[嵌入式Linux] AM5728/AM57XX openCL使用案例二(计算向量和)
1097|0
 楼主| ohyes158 发表于 2016-6-22 11:03 | 显示全部楼层 |阅读模式
下面通过一个向量相加的程序来了解OpenCL . 有A,B两个四维向量,相加后值存在C向量里,openCL根据用户提供的维数,将向量分解成多个任务分发给DSP进行并行计算
openCL程序分为两个部份,一部份是内核代码,负责具体算法。另一部份是主程序负责初始化OpenCL和准备数据。主程序加载内核代码,并按照既定方法进行运算
kernel代码如下
__kernel voidvectoradd(__global int *a, __global int *b, __global int *c)
    int id = get_global_id(0);
    c[id] = a[id] + b[id];
__kernel 指明这是一个openCL内核,__global 说明指针指向的是全局的设备内存空间
HOST端代码如下
int get_ocl_string(const char *file_name, char *ocl_string)
    FILE *fp;
    int file_length;
    int status = 0;
    fp = fopen(file_name, "r");
    if (fp == NULL)
        return -1;
    fseek(fp, 0, SEEK_END);
    file_length = ftell(fp);
    fseek(fp, 0, SEEK_SET);
    status = fread(ocl_string, 1, file_length,fp);
    if (status == -1)
        return -1;
    return file_length;
int main(void)
    int array_a[10] = {0, 1, 2, 3, 4, 5, 6, 7,8, 9};
    int array_b[10] = {9, 8, 7, 6, 5, 4, 3, 2,1, 0};
    int array_c[10] = {0, 0, 0, 0, 0, 0, 0, 0,0, 0};
    size_t datasize = 10 * sizeof(int);
    size_t ocl_string_size;
    char *ocl_string;
    ocl_string = (char *)malloc(1024*1024);
    cl_platform_id platform_id;
    cl_device_id device_id;
    cl_context context;
    cl_command_queue command_queue;
    cl_mem buffer_a, buffer_b, buffer_c;
    cl_program program;
    cl_kernel kernel;
    clGetPlatformIDs(1, &platform_id,NULL);
    clGetDeviceIDs(platform_id,CL_DEVICE_TYPE_ACCELERATOR, 1, &device_id, NULL);
    //创建上下文
    context = clCreateContext(NULL, 1,&device_id, NULL, NULL, NULL);
    command_queue = clCreateCommandQueue(context,device_id, 0, NULL);
   //分配内存
    buffer_a = clCreateBuffer(context,CL_MEM_READ_ONLY, datasize, NULL, NULL);
    buffer_b = clCreateBuffer(context,CL_MEM_READ_ONLY, datasize, NULL, NULL);
    buffer_c = clCreateBuffer(context,CL_MEM_READ_ONLY, datasize, NULL, NULL);
   //读取核函数,并且上传到DSP端
    ocl_string_size =get_ocl_string("vectoradd.cl", ocl_string);
    clEnqueueWriteBuffer(command_queue,buffer_a, CL_FALSE, 0, datasize, array_a, 0, NULL, NULL);
    clEnqueueWriteBuffer(command_queue,buffer_b, CL_FALSE, 0, datasize, array_b, 0, NULL, NULL);
    program =clCreateProgramWithSource(context, 1, (const char **)&ocl_string,&ocl_string_size, NULL);
    clBuildProgram(program, 1, &device_id,NULL, NULL, NULL);
    kernel = clCreateKernel(program,"vectoradd", NULL);
   //传递参数
    clSetKernelArg(kernel, 0,sizeof(cl_mem),&buffer_a);
    clSetKernelArg(kernel, 1,sizeof(cl_mem),&buffer_b);
    clSetKernelArg(kernel, 2,sizeof(cl_mem),&buffer_c);
    size_t global_work_size[1] = {10};
    //执行核函数
    clEnqueueNDRangeKernel(command_queue,kernel, 1, NULL, global_work_size, NULL, 0, NULL, NULL);
    //从核函数取回计算结果
    clEnqueueReadBuffer(command_queue,buffer_c, CL_TRUE, 0, datasize, array_c, 0, NULL, NULL);
    for (int i = 0 ; i < 10; i ++) {
        printf("%d ", array_a);
    printf("\n");
        printf("%d ", array_b);
    printf("\n");
        printf("%d ", array_c);
    printf("\n");
    clReleaseKernel(kernel);
    clReleaseProgram(program);
    clReleaseCommandQueue(command_queue);
    clReleaseMemObject(buffer_a);
    clReleaseMemObject(buffer_b);
    clReleaseMemObject(buffer_c);
    clReleaseContext(context);
    return 0;
将上述程序编译,结果如下
0 1 2 3 4 5 6 7 89
9 8 7 6 5 4 3 2 10
9 9 9 9 9 9 9 9 99
转载,请注明  匠牛社区AM5728开发板
