资源
程序源码如下
int main(void)
    char strings[512];
    cl_uint num_platform;
    cl_platform_id platform_id[20];
    cl_uint num_device;
    cl_device_id device_id[20];
    cl_device_type device_type;
    cl_ulong tmp;
    clGetPlatformIDs(0, NULL, &num_platform);
    clGetPlatformIDs(num_platform, platform_id, NULL);
    for (int i = 0; i < num_platform; i ++) {
        clGetPlatformInfo(platform_id, CL_PLATFORM_NAME, 512, strings, NULL);
        printf("platform name [%s]\n", strings);
        clGetPlatformInfo(platform_id, CL_PLATFORM_VENDOR, 512, strings, NULL);
        printf("platform vendor [%s]\n", strings);
        clGetPlatformInfo(platform_id, CL_PLATFORM_VERSION, 512, strings, NULL);
        printf("platform version [%s]\n", strings);
        clGetPlatformInfo(platform_id, CL_PLATFORM_PROFILE, 512, strings, NULL);
        printf("platform profile [%s]\n", strings);
        clGetDeviceIDs(platform_id, CL_DEVICE_TYPE_ALL, 20, device_id, &num_device);
        for (int j = 0; j < num_device; j ++) {
            clGetDeviceInfo(device_id[j], CL_DEVICE_TYPE, sizeof(cl_device_type),
                            &device_type, NULL);
            if (device_type == CL_DEVICE_TYPE_CPU)
                printf("device type [cpu]\n");
            else if (device_type == CL_DEVICE_TYPE_GPU)
                printf("device type [gpu]\n");
            else if (device_type == CL_DEVICE_TYPE_ACCELERATOR)
                printf("device type [accelerator]\n");
            clGetDeviceInfo(device_id[j], CL_DEVICE_NAME, 512, strings, NULL);
            printf("device name [%s]\n", strings);
            clGetDeviceInfo(device_id[j], CL_DEVICE_GLOBAL_MEM_SIZE,
                            sizeof(cl_ulong), &tmp, NULL);
            printf("device global mem [%lld]MB\n", tmp/1024/1024);
            clGetDeviceInfo(device_id[j], CL_DEVICE_GLOBAL_MEM_CACHE_SIZE,
            printf("device global mem cache [%lld]KB\n", tmp/1024);
            clGetDeviceInfo(device_id[j], CL_DEVICE_LOCAL_MEM_SIZE,
            printf("device local mem [%lld]KB\n", tmp/1024);
            clGetDeviceInfo(device_id[j], CL_DEVICE_MAX_MEM_ALLOC_SIZE,
            printf("device max mem alloc [%lld]MB\n", tmp/1024/1024);
            clGetDeviceInfo(device_id[j], CL_DEVICE_MAX_CLOCK_FREQUENCY,
            printf("device max clock frequency [%lld]MHZ\n", tmp);
            clGetDeviceInfo(device_id[j], CL_DEVICE_MAX_COMPUTE_UNITS,
            printf("device max compute unit [%lld]\n", tmp);
    return 0;
将上述程序进行编译,在am5728板卡上运行,结果如下
转载,请注明  匠牛社区AM5728开发板
