28335的AD采样频率设置
763|2
 楼主| ziyiren 发表于 2016-6-26 23:01 | 显示全部楼层 |阅读模式
在TI提供的controlsuite中:
   EALLOW;
   #if (CPU_FRQ_150MHZ)     // Default - 150 MHz SYSCLKOUT
     #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3)   = 25.0 MHz
   #endif
   #if (CPU_FRQ_100MHZ)
     #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2)   = 25.0 MHz
   #endif
   EDIS;
// Assumes ePWM1 clock is already enabled in InitSysCtrl();
   EPwm1Regs.ETSEL.bit.SOCAEN = 1;        // Enable SOC on A group
   EPwm1Regs.ETSEL.bit.SOCASEL = 4;       // Select SOC from from CPMA on upcount
   EPwm1Regs.ETPS.bit.SOCAPRD = 1;        // Generate pulse on 1st event
   EPwm1Regs.CMPA.half.CMPA = 0x0080;          // Set compare A value
   EPwm1Regs.TBPRD = 0xFFFF;              // Set period for ePWM1
   EPwm1Regs.TBCTL.bit.CTRMODE = 0;                  // count up and start
修改EPwm1Regs.TBPRD = 0xFFFF;这部分应该就是设置ADC频率了吧?
还有28335的晶振是30MHz,这里有用到吗?为什么?
houjiakai 发表于 2016-6-27 22:54 | 显示全部楼层
楼主是要设置多少的采样频率
houjiakai 发表于 2016-6-27 22:56 | 显示全部楼层
直接读取ADC的数值吧。
